Moving Leaf spring mounts - Chevy Nova Forum
Old 15th-September-2008, 07:22 PM   #1
justsomeguy
Has anybody moved the front and rear leaf spring mounts inward to make room for a wider tire on a 67.
Could you do this, narrow the rearend, and widen the inner wheel well?
Next question, would I want to?
I have a 67 that is rusted out badly. It was a freebie and if I want to do somethig with it I will have to replace the back 12" of the rear frame rails, trunk floor and body shell floor along with almost everything else.
I could alway back half it but I have already done that to one of my third gen. Novas and would like to do something different. I hate doing the same thing twice if there are other options.
I tried to post some pics but nothig happened, Give me some pointers on posting pics and I will show you the RRRRUUUUSSSSTTTT.
Last edited by justsomeguy; 16th-September-2008 at 10:10 PM. Reason: Clarification
Old 15th-September-2008, 11:02 PM   #2
deuces2
deuces2's Avatar
Nova(s): Dozen +,1st and 2nd gen
Garage
You can move the leaf springs inboard,the ezest way is with the frame connectors move the front mount over one leaf spring width and Jegs and Summit makes a bracket to move the rear leaf inboard the spring width....you will gain room for a little wider tire butt the gas-tank or the stock wheel tubs will just not fit a very wide tire
Old 16th-September-2008, 10:04 PM   #3
justsomeguy
If I were to widen the wheel wells and narrow the fuel tank and rearend, How close together can you put leaf springs and have them still do there job correctly.
Old 17th-September-2008, 12:37 AM   #4
EVILS 65
EVILS 65's Avatar
Nova(s): 1965, 385, th400, 4.10
if you get the competition engineering weld in sub-frame connectors and their frame rails you can move them in 8" per side. stock gas tank wont fit.
6.432@105 w100 shot N2O/ on pump gas
Leaf Spring Question 450HP Steering, Suspension, and Chassis 8 12th-January-2008 10:35 AM
leaf spring question chevy72nova 3rd Generation Chevy II/Nova's 6 12th-November-2007 09:24 PM
Leaf Spring Mounts Reno Steering, Suspension, and Chassis 3 20th-May-2007 01:29 PM
ahhhhhhhh. leaf spring havoc. need advice '74hatchback Steering, Suspension, and Chassis 0 21st-June-2006 12:00 AM
