Rear disc conversion - Chevy Nova Forum
Old 4th-January-2009, 05:04 AM   #1
Eddie Wilson
(OP)
Title: Nova Newbie
Who has the best deal on rear disc brake conversion kit for the GM 10 bolt?
I do not want the E brake stuff and plan on keeping the C-clip axles.
I seen a couple kits on Ebay that look like nice kits, but im skeptical about such deals.
thanks
eww
Old 4th-January-2009, 05:17 AM   #2
Nova 404
Nova 404's Avatar
Title: Supporting Vendor
Nova(s): 1967 Nova SS
You should be able to use late Camaro/Trans Am rear discs.
Member of the NorCal Brotherhood!
Old 4th-January-2009, 06:39 AM   #3
hatehonda
Nova(s): 1967
You can pick up rear caliper mounting brackets off of ebay for around $70-$100 and buy the rest of the parts a local parts store. The guys selling the brackets can let you know exactly what components to piece together. They typically use front calipers/pads off of early 80s GM cars and rear rotors off of like an early 80s Trans Am.
Old 4th-January-2009, 04:33 PM   #4
63chevyll
63chevyll's Avatar
Nova(s): 632dr, 66wagon
thats what i did,
i used the 80 TA brackets, rotots, and calipers
Back in Nova mode again
Old 4th-January-2009, 08:11 PM   #5
TomM
TomM's Avatar
Nova(s): 1966 - Coupe
Garage
thanks
eww
Eddie, email me at tmunsch@verizon.net, site will not let me send PM....
T,
Old 4th-January-2009, 08:22 PM   #6
Eddie Wilson
(OP)
Title: Nova Newbie
Tom
Got cha......thanks
Old 5th-January-2009, 07:02 AM   #7
67pete
67pete's Avatar
Nova(s): 67 LS1/T56 Coupe
63CHEVYII, how did you get your e-brake to work ?
pete z
If everything is coming your way, then you're in the wrong lane!
'67 coupe, Heidt's, LS1/T56 and still adding....
Old 5th-January-2009, 11:44 AM   #8
TomM
TomM's Avatar
Garage
Use an 85 Cadillac Seville. Same brake pad and everything...uses stock Nova e-brake cable also.....
T,
Old 10th-January-2009, 11:11 PM   #9
63chevyll
63chevyll's Avatar
i didnt, i have a habit of no ebrake with automatic
Old 11th-January-2009, 12:04 AM   #10
Tarantula
Tarantula's Avatar
Nova(s): 1974 "454" Nova Custom
T,
1985 Cadillac Seville is the only year that I can use for rear disk brakes? (for this particular model)
Steve
Old 11th-January-2009, 10:11 AM   #11
TomM
TomM's Avatar
Garage
No, that is just for one with e-brake, you can use any early model GM, I believe. Mine had 69 camaro front calipers on the rear, but I wanted ebrake, so did the Seville....
T,
Disc brake conversion for 63?? Rock 1st & 2nd Generation Chevy II/Nova's 45 2nd-June-2008 08:28 PM
disc conversion will these fit? tdbutler Steering, Suspension, and Chassis 2 18th-May-2008 01:58 PM
disc brake conversion hckeyplayer74 Steering, Suspension, and Chassis 1 26th-November-2007 11:22 AM
63 Rear End Conversion bowtie Steering, Suspension, and Chassis 8 30th-September-2007 09:49 AM
Rear drum to disc conversion ZNova Steering, Suspension, and Chassis 7 23rd-April-2007 03:56 PM
