How do you remove the ignition switch on a 63 - Chevy Nova Forum
Go Back   Chevy Nova Forum > Non-Technical > 1st & 2nd Generation Chevy II/Nova's
Old 5th-September-2008, 11:22 AM   #1
gofast250
(OP)
Title: Nova Newbie
Nova(s): 1963 ss convertible,resto
Actualy The ignition switch is on a 62 nova ,That i was stripping ,But could not figure how to get the switch off the dash .
I know the bezel unscrews ,But wont go past the ears of the switch .
I belive you put a pin type device in the little hole on the face of the switch and it would come apart, Just can not seem to be able to figure it out .
any help Would be great .
Thanks ,
Mike
Old 5th-September-2008, 11:26 AM   #2
1963NovaSS
Nova(s): 1963 SS
use a paper clip to put in the little hole. Theres a spring loaded button of sorts, you'll feel it. Then the lock cylinder will come out, then you unscrew the ignition bezel. It's easiest to un screw with the proper tool, Classic & others sell it. Good luck.
Tim
Old 5th-September-2008, 01:22 PM   #3
65Nova4door
65Nova4door's Avatar
Nova(s): 1963 hardtop 1965 4door(
hopefully you have an easier time than I did:
http://www.stevesnovasite.com/forums...672#post796672
Where are you in California?
Old 5th-September-2008, 02:18 PM   #4
gofast250
(OP)
Title: Nova Newbie
ignition switch removal
I will give that a try .
I am located in Santa Maria.
Old 5th-September-2008, 02:25 PM   #5
gofast250
(OP)
Title: Nova Newbie
does the ears on the bezel need to be position at a certain point to inset the paperclip.
Old 5th-September-2008, 03:20 PM   #6
undercvrSS
undercvrSS's Avatar
Nova(s): 67 SS 67 Sedan project
you need the key, and it needs to be turned to the accessory position.
Old 5th-September-2008, 03:33 PM   #7
veno
veno's Avatar
Nova(s): 72 385, t350, 3.73 4w-dsk
Garage
what he said...
insert the key, turn to acc. insert paper clip, pull on key.. key and tumbler will come straight out...
BUT you HAVE to have the KEY.. else... get a cut off wheel, die gringer, carbide burrs, drill, beer, playboy for a break, a couple of replacement bits for the ones you break... and have at the lock face.....
Old 5th-September-2008, 06:08 PM   #8
gofast250
(OP)
Title: Nova Newbie
My ignition has ,Lock,off,on ,start.
When you say acc postion do you me lock ,Because i can not get it to go to lock with the key or without,Maybe i do not have the correct keys fro this car.
Old 5th-September-2008, 06:16 PM   #9
veno
veno's Avatar
Garage
does the key turn the lock? if so your in good shape..... Now I dont remember.. that far back... try each position but lock... I would bet its the on position... when you find the right position you will feel spring pressure when you insert the paper clip.... Inset the paper clip and slowly turn the key from the lock position to the point where you feel the paper clip give...
when you feel the spring.. you have the correct position... now its time to start your journey....
Old 5th-September-2008, 11:09 PM   #10
63CHVII
63CHVII's Avatar
Nova(s): None
63s only had the lock mechanism. Once you're past that you don't need a key to start the car. I very rarely use my key at all but since it does fit in the assembly it's a good place to keep it until I get to a show and actually need the key to open the trunk.
Jeff
USN 1985-2005
1965 Chevy II 4 door (Laverne)GONE
1963 Chevy II 300 (Shirley)GONE
Old 6th-September-2008, 01:50 AM   #11
brewwagon
brewwagon's Avatar
Nova(s): 65 acadian canso sd 2drht
this thread should be moved to electrical
it will get buried here in bs lol
someone else will be looking for the info and surely it helps out
brewws
what the hell is in that thing?
can't remove ignition switch and bezel 65Nova4door Body and Interior 37 23rd-September-2016 03:06 AM
Ignition switch grief Lgian Originality 14 5th-March-2008 12:57 PM
63 ignition switch question Tubbed63 Electrical 7 4th-August-2007 12:52 AM
How To Remove The Cylinder From Ignition Switch MR G Electrical 5 14th-January-2007 08:17 PM
Ignition switch install caseydp75 Electrical 7 24th-July-2006 01:32 AM
