Inline 6 Camshaft removal....!! - Chevy Nova Forum
Old 24th-January-2009, 07:26 PM   #1
64NovaWarrior
(OP)
64NovaWarrior's Avatar
Nova(s): 64 Longroof
Just bought a 250 I6 and I'm in the disassembly process. I seem to be missing the boat on removing the camshaft. Does it need some persuasion in order to slide it out smoothly or should it slide out with little effort. I haven't attempted the persuasion method yet, but I'm getting close!
Thanks in advance.....
.....Confucius say: 'mrs confucius mad tonight, couch is mans best friend!'
Old 24th-January-2009, 07:30 PM   #2
batman09
batman09's Avatar
Nova(s): 1967 LS3 & 1962 LSX wagon
Garage
should slide right out.did you remove the lifters and the fuel pump?bm
1962 Nova wagon-----Lsx/4L60e
1967 Nova---LS3/4L70e
Old 24th-January-2009, 07:33 PM   #3
veno
veno's Avatar
Nova(s): 72 385, t350, 3.73 4w-dsk
Garage
and distributor!
a nation of free men, shall live forever, or die by suicide
Old 24th-January-2009, 07:34 PM   #4
batman09
batman09's Avatar
Garage
Originally Posted by veno View Post
and distributor!
yepthat toobm
Old 24th-January-2009, 07:56 PM   #5
64NovaWarrior
(OP)
It's basically a bare block, except for the lifters. As soon as I remove the camshaft I can softly push out the lifters. I won't be using the camshaft since I'm rebuilding everything with new parts.
Looks like I need to use a little "Tim Allen" persuasion?
Old 24th-January-2009, 08:21 PM   #6
veno
veno's Avatar
Garage
I have never rebiult a l6.. but the two bolts over the distributor gear.. is there a meshing gear there? seem like there should be as L6 distributors only have a spade connector... and it must have a corresponding gear to drive the distributor....
have you removed the gear drive for the distributor?
Looks like its still in place....
Old 24th-January-2009, 08:38 PM   #7
64NovaWarrior
(OP)
I'll check it out in the morn...the two bolts you see bolted down the oil pump assembly. I just loosely threaded them back in....
Thanks, Veno...!!
Old 24th-January-2009, 09:46 PM   #8
Paul Wright
Paul Wright's Avatar
How about removing the lifters BEFORE trying to remove the camshaft.
Originally Posted by Paul Wright
Building a small, high rpm engine
with the perfect bore, stroke and rod ratio is very impressive...
like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar.
Cubic inches is like Indiana Jones with a cheap pistol.
Old 24th-January-2009, 10:35 PM   #9
SlickVic107
SlickVic107's Avatar
Nova(s): 72 Nova 355 9.91@134
I was thinking the same thing!
Parts listed in For Sale/Misc section!
87 Cavalier, 383 9.27@142
Old 24th-January-2009, 10:42 PM   #10
72GreenRally
72GreenRally's Avatar
Nova(s): '72 Green Rally Nova
There is a retaining plate behind the cam gear that has to be removed. There should be access holes in the cam gear to take the 2 bolts out. Then it should slide right out.
Are you pondering what I'm pondering?
Old 24th-January-2009, 11:24 PM   #11
vegas mike
vegas mike's Avatar
Nova(s): 1974 custom
yup
make sure the lifters are pulled out all the way or at least most of the way.
there are 2 holes in the cam gear to allow you to remove two phillips head bolts (i think they were phillips???) after all that i gave it a light tap with a rubber mallet just to loosen up everything.
might not have needed it, but i like to hit things with hammers.
Old 24th-January-2009, 11:32 PM   #12
sgtsteve
sgtsteve's Avatar
Nova(s): 66 Chevy II 4 Dr 72 Chev
No wonder you needed another harmonic balancer....j/k
Navy/Army National Guard/Navy Reserve RETIRED with 22 years.
Old 25th-January-2009, 10:27 AM   #13
64NovaWarrior
(OP)
Wellllll.....the lifters weren't the issue, the retaining screws in the cam plate were! They were covered with sludge, and yup they are phillips head screws! Why in the world would they use phillip head screws and not a small hex bolt, 3/8 or 7/16, I'll never know! One came out with ease and looks like I'll have to drill out the other one since I kinda strip out the phillips head....dam it!
Thanks, guys......
Old 25th-January-2009, 01:36 PM   #14
vegas mike
vegas mike's Avatar
no that's cause the guy that put it in used a bigger non rubber hammer.
Flat Tappet Warning! Lack of Zddp and modern oils veno Drivetrain & Performance 470 7th-March-2017 07:38 AM
very sweet inline 6 for those interested Richardlss Drivetrain & Performance 8 8th-October-2008 11:56 PM
Comp Cams -8 Series Roller Cams - Help leejoy Drivetrain & Performance 20 23rd-January-2008 05:56 PM
big block papa Drivetrain & Performance 16 30th-September-2007 08:43 AM
Inline 6 Engine Removal Rodzilla 1st & 2nd Generation Chevy II/Nova's 3 21st-July-2006 04:52 PM
