My Budget LS1 Swap Guide - Chevy Nova Forum
Go Back   Chevy Nova Forum > Body, Chassis and Mechanical > Drivetrain & Performance > LSx Forum
Old 3rd-March-2009, 04:43 PM   #1
MeanYellowZ
(OP)
Nova(s): 62 Chevy II, LS1, Turbo,
Alright, I had a handful of guys wanting more info on how to swap in an LS-series of engine on a limited budget. I do these conversions pretty much for a living and will try and help shed some light on installing one of these in about anything on the lowest budget possible. Dependability, great power output, mileage and the cool factor all can come at a very reasonable price if you are willing to work a little for it.
First off a little about the engines I will be referring to. In my world I refer to either the 4.8, 5.3, 5.7 or 6.0 engines as LS1 as they share the same platform and most parts with the actual 5.7 aluminum RPO LS1 engines. I rarely do ACTUAL LS1 swaps and here is why. The two main advantages a Camaro/ Firebird/ Corvette LS1 have over a truck 5.3 for example are that the aluminum block weighs 65lbs less and they usually make around 10 horsepower more. These two factors do not warrant the big difference in price to me. There have been dyno tests were 5.3s were swapped in place of 5.7s and with all parts the same (intake, etc) they usually made 9-10 horsepower less. This is obviously NOT a large difference. I'm not bashing a true LS1 by any means, but the 5.3s can usually be bought for 1/3 to 1/4 of the price, so I tend to use them.
That said.....
With some digging around, you can usually pickup a complete 5.3 for anywhere between $250-$550. The way I usually get them is top to bottom, with truck intake/ rails/ injectors/ coils. They usually do NOT have starters, alternators, power steering, etc. This is just the way I get them. I have bought 18 of them this way.
The next biggest expense is usually the harness, which you have different options. Either harness can be made to work, be it from a truck or a LS-car harness (Camaro, Firebird) The biggest differences are that the trucks use a different injector plug type than the cars and the truck harnesses lay out differently. I try to avoid the truck harnesses as much as possible due to the odd layout, they are harder to make look nice and they are wired a little more complexly than the car ones (more keyed power sources) Here is where you have to decide what direction you are going to go, plan on leaving the less attractive truck intake (still make good power) or switch to the car style intake/ rails/ injectors to make it look more like an actual LS1. A stock harness usually will run around $150-200 dollars and you will then have to spend 3-4 hours cutting it apart/ figuring out the wires that won't be needed for your application and removing them and finding the wires you will need to connect to make your swap run. This is not a very difficult task, but it does require some patience and a good source of info, such as:
http://www.ls1tech.com/forums/conver...swap-faqs.html
This would be the cheaper route to go if you are somewhat confident in wiring, the other route would be to buy an aftermarket or already converted harness. I have previously reconfigured all factory harnesses for my swaps but am now going to try an ebay vendor that sells all new harnesses in the $350 dollar range. These are made with the correct length wires to place the ECM better and layout more pleasing to the eyes. It would take a lot of work to modify every wire on an older harness to make it layout as nicely as one of the custom built from scratch harnesses.
The next item to consider is what transmission you plan on running. The LS engines will work with any older GM trans with some considerations. TH350s/ 700R4s/ TH400s work by using a GM part as a flexplate spacer and bolts to place the flexplate at the proper spacing, and this part provides a place for the converter snout to engage, using the original converter. The thing to consider is the downshift/ TV cables associated need to be addressed. Companies like Bowtie overdrives, etc have pieces to make them work. Obviously the 6-speeds/ 4l60Es designed to be behind the LS-engines work easily with the proper harnesses if your budget allows.
Next would be the fuel system. The easiest way to do this would be to use an inline Walbro pump sold all over the net, usually around $120 and the corvette filter-regulator combo. There are many options here depending on yor vehicle as far as getting the fuel to the pump. You can pull your factory sending unit and find a way to mount the pump to the sender and install in tank, or maybe even an aftermarket vendor makes a sending unit for your application to do just that. Other options including welding a sump to the bottom of the tank and feeding from there. Next would be installing a fuel cell or even an aftermarket tank designed for EFI use in your application. Some even just mount the pump and pull fuel through the factory pickup. This is usually okay for lower horsepower (stock swaps) and certain pumps, as some don't like pulling fuel very much and might not last forever. After the pump, you feed the corvette filter/ regulator which then has an output that you run to the fuel rail and it also has an output for return fuel back to the tank which just needs plumbed into the top of the tank. The truck intake and fuel rails includes a regulator so you can just run a line up to it and a line back from it returning unused fuel to the tank.
The only other variable here is what accessories you need to run on your engine. Of course there are vendors out there like March, Kwik Performance etc that sell complete accessories setups that are nice, but pricey, which doesn't fit into this budget writeup. I usually am doing hotrod style swaps that often only include an alternator. These are fairly simple, I usually use GM CS-style alternators, found in TBI/ TPI style 4.3-5.0-5.7 engines. These are pretty affordable, work well and are easily replaceable in case of failure. Making mounts out of simple metal (3/16s bar stock-3/8ths round stock) doesn't take too much skill. Just mount the alternator out of everythings way in your swap and most times you can even route the belt to use the factory tensioner. I have done many this way and even some with power steering and used the factory tensioner with perfect results. None ever took more than two hours to figure out. For the non creative types the easiest way to do this is to hold a straightedge across the balancer and hold the alternator up to it in a good spot and find a way to tack a bracket in place to hold it temporarily and then build some easy brackets (I love using the round bar) to mount it, it doesnt even need to adjust if you use the factory tensioner. Of course using factory LS1 brackets/ accessories is always a possibility if they fit your application and are available for use. The thing to keep in mind is that the truck/F-body/Corvette all use different accessory spacing in regards to the distance from the pulley to the block, the trucks stick out the furthest, the F-body is in about 5/8 from that and the vette is in a little more. The total difference between all three is around an inch I believe, but it is enough to make obvious bracket issues if trying to mix and match parts.
Well if you are still with me I am going to make a few lists with pricing for a few different situations.
First would be low budget, this would include a 5.3 engine swap, leaving the truck intake and using for this example a TH400 trans that was already in the vehicle.
5.3 Engine $350
Stock truck harness $150
Add on fuse panel for harness $40
ECM $40
Conversion mounts $50
Gm Trans adapter/ bolts $50
New starter $80
GM CS alternator-junkyard $25
walbro fuel pump $120
Maf sensor - used -ebay $40
New O2 sensors $120
radiator hoses $20
Fuel lines/ fittings $100
Computer reflash $150
Exhaust work/ O2 bungs $100
Total $1435
This would be the bare minimum swap into a vehicle. For example I just did a swap like this into a 69 Chevy truck. This has no hood clearance issues for the taller intake, standard truck manifolds that came with the engine fit the chassis in this application. The trucks stock radiator worked excellent as the LS-engines run pretty cool anyhow. The truck had existing electric fans like many vehicles out there already may have.
This swap would have been for the more do-it-yourself kinda guy as it used a stock harness requiring the modifications to make it work.
Now, take that same swap and add the car intake/ rails/ injectors and use an aftermarket harness which is already done, wires in with only a few connections and looks much nicer.
Previous price $1435
LS1 intake $80
LS1 rails $50
LS1 injectors $40
aftermarket harness (ebay) $350
credit back -truck harness -$150
credit back - fuse panel -$40
Total $1765
From there just add whatever YOU might need for your swap. Things to keep in mind are:
Do any of the stock LS style manifolds fit your chassis? There are many choices, including those from the trucks, F-body, vette C5, vette C6, GTO, even the front wheel drive style ones. If none of these fit you may be left going to an aftermarket vendor that makes swap headers, or having a set made. Obviously the cost can vary greatly here.
The other thing to keep in mind is the oil pan. The LS engines came with many differents pans. The truck pans mimick old school SBC style but hang kinda low. The F-body pans are lower profile but extend further forward. Research will have to be done for your application.
The best part about the internet is that almost any combination you can think of for any swap has been done or tried, so a little research can go a long way towards planning your swap.
I tried to use accurate pricing for this writeup. Obviously some parts can be found cheaper or more expensive, these are just my findings. If you have trouble locating a part in the same price range, feel free to contact me for help.
Good luck guys and don't get discouraged, these swaps are not that hard and they are great when finished.
Feel free to contact me via PM, in this thread or via email
MeanYellowZ@hotmail.com
Some pics of a few of my swaps and misc:
This is how I buy the engines...right from the junkyard
after cleanup and some paint....
Old 3rd-March-2009, 05:23 PM   #2
The Big Al
The Big Al's Avatar
Nova(s): 68ss, 70ss (SOLD)
THIS IS A GREAT THREAD!!!!!
I have to say!
Feel like I just read a Car Magazine
“The bitterness of poor quality & Service remains long after the sweetness of low price is forgotten”
Old 3rd-March-2009, 05:42 PM   #3
nononononova
Nova(s): none currently
How many Nova swaps have you done? Did you have to do anything to the firewall in any of them?
Sticks and stones may break my bones but words are like bullets. Some people get shot in the heart.
Old 3rd-March-2009, 05:42 PM   #4
novavetteguy
novavetteguy's Avatar
This is outstanding info!!
THANK YOU!!
63 Wagon 3 Seats 327/700R4(SOLD)
61 Corvette 283/270HP 2-4s 4spd (SOLD
63 'Vert "Updated"
Old 3rd-March-2009, 06:50 PM   #5
MeanYellowZ
(OP)
Looks like I'm going to have to go back and correct some spelling! I just got to typing and went crazy....
I have personally only done ONE Chevy II swap, which was my turbocharged 62, which doesn't really fit this thread because it wasn't exactly a budget or stock swap. There are a handful of people on this site that have done stock frontend swaps and I'm sure they can be of help with that particular info. I know this is a Nova site, but my info is kinda general for all types of vehicles, hopefully it helps answer some questions about the LS-swaps themselves.
I do have a 73 Nova coming in the next few weeks for a swap with turbo for me to do, so I will have some experience with those soon. Thus far I have experience with swaps in:
- Early 90's Chevy trucks
- 49-54 Chevy Truck
- Early Chevy II with aftermaket clip
- C4 Corvette
- 94+ S10/ Blazer
- 55-59 Chevy Truck
- 82-92 F-body
- 67-72 C-10
Old 3rd-March-2009, 07:05 PM   #6
scherp69
scherp69's Avatar
Nova(s): 68 pro-touring Acadian
Great thread. Thanks for spending the time to do it up. This is all I've been thinking about lately is what to do for a motor. I am highly leaning towards an LS conversion and was going to get a new crate, but now you have me thinking.
Mike
Old 3rd-March-2009, 07:31 PM   #7
tbills66
tbills66's Avatar
Nova(s): 66 SS
This should be pinned. I am wanting to do this with a turbo setup when I get the money.
Old 3rd-March-2009, 07:33 PM   #8
MeanYellowZ
(OP)
Turbos and LS engines are a bad idea....
.......for your tires
http://www.youtube.com/watch?v=h9Zil...e=channel_page
Old 3rd-March-2009, 07:37 PM   #9
MPLS66
MPLS66's Avatar
Nova(s): 63SS 67 sedan
Thank you for explaining the process. THE INFORMAYION WAS VERY HELPFUL
Old 3rd-March-2009, 08:25 PM   #10
novavetteguy
Couple of questions:
Based on your experience, what clip would you recommend?
Do you know if there is an after market fuel tank w/pump already available?
Approx. what would you charge a customer for option #2 on your list? (you can PM me this if you like.)
63 'Vert "Updated"
Old 3rd-March-2009, 08:28 PM   #11
tbills66
tbills66's Avatar
Nova(s): 66 SS
That is sweet.
This is a guy off of one of the other forums I'm on.
http://www.youtube.com/watch?v=Z_R7N...eature=related
http://www.youtube.com/watch?v=_G2eWE-5Rvc&NR=1
Old 3rd-March-2009, 08:52 PM   #12
MeanYellowZ
(OP)
I don't know of an aftermarket tank off hand but I think I have seen them out there. There are also aftermarket senders out there. Without starting a large angry thread I can say I ran the Heidts clip and wasn't super happy with it. I like the ones from checkeredracing by my research
Old 3rd-March-2009, 09:48 PM   #13
slow3oh
slow3oh's Avatar
Nova(s): 71 project 68 daily driv
GREAT thread
Ive been looking for low buck good motors to build up for the nova
now you got me thinking
1972 SS -sold
1971 383-sold
1970 350-sold
1968 SS 383 Daily driven
Old 3rd-March-2009, 11:27 PM   #14
Nik_95cobra
Nik_95cobra's Avatar
Thanks MeanYellow, cool thread, I think I'm going this route on mine.
1962 Chevy II - 1995 SVT Cobra
Old 4th-March-2009, 06:50 AM   #15
waldos_1
waldos_1's Avatar
Nova(s): 1971 now
We have done 2 ls1 swaps in 2 cars with just a cam upgrade and we went to a carb set up and wow they run in the 10,s wasent bad at all and gonna do another soon
LS1 swap. ACONLP Drivetrain & Performance 2 6th-February-2008 12:26 PM
Need help LS1 swap idoctr 3rd Generation Chevy II/Nova's 2 4th-June-2007 04:02 PM
Possible LS1 Swap ProchargedchevyI Drivetrain & Performance 5 2nd-June-2007 09:44 PM
LS1 swap?? Qwk Drivetrain & Performance 2 23rd-August-2006 09:14 PM
