Old 24th-October-2008, 09:32 PM   #1
73TurboNova
73TurboNova's Avatar
Replacing TH350 with a TH400..will it bolt in 73?
I am replacing a TH350 with a TH400. As long as I get a short tail housing, will it bolt in other than replacing the transmission yoke? Is the length the same? I am mainly wondering if I can use the stock driveshaft.
Old 24th-October-2008, 11:09 PM   #2
tvnl
tvnl's Avatar
Nova(s): 63 SS
Nope it's longer.
-Todd-
63 in early stages of a Pro Street car. Buildup
Old 25th-October-2008, 12:37 AM   #3
73TurboNova
Originally Posted by tvnl View Post
Nope it's longer.
Doh! I guess the fact that I got one with a 9" tail housing doesnt matter then, its a custom driveshaft either way. Hopefully Dennys has fast turn around, I'll give them a call on Monday. Might as well upgrade to 1350 ujoints too. Thanks
Old 25th-October-2008, 02:13 AM   #4
1quik69
1quik69's Avatar
Title: Moderator
Nova(s): 1969w/468,1972w/408,
You'll need the TH400 crossmember,Th400 yoke and a different length driveshaft.
Old 25th-October-2008, 03:14 AM   #5
firebird69racer
firebird69racer's Avatar
Make sure you get the right O.D. yoke to go with the tail housing seal and bushing. There are two different sizes.
Old 25th-October-2008, 09:15 AM   #6
tvnl
tvnl's Avatar
Nova(s): 63 SS
I've never run across that, if so i would think it would be the bolt on yoke that would be bigger cause that's what they used in the big trucks.
-Todd-
Old 25th-October-2008, 01:33 PM   #7
balljoint
balljoint's Avatar
Title: Nova Newbie
Nova(s): 1978 chevy nova
Why do feel the need for a turbo 400,your 350 can be built as strong as you want ,and is lighter.
Old 25th-October-2008, 05:11 PM   #8
73TurboNova
If I dont mount the motor offset, can I just scoot the crossmember back and drill new holes in the frame, or is the TH400 mount a different height too?
The reason I am going with a th400 is I am putting a single turbo 454 in the car so it needs to support alot of power.
Thanks for the help.
Old 25th-October-2008, 05:46 PM   #9
1quik69
1quik69's Avatar
Title: Moderator
I'm not sure if the mounting height is different but the TH400 crossmember is completely different from the TH350 crossmember. The TH400 member will bolt right to the factory frame holes. Run a search on e-bay or google and you will see what I mean. The aftermarket catalogs will probably show them also.(Classic, year one etc)
Old 3rd-November-2009, 04:21 PM   #10
Tony Silva
Tony Silva's Avatar
Title: Nova Newbie
Nova(s): 1972 NOVA-454
you guys answered my questions, lots of knowledge all over this site
Old 3rd-November-2009, 05:33 PM   #11
Dutch
Dutch's Avatar
Nova(s): 1971 SS/1974 Nova Custom
I agree here, cant think of much a 350 cant handle. With everything that you will need to convert to a 400 why not just put that money into building a stronger 350??
"Street Legal, who's really looking?"
Old 3rd-November-2009, 05:47 PM   #12
73TurboNova
Its cheaper to build a TH400 to take 800hp than a TH350 or Powerglide.
I got the TH400 in last month. I bought a new crossmember from Ebay (thanks China) and reused my stock driveshaft, all I had to do was change the transmission yoke, the length was fine. The short TH400 is about an inch longer than the TH350 so there was enough room. Im going to convert to 1350 ujoints and get a new driveshaft anyway but it was nice to get it up and running right away with the stock shaft.
1973 Nova turbo 454
Old 3rd-November-2009, 06:47 PM   #13
Dutch
Dutch's Avatar
For the u-joints have you heard of CTM? I have heard good things but wondered if you had seen or heard of them, might be a good choice for your set-up.
Old 3rd-November-2009, 07:45 PM   #14
photoman
photoman's Avatar
Be sure to use a driveshaft loop. You're going to need it putting 800hp to a stock driveshaft (assuming you get some traction).
1969 Nova
350
TH400
8.5" Ten Bolt 3.42 Posi-traction
Replacing TH350 with 700r4 - questions 63-Hardtop Drivetrain & Performance 16 27th-October-2008 11:19 PM
the th350 vs the th400 Evans71 Drivetrain & Performance 12 14th-August-2008 01:56 PM
Rearends ChevyIINova Drivetrain & Performance 8 8th-September-2007 08:56 PM
350 4 bolt/ TH350 nogo69 Drivetrain & Performance 1 2nd-July-2007 10:57 PM
