Wrong Fel-pro one piece gasket? - Chevy Nova Forum
Old 26th-February-2009, 12:43 AM   #1
therooster
(OP)
therooster's Avatar
Title: Nova Newbie
Nova(s): 1964 Nova 400 series Coup
Angry Wrong Fel-pro one piece gasket?
I just installed a new Fel-pro gasket part # OS-34509 T (thin seal) on my 69-79 350 4-bolt block. I got everything tightened up noticed that the front journal has a small gap. I heard the thick seal is for the newer 350's (OS-34510 T) but it seams like the thick one will make up that gap. The rear journal looks to be seated ok (kinda hard to see). Could it possibly be my front cover is from a newer 350? Are they different?
thanks.
-Nick
Old 26th-February-2009, 12:51 AM   #2
The Big Al
The Big Al's Avatar
Nova(s): 68ss, 70ss (SOLD)
Best of Drivetrain & Performance
http://www.stevesnovasite.com/forums...ad.php?t=17384
“The bitterness of poor quality & Service remains long after the sweetness of low price is forgotten”
Old 26th-February-2009, 06:25 PM   #3
fujimook
Just installed a new oil pan on my early 327 and what I found was that front seal thickness is dictated by the pan, not the timing chain cover. 55-74 sbc's used the thin seal (felpro 34509t) and 75-85 used the thick front seal (34510t). If you're not sure what you've got, lay a straight edge across the front oil pan rails and measure down to the pan seal lip. 2 1/4" uses a thin seal and 2 3/8 uses a thick seal. 86 & later use a thick front seal but require a 1pc rear main seal. FWIW, found the least expensive 34510t @ O'Rielly's; about $22 + tax.
Hope this helps.
john
70 Nova, 327, AFR, TRW, Perf RPM, Holley dp, Comp xs268s, DIY HEI & cowl air, headers, 4 spd, PowerTrax
Old 9th-March-2009, 10:42 AM   #4
67-CII
67-CII's Avatar
Nova(s): 67 Hardtop on E85
Been There Done That
Have a 74 3/4 Ton 350 4bolt but the guy who owned it before me replaced the oil pan with one from 75+ that requires a thick seal (OS34510).
Found this out the hardway!
I was replacing timing chain, water pumpt etc. but not the oil pan gasket since that had recently been done by previous owner so I never noticed the space in the front seal but was suprised at how easy I was able to work the seal in without droping the pan front. Drove truck around the block and she was bleedin like a stuck pig. Oil everywhere!
Live and learn!
SBC intake manifold gasket restrictor in center chamber ChevyBelly Drivetrain & Performance 4 25th-February-2009 03:32 PM
Intake Manifold Gasket Installation - Help leejoy Drivetrain & Performance 2 29th-October-2007 01:33 PM
1965 Nova Rear Glass Install...Somethings Wrong!!! chevy65supernova Body and Interior 6 24th-September-2007 11:55 PM
Trimming oil pan gasket DriveWFO Drivetrain & Performance 7 3rd-August-2006 11:39 PM
1967 Windshield Gasket Frank B Body and Interior 8 17th-July-2006 09:49 PM
