2" Lowering Blocks or 2" Lowered Leafs - Chevy Nova Forum
Old 25th-December-2008, 05:43 PM   #1
62civa
(OP)
62civa's Avatar
Nova(s): 62 Coupe
Right now, my car is mocked up with 2" lowering blocks in the rear. Up front I have a Heidts clip with coil overs. The car is sitting pretty close to where I want it in the back, but with the 2" lowering blocks, there is not a lot of space between the lower shock mounting plate and the ground. I am leaning towards putting on a set of Caltracs, but they hang down at least another 2" or 3" below the shock mounting plate. Has anyone here at SNS used leafs that are 2" lower than stock? Who sells them? and what other pros and cons should I be thinking about when deciding between usning 2" blocks or a set of 2" lowering leaf springs?
Ron
My 62:
Old 25th-December-2008, 06:29 PM   #2
Sooner1
Sooner1's Avatar
Ron
caltrac sells a -2.5 inch split mono leaf vto lower your car. johnh with a blue 73 bb nova has them.
you seem to have the cheapest way to go for now unless you are willing to spend a little money. i thought i could just use the leafs- but it turned out that i needed the caltrac bars to mount the shocks as well.
'66 and '67 Hard Tops
Hot Rod Drag Week 2015 Champ
'72 Nova:Twin turbo LS DW 2017 Project
Old 25th-December-2008, 07:27 PM   #3
Nova 404
Nova 404's Avatar
Title: Supporting Vendor
Nova(s): 1967 Nova SS
If you decide to use lowering blocks make sure the traction bars you choose will not be lower than the lip of the wheel.NHRA rules state nothing can hang below the lip of the wheel.Reason is in in the event of a flat tire the traction bar will hit the ground before the wheel possibly causing loss of control.I removed my lowering blocks and used dropped split monos to achieve the same height.
Member of the NorCal Brotherhood!
Old 26th-December-2008, 01:24 AM   #4
62civa
(OP)
62civa's Avatar
Nova(s): 62 Coupe
Thanks for the answers guys. I'll measure to see how low the Caltracs will sit in relation to the bottom of the wheel. Does anyone know if the lowered leafs start off as the same length as standard leafs or do they start off as shorter springs. In other words, if you measured around the length of the spring, from eye to eye do they measure the same or do the de-arched ones measure longer? Will the shackels (in my case, sliders) be located any differently? If I had my current springs de-arched, the distance between the spring eyes would increase right? I have already located and welded in my sliders and I do not want to have to move them further back.
Ron
My 62:
Old 27th-December-2008, 11:53 AM   #5
weebetruckin
weebetruckin's Avatar
Nova(s): 70 Nova 63 Wagon (sold)
Having been looking for 2" lowering blocks but having trouble locating anyone that carries them. Any suggestion?
Duane
Old 27th-December-2008, 12:20 PM   #6
Sooner1
Sooner1's Avatar
Ron
id call calvert - they are fairly good at answering these questions.
regarding what you asked about the springs:
in theory, LOWERED calvert split mono would have less of an arch but the same length- so they can still fit the stock mounts/shackles.
quick question:
are your existing springs- stock- if so, im wondering just how much sag they have in them?
before the split monos- i loved my cars stance- so i bought calvert -1's thinking they were lower than stock springs. they ended up being 2inches higher- so i put ~1inch lowering block on it.
it still sits ~1/2 inch higher than id like it- but im pleased overall.
my point being- you may not need -2.5 springs if your springs are already sagging a lot now.
i plan to put my moroso trick springs on tomorrow- if so, i will post a pic of its stance.
steve
Old 27th-December-2008, 03:56 PM   #7
ioldsnut
ioldsnut's Avatar
Nova(s): 68' SS LT1 w/ T56
Hey Weebe.... I got mine at Advance Auto Parts and I think any AutoZone has them too...
Old 27th-December-2008, 05:58 PM   #8
62civa
(OP)
62civa's Avatar
Nova(s): 62 Coupe
My springs are stock replacement monos from Calssic industies. They have been on the car for about 2 years. I don't think they have sagged any, other than the normal settling With the 2" lowering blocks, I like the rear ride height. I have 2" dropped spindels up front on a Heidts clip with coil overs. Overall I want the car to sit pretty low. I'm working on the rear end today. Once its back in the car, I'll make some measurements to see how far the traction bars will hang down. I'll call Calvert racing on Monday.
Ron
My 62:
Old 27th-December-2008, 06:22 PM   #9
Sooner1
Sooner1's Avatar
Ron
edit:
can you post a couple pics the back and side of your car?
are you planning to race it?
if not, you might not really benefit from the split monos- just good rear shocks
+/- the caltrac bars.
some people have issues with the front of the caltrac scraping- but caltrac has tried to remedy this with a low profile piece- basically just removed the bottom hole off the mount.
not uncommon for people to have ~2-3 inches from the ground.
i will try to measure mine tomorrow.
steve
Old 27th-December-2008, 07:25 PM   #10
Raymond
Raymond's Avatar
Nova(s): 1964 SS (sold)
If you're interested there is a member who is selling Landrum leafs for $75 + shipping..................they will lower the car! Look in the for sale section. Roger Bentley 734 699 9196...........call him.
Ray
Old 27th-December-2008, 07:59 PM   #11
62civa
(OP)
62civa's Avatar
Nova(s): 62 Coupe
Thanks Ray. I sent him a PM asking about the springs specs.
Ron
My 62:
Old 27th-December-2008, 11:33 PM   #12
weebetruckin
Do they include the extended U-bolts? I will try and call tomorrow.
Duane
Old 27th-December-2008, 11:37 PM   #13
ioldsnut
ioldsnut's Avatar
Yeah Weebee... long "U" bolts, everything you need... If I remember,, I think they were only around 30 or 40 bucks...
Old 28th-December-2008, 12:20 AM   #14
ddoyel
ddoyel's Avatar
Nova(s): Son's "72" ex 6 now v8, 7
Do you have any pics of yours installed? What size wheels are you running?
When people fear govt, there is tyranny; when govt fears people, there is liberty.
T Jefferson
Old 28th-December-2008, 12:05 PM   #15
weebetruckin
I would like to install 225/40 tires with 18" x 7" rims do think I will have a clearance problem with the lowering blocks installed?
Duane
Last edited by weebetruckin; 28th-December-2008 at 12:06 PM. Reason: added to the post
2" rear lowering block for a 63? Irie Steering, Suspension, and Chassis 22 14th-April-2015 03:38 AM
2" lowering springs or 2" lowering spindle sal0327 Steering, Suspension, and Chassis 1 15th-July-2008 04:54 AM
Lowering Blocks Again But A Little Different JRD Steering, Suspension, and Chassis 1 23rd-March-2008 07:30 PM
Lowering blocks on a 66-67 Jimmac Steering, Suspension, and Chassis 6 18th-July-2006 02:03 AM
Lowering Blocks and Traction Devices Scooter Steering, Suspension, and Chassis 16 27th-April-2006 01:01 PM
