Bell housing bolt removal - Chevy Nova Forum
Old 5th-October-2008, 03:07 AM   #1
chevythunder35
(OP)
Title: Nova Newbie
Can ya tell me the easiest way to get the top two bolts on top of the trans out
Old 5th-October-2008, 03:13 AM   #2
burty
burty's Avatar
Nova(s): Ain't got no posts!
Garage
I have found that standing on drivers side of car using your LEFT hand palm towards motor take out the passenger side bolt. Standing on passenger side of car use your RIGHT hand palm towards motor for the drivers side bolt. Of course I'm 6'5" tall so you maybe can't reach.
Two toughest bolts on the car as far as I'm concerned.
P.S. Put Free Bird and Stairway to Heaven on the boom box. By the time those two songs are over your done.....Burt.
Old 5th-October-2008, 03:58 AM   #3
fosheezie
fosheezie's Avatar
Nova(s): 1966 ss
if your removing the trans i usually just lower the trans just a little (after you remove the crossmember) and use a long extension and an impact wobble socket... just make sure you watch the clearance between your distributor and firewall when you are letting it down
and dont forget the southern rock music like he said... it has been scientifically proven by scientists that lynard skynard cuts removal time in half
Old 5th-October-2008, 04:29 AM   #4
Paul Wright
Paul Wright's Avatar
Yeah, when I worked at the Chevy dealer working flat rate that was the hot trick. A 3 foot 3/8 drive extension and a 9/16" impact wobble. Use the 3/8 drive since it's smaller and the impact wobble is less floppy than the chrome ones.
I had a small 3/8 drive Ingersol impact and the above set up and it wouldn't take more than a minute to get all the bolts out. I'd start at the top and work down. Take the lower ones out last because they are supported by the alignment pins. If you take the top ones out last, all the weight is hanging from those and you could break the case.
Remove the torque converter bolts and everything else first because it's coming out and you don't want to be removing things when that baby is loose.
Originally Posted by Paul Wright
Building a small, high rpm engine
with the perfect bore, stroke and rod ratio is very impressive...
like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar.
Cubic inches is like Indiana Jones with a cheap pistol.
Old 5th-October-2008, 05:47 AM   #5
jlowery78
Nova(s): 1969 454 BB Turbo 350
I always take them out or screw them in with the dizzy removed. It's a lot easier.
Old 5th-October-2008, 11:35 AM   #6
David_D.
David_D.'s Avatar
Nova(s): 1974 Nova Custom Hatchback, 1972 Nova
That's how I do it (well, used to until I installed the CSI Tranny shield). Now I have access holes in the firewall.
David_D.
74 Custom Hatchback
10.343@127.86
Horsepower Innovations E85 Carburetors
One more question about a bell housing vs scattershield jaytone 3rd Generation Chevy II/Nova's 4 22nd-December-2007 07:30 PM
New bolt in housing ends? MAZZ63II Drivetrain & Performance 6 2nd-September-2007 12:44 AM
Where to get a 12 bolt housing. Big Fran Drivetrain & Performance 13 6th-August-2007 11:38 AM
GM 10 Bolt 8.5" Housing Damage Question leejoy Drivetrain & Performance 6 7th-November-2006 03:06 PM
