Kansas City MO and surrounding areas.....good speed shops? - Chevy Nova Forum
Go Back   Chevy Nova Forum > Regional Chevy II/Nova Enthusiasts > Mid Western US
Old 29th-November-2008, 12:33 PM   #1
Dawg
(OP)
Dawg's Avatar
Nova(s): 1969 Nova
I'm still a newbie to MO. I'm looking for any good automotive speed shops around the KC/Lee's Summit/Independence MO areas. Does anyone know of one? Thanks.
If he is still there; he did the work on my engine. When I picked up my engine mine was the only GM block he was working on. The rest were Dart Big and Small M blocks. He had over a dozen high dollar engines going together in his shop.
Maschmeier Perf Engineering
2850 D West 40 Hwy
Blue Springs, MO 64015
816-682-6946
There used to be MO-PO Performance out in front of his shop I think they are closed now. They own the building Maschmeier Perf Engineering is in. They were a couple of older guys that had a small shop.
There is a street rod shop on father up Hwy 40; they sold a few things. Not much of an inventory.
Where your at Summit and Jegs are your best friends.
69 Nova Dart SHP 400 V8 engine, Autogear M23Z 4 speed transmission, 3.55 rear, tons of smiles per gallon
Last edited by taz3; 29th-November-2008 at 01:27 PM. Reason: Moved to more appropriate area
Old 29th-November-2008, 01:55 PM   #2
Dawg
(OP)
Dawg's Avatar
Nova(s): 1969 Nova
Hey I'm really just looking for a shop locally that sells AN fittings to install a fuel pressure gauge.
I know Summit carries them but I wanted to get them today so I could finish up this install. Also Summit charges like a $10 handling fee regardless of how big or small of an item you get. That's why I like to save up and then get a bunch of stuff from there at once.
Now if I could only find a good speed shop around the KC area....
Old 29th-November-2008, 02:15 PM   #3
Racinfan83
Racinfan83's Avatar
Nova(s): Had a Nova, now '90 ZR-1
Try this: http://www.google.com/search?hl=en&r...ty&btnG=Search
'71 SS Nova
Used to be mine - now with another Nova lover!!
Old 29th-November-2008, 03:06 PM   #4
Pragmatist
Pragmatist's Avatar
Garage
Hey racing fan, I think he was hoping you could drive him there.
66 & 67 hard top,
My 1980 avatar pic.
Old 29th-November-2008, 04:17 PM   #5
Racinfan83
Racinfan83's Avatar
WELL.....since I'm on the far side of the state - and at work to boot - I figured I'd introduce him to the world of Google..
'71 SS Nova
Old 29th-November-2008, 09:47 PM   #6
Beck1966hdtp
Tompkins over off Front street has some an fittings and Bills performance on north oak trafficway and 72nd street
Old 29th-November-2008, 11:44 PM   #7
Dawg
(OP)
Dawg's Avatar
Nova(s): 1969 Nova
Tried google before I posted and didn't find what I was looking for.
Old 30th-November-2008, 09:46 AM   #8
Racinfan83
Racinfan83's Avatar
Sometimes you have to play around with the wording to get what you want on Google. I hope my link helped you out
'71 SS Nova
Old 30th-November-2008, 12:07 PM   #9
Jake
Jake's Avatar
Watcha need? I keep some inventory but can have anything else same day or next. I am in Lees Summit, MO
Jakes Performance Fabrication
1216-C SE Broadway, Less Summit, MO 64081
816-686-5133
Old 30th-November-2008, 02:55 PM   #10
Dawg
(OP)
Dawg's Avatar
Nova(s): 1969 Nova
Well, I am trying to install an electric fuel pressure sender to the end of a fuel injection rail.
The rail has a 4 AN style fitting with a schrader valve in it.
I need an adapter to convert the 4 AN over to a 1/8 NPT fitting.
Old 30th-November-2008, 10:38 PM   #11
Jake
Jake's Avatar
I may have what you need. Which part of your fitting is male and female? And what configuration do you need the fitting to be?
Old 30th-November-2008, 11:03 PM   #12
Dawg
(OP)
Dawg's Avatar
Nova(s): 1969 Nova
The rail and the sensor both have male fittings.
Therefore what would work the best for me would be a 4 AN female swivel to 4 AN male with a 1/8 NPT port tapped for a pressure gauge.
Even better if the 4 AN male side is tapped/threaded inside to accept a schrader valve.
If not that, a 4 AN female swivel to 4 AN male would work, I can get a 1/8 NPT female/female coupler to make work.
Old 1st-December-2008, 12:12 AM   #13
Jake
Jake's Avatar
Unless I am catching what you want wrong, I take it you want to run your gauge and schrader out of your rail? Would something like this work if we tapped the port off to the side for 1/8 npt? http://www.godmanhiperformance.com/i...product_id=938
I may be able to better put something together if I saw the pieces.
I also found a 90degree swivel fitting on -4 with a gauge port at another place.
Old 1st-December-2008, 01:08 AM   #14
Dawg
(OP)
Dawg's Avatar
Nova(s): 1969 Nova
No....already have one of those.....
This would work:
Or maybe this:
Old 1st-December-2008, 01:38 AM   #15
Dawg
(OP)
Dawg's Avatar
Nova(s): 1969 Nova
I decided to take some pics to help get a better understanding of what I'm doing.
First off, this isn't a Chevy engine....it's a Buick engine.....a V6 turbo....as you would find in a Grand National:
It's also a fuel injected engine. Here's a close up of the end of the fuel rail where the male 4 AN fitting is next to the black cylinder fuel pressure regulator)....
An even further close up...
And an even further close up...notice how there's a schrader valve inside....
Now here's what I am trying to do...is hook up this Autometer fuel pressure sensor to the male 4 AN fitting at the end of my fuel rail:
I have this tee fitting, which is kind of cheaply made IMO (look at how thin that little tube is between the L and the female that threads on the end of the fuel rail).....
And I want to do this:
So if I were to use the tee fitting I'd need a female 4 AN to male 1/8 NPT adapter like one of these:
And then in conjunction with it, I'd use a dual female 1/8 NPT coupler such as this one:
But if at all possible, one of the fittings I posted above in the previous thread would also work.
The nice thing about the brass tee I have is it has the schrader valve inside like the fuel rail:
