Lunati Voodoo cams & valvetrain noise? - Chevy Nova Forum
Old 15th-October-2008, 01:45 PM   #1
Nacho
Nacho's Avatar
Nova(s): 1971 Nova
Garage
Looking for some feedback on this cam! I currently running a comp cam and I get to much valvetrain noise. Lunati cams claim slower closing cam lobes sides to reduce noise but I want some proof! Also what is a good oil to use for Hydraulic flat tappet cams?
Brand: Lunati
Product Line: Lunati Voodoo Cam and Lifter Kits
Part Type: Camshaft and Lifter Kits
Part Number: LUN-60103LK
Cam Style: Hydraulic flat tappet
Basic Operating RPM Range: 1,800-6,200
Intake Duration at 050 inch Lift: 227
Exhaust Duration at 050 inch Lift: 233
Duration at 050 inch Lift: 227 int./233 exh.
Advertised Intake Duration: 268
Advertised Exhaust Duration: 276
Advertised Duration: 268 int./276 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.489 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.504 in.
Valve Lift with Factory Rocker Arm Ratio: 0.489 int./0.504 exh. lift
Lobe Separation (degrees): 110
Intake Valve Lash: 0.000 in.
Exhaust Valve Lash: 0.000 in.
Computer Controlled Compatible: No
Lifters Included: Yes
Lifter Style: Hydraulic flat tappet
Valve Springs Included: No
Retainers Included: No
Locks Included: No
Valve Stem Seals Included: No
Timing Chain and Gears Included: No
Assembly Lubricant Included: No
Pushrods Included: No
Rocker Arms Included: No
Gaskets Included: No
Quantity: Sold as a kit.
Old 15th-October-2008, 02:41 PM   #2
tvnl
tvnl's Avatar
Nova(s): 63 SS
A flat tappet hyd should not make noise, check your valve adjustment.... And Valvoline VR1 is what I use.
-Todd-
63 SS in intermediate stages of a Pro Street car.
Old 15th-October-2008, 02:47 PM   #3
danthegeek
danthegeek's Avatar
Nova(s): Red 71
I have a comp xe268 in my 350. Its as quite as a mouse. Todd is right, something has to be adjusted incorrectly or something is hitting. You sure its not header gaskets?
-dan
Ps- Mine made a horrible noise when I did the break-in. Turns out the rockers were hitting the valve covers. You may want to check that as well.
71 Nova
"Freakin Hybrids man. They just dont do the trick anymore..."
Old 15th-October-2008, 03:42 PM   #4
Nacho
Nacho's Avatar
Nova(s): 1971 Nova
Garage
I just replaced the header gaskets all four. I have adjusted the valves several times but the noise comes back! I first started with roller rockers then I switched to summit steel non roller and what has finaly helped is Original GM stock rockers but it only reduced the noise its still there.
Old 15th-October-2008, 05:16 PM   #5
chuckha62
chuckha62's Avatar
Nova(s): '63 SS (gone!) '67 Goat
I have the Lunati 60102 and I have no noticable valve/lifter noise
When the only tool in your box is a hammer, you tend to see every problem as a nail
Old 15th-October-2008, 05:55 PM   #6
chevyman18
chevyman18's Avatar
Nova(s): 70 Nova: "Snake Eater"
i'm running the 60103 in my 350. no valvetrain noise. cam runs pretty solid for a flat tappet cam, motor is rock solid!
70 Nova--->
ROAD HOUSE!
Old 15th-October-2008, 06:07 PM   #7
D-Man
D-Man's Avatar
How are you adjusting your valves?
How much pre-load?
Whose lifters are you using?
What heads?
Retainer to seal clearance?
Springs binding?
Pushrods binding?
Any shiny spots on the inside of your valve covers?
An unarmed man can only flee from evil, and evil is not overcome by fleeing from it.
Lt.Col. Jeff Cooper
Old 15th-October-2008, 09:49 PM   #8
95possom
95possom's Avatar
Nova(s): 63 hardtop
Im running the LUN-60104 and I like it. Just make sure your push rod lenght is right for whatever set-up you're using. You may have wore out lifters to? Just a thought. I have had some roller rockers that made a little noise, but you should be able to tell the difference from lifter noise. Here's a link to video. It was idle down to low as I just put the carb on. http://www.youtube.com/watch?v=4Y0YITzEQqM
Old 16th-October-2008, 01:22 AM   #9
Nacho
Nacho's Avatar
Nova(s): 1971 Nova
Garage
How much pre-load?
What heads?
Springs binding?
Pushrods binding?
I have tried both ways to adjust my valves. Pre-load i have tried 1/2 turn after zero lash and 3/4 turn. lifters are comp cams brand, heads are Camel Hump, retainer to seal I dont know, springs binding (No), Pushrods seem to ride the guide plates little and no shiny spots on valve covers
Old 16th-October-2008, 11:33 AM   #10
D-Man
D-Man's Avatar
Check your valvetrain setup up top. I don't know what springs you've got or at what installed height their setup at but it's a very common problem, especially with over .470" lift.
You can also check for interference between the rockers and retainers (doubtful but worth a gander), as well as interference with any oil baffles inside the valve covers.
As a last shot in the dark, did you use the clear di-electric grease inside your spark plug boots?
You get one of those arcing out it will sometimes make a very deceptive sounding "POP"..
Lt.Col. Jeff Cooper
Lunati Voodoo 1977stroked Drivetrain & Performance 11 8th-September-2008 05:50 AM
Valvetrain Noise doczapp Drag Racing Forum 10 29th-April-2008 03:45 PM
327 Valvetrain noise when warm... surfdog Drivetrain & Performance 0 31st-May-2007 06:39 PM
Valvetrain noise question... JTW Drivetrain & Performance 22 19th-August-2006 12:38 PM
Voodoo Cams 1963DUCE100 Drivetrain & Performance 19 9th-August-2006 12:54 AM
