COMP Cams 12-564-4 anyone have or use this cam? - Chevy Nova Forum
Go Back   Chevy Nova Forum > General > Drag Racing Forum
Old 17th-August-2008, 02:43 AM   #1
bigdaddykane
Nova(s): 3rd gen Nova's
Hey everyone, does anyone have or is using this hydrualic flat tappet camshaft for a small block? or know anyone who is using it? its part number COMP Cams 12-564-4 and the specs are 230 int./244 exh. @.050 duration and 0.487 int./0.501 exh. lift with a 113 lobe separation
I'd like to find out what it sounds like before i get one. please let me know
thanks much
Old 17th-August-2008, 10:59 AM   #2
tvnl
tvnl's Avatar
Nova(s): 63 SS
Looks like a nitrous cam?
-Todd-
63 SS in intermediate stages of a Pro Street car.
Old 17th-August-2008, 11:13 AM   #3
The Big Al
The Big Al's Avatar
Nova(s): 68ss, 70ss (SOLD)
You want a nasty sounding cam that makes power!
Pic here!
http://lunaticams.com/ProductGroup.aspx?id=245&cid=58
“The bitterness of poor quality & Service remains long after the sweetness of low price is forgotten”
Old 17th-August-2008, 07:53 PM   #4
Tiny in Ohio
Tiny in Ohio's Avatar
Nova(s): 71 Nova
Big Al,
I like the 300/515 cam from Lunati that you linked to. Do you think that would work with my combo?
355
9.5+:1 compression
461 castings with 2.02 / 1.60 valves
Weiand Stealth intake
750 carb (eddy or holley)
Thanks in advance.
Tiny
1971 Nova 461/T400, 8.5" 4.10s
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL ISSUE.
Old 17th-August-2008, 08:15 PM   #5
The Big Al
The Big Al's Avatar
Originally Posted by Tiny in Ohio View Post
Big Al,
355
9.5+:1 compression
Thanks in advance.
Tiny
If your heads and springs are set for that lift.
Go for it.
AL
Old 17th-August-2008, 09:24 PM   #6
63SSNOS
That Comp cam is a small nitrous cam, we ran it in a low compression 350 an sprayed 375hp to it. ran like the dickens on nitrous, but was a mild street mannered cam with a rumpety idle. Others will make better N/A power but won't have the mild manners this one got riding around, it'll idle as low as 700-800rpm an drive nice. I have a 286 magnum grind in my Stingray which is similar to the nitrous grind specs but the nitrous cam is much better off idle with no hesitation. My next teardown the nitrous grind will be in the Stingray motor for sure.
Old 17th-August-2008, 10:17 PM   #7
bigdaddykane
hey 63SSNOS , do you have a video of the idle that i can hear? appreciate any help, thanks so much
Old 17th-August-2008, 10:20 PM   #8
bigdaddykane
hey 63SSNOS ,
do you have a video of the car idling with that nitruos can i can hear? appreciate any help, thanks so much
Old 3rd-September-2008, 02:28 AM   #9
bigdaddykane
Smile
hey 63SSNOS ,
Old 3rd-September-2008, 03:39 AM   #10
1977stroked
1977stroked's Avatar
Nova(s): 77' Nova 383" stroker
This is the one Im going with http://lunaticams.com/Product.aspx?id=1781&gid=245
With a 750 holley, weiand stealth air strike, 3.42 gears, Hughes 2500 stall, and this cam should make a good combo.....thats what I will have by march next year......12s here I come....
1977 Nova 383 Stroker
60ft 1.73
1/8 7.94 @ 86.34
Old 3rd-September-2008, 03:49 AM   #11
bigdaddykane
Smile
hi
what are the specs on it? the link wont open for some reason.....
Old 3rd-September-2008, 03:53 AM   #12
1977stroked
Here you go.....Hydraulic, fair idle. Needs headers, gearing and stall converter. Good street/strip cam.
* Advertised Duration (Int/Exh): 300/300
* Duration @ .050 (Int/Exh): 246/246
* Gross Valve Lift (Int/Exh): .515/.515
* LSA/ICL: 108/104
* Valve Lash (Int/Exh): Hyd/Hyd
* RPM Range: 2500-6500
* Includes: Cam Only
60ft 1.73
1/8 7.94 @ 86.34
Old 3rd-September-2008, 02:50 PM   #13
D-Man
D-Man's Avatar
* LSA/ICL: 108/104
Why not this one?
http://lunaticams.com/Product.aspx?id=1986&gid=287
Hydraulic. This is possibly the most powerful hydraulic cam ever designed! Designed for Very Hot street/bracket race applications, this cam requires a minimum of 10.5:1 compression, 4.11 gearing and 3500 RPM stall converter. Works with up to 250HP nitrous, and pulls Very Hard past 6500 RPM.
* Advertised Duration (Int/Exh): 284/292
* Duration @ .050 (Int/Exh): 241/249
* Gross Valve Lift (Int/Exh): .525/.546
* LSA/ICL: 110/106
* RPM Range: 2500-6600
Part Number: 60105
An unarmed man can only flee from evil, and evil is not overcome by fleeing from it.
Lt.Col. Jeff Cooper
Old 3rd-September-2008, 02:53 PM   #14
1977stroked
Originally Posted by D-Man View Post
Why not this one?
* LSA/ICL: 110/106
Part Number: 60105
I dont have any of that.....otherwise I would, I actually do have 10.5 compression though......
60ft 1.73
1/8 7.94 @ 86.34
Old 3rd-September-2008, 03:10 PM   #15
D-Man
D-Man's Avatar
thanks much
You could also consider this one.
http://lunaticams.com/Product.aspx?id=1985&gid=287
Hydraulic. Hot Street cam, likes 2800 converter, Hi-Rise type dual plane intake with 750cfm carb, headers, 10:1 compression and 3.73 gears. Likes up to 200HP nitrous.
* Advertised Duration (Int/Exh): 276/284
* Duration @ .050 (Int/Exh): 233/241
* Gross Valve Lift (Int/Exh): .504/.525
* LSA/ICL: 110/106
* RPM Range: 2200-6400
Part Number: 60104
You've got to remember that the Comp and Bracket master lobes are well over 20 year old designs. The only way you're going to get any newer lobes is to contact Harold directly.
If you are looking to find the absolute BEST performance without all of the expense of going to a roller then I would strongly suggest looking at the solid flat tappet grinds. If your valve train is set up correctly then there is BARELY any more service required but the performance difference is HUGE!!! Especially over 4000 rpm which is generally where your entire trip down the track is going to be. For that I would urge you to call Harold Directly (662-562-4933) because there's a whole list of solid flat tappet cams he's designed that haven't even been listed or available to the public yet that he can (and WILL) get ground for you.
I just got one fresh off the Landis CNC a week or so ago (because the masters haven't even been made yet) and it LOOKS phenomenal!! You can actually SEE just how asymmetrical the lobes are!!
Lt.Col. Jeff Cooper
Who is running Comp Cams 270H? FNG Drivetrain & Performance 24 13th-August-2009 02:03 AM
comp cams 292H novapop Drivetrain & Performance 6 24th-March-2008 08:47 AM
Comp Cams -8 Series Roller Cams - Help leejoy Drivetrain & Performance 20 23rd-January-2008 06:56 PM
Redoing my engine this winter! 270win Drag Racing Forum 130 13th-August-2007 08:51 AM
Comp Cams 6100 belt drive install question AZNova Drivetrain & Performance 2 30th-October-2006 10:55 PM
