Camel hump heads - Chevy Nova Forum
Go Back   Chevy Nova Forum > General > Drag Racing Forum
Old 3rd-August-2008, 11:47 PM   #1
bigbadbp7
(OP)
bigbadbp7's Avatar
Nova(s): 72 nova
Question Camel hump heads
Im about to install a 350 into my 72 nova
bored .20 over
comp cam 268 advr duration 454 Lift
64 cc camel hum heads
rmp intake manifold
600 cfm carb
So here is my problem I dont have accessory bolt holes so where would I find brackets for alt and PS pump.
Also how much power do you think will be making?
Old 4th-August-2008, 12:38 AM   #2
1963wagonman
1963wagonman's Avatar
Nova(s): alot
my guess......with lil info...
290-310hp
Old 4th-August-2008, 12:43 AM   #3
bigbadbp7
(OP)
bigbadbp7's Avatar
Nova(s): 72 nova
sweet. do you know where i could get brackets for my alt and PS..
Ya i hope to get in the 13 in the 1/4. Im going to be getting fiber glass hood fenders and bumbers.
Old 4th-August-2008, 01:25 AM   #4
1969NovaSS
1969NovaSS's Avatar
Nova(s): Nova Freak!!!
If you run the short style water pump and 68 or older brackets, then you would be fine. Other alternative is to fab brackets up to mount accessory's or modify the ones you have. I have run the Camel hump heads on a 74 Nova. I really didnt run into to many problems as the P.S. pump bolted throught the water pump and then the other bracket bolted to the header/ manifold bolt. Only bracket I had to make was for the lower bolt of the alternator. Made a bracket to support the rear. Took the spacer off the alternator and made a bracket that bolted to the manifold/ header bolt and lower bolt along lower edge of block in front. Still used the original lower bracket that bolts to the pump. The other bracker I made had a nut welded on. Kinda hard to explain. The long bolt that usually goes into the head cannot as you can see on yours.
Old 4th-August-2008, 03:03 PM   #5
fasteddie
fasteddie's Avatar
Nova(s): 1968
Here is a couple pics of my alt bracket with camel hump heads. You can see the top bracket mounts off the water pump but I dont seem to have a pic of the lower bracket. The lower bracket mounts off the front 2 header bolts on the drivers side, you should be able to pick up both brackets at your local parts store! hope this helps!
Old 4th-August-2008, 04:42 PM   #6
1969NovaSS
1969NovaSS's Avatar
[QUOTE=fasteddie;887322]Here is a couple pics of my alt bracket with camel hump heads. You can see the top bracket mounts off the water pump but I dont seem to have a pic of the lower bracket. The lower bracket mounts off the front 2 header bolts on the drivers side, you should be able to pick up both brackets at your local parts store! hope this helps!
QUOTE]
Your using a short style water pump right?
Old 4th-August-2008, 05:42 PM   #7
underatree
Nova(s): 1970...Work in progress
Yeah he's using a short water pump.I am running the same setup on my c-10 with camel humps.
The bracket that bolts to the header is adjustable so you should be able to get it all lined up.I had to grind a bit of the bottom of the upper altenator bracket as it was poorly made china crap.
My truck came factory with a short water pump.when I put the headers on I had to loose the factory bracket.
1970 nova 460bbc/th400
Old 4th-August-2008, 05:51 PM   #8
bigbadbp7
(OP)
bigbadbp7's Avatar
Nova(s): 72 nova
so it doesnt really matter what side you put it on?
1972 nova
15.9 @ 83 in the 1/4
Old 4th-August-2008, 05:59 PM   #9
underatree
Why would you want to change sides?
If the wiring is on the driver side I would leave it there.I am not sure what side yours is on.
I am pretty sure the altenator mount that bolts to the header is for the driver side only.
Old 4th-August-2008, 06:20 PM   #10
bigbadbp7
(OP)
bigbadbp7's Avatar
Nova(s): 72 nova
well see as of now on my old 72 motor.. powerstering is on drivers and alt is on passenger
1972 nova
Old 4th-August-2008, 06:21 PM   #11
bigbadbp7
(OP)
bigbadbp7's Avatar
Nova(s): 72 nova
well my my powerstering is on driver side and alt is on passenger side
1972 nova
Old 4th-August-2008, 09:03 PM   #12
fasteddie
fasteddie's Avatar
Nova(s): 1968
This style of bracket will not work then! There is a company buy the name of I think Allen Grove who makes them for your set up in either long or short pump! Do a google search under his name ( I think I spelled it right or could be Allan) and you should find what you need! Hope you get it worked out.
Old 4th-August-2008, 09:19 PM   #13
bigbadbp7
(OP)
bigbadbp7's Avatar
Nova(s): 72 nova
hey man thanks alot thats what i need sweet
1972 nova
Old 4th-August-2008, 10:01 PM   #14
fasteddie
fasteddie's Avatar
Nova(s): 1968
Glad to have been able to help!
Old 7th-August-2008, 10:51 PM   #15
Baddbob
I've ran those old 461 and 462 castings on many engines with the long pump. All I did was modify the stock lower bracket by doubling two of them and welding them together then welding another bracket on them that goes to the backside of the alternator. If you make this mounting point strong enough then there's no need for the attachment to the head. Here's a pic of my Son's 331 done that way, we spin it to 7k and have never lost a belt. It doesn't flex at all.
Name:	engine right.jpg
Plugs for 461 Camel Heads??? kenfb1 Drivetrain & Performance 5 2nd-May-2008 09:30 PM
camel hump heads Mankind Drag Racing Forum 6 9th-March-2008 02:06 PM
rocker studs on camel back heads.. Peroy1 1st & 2nd Generation Chevy II/Nova's 1 30th-December-2007 01:26 AM
70 Double Hump Heads How Much ?? my69rat Drivetrain & Performance 19 30th-August-2007 05:34 PM
What kind of CFM do stock or pocket ported double hump heads flow? 70SS350 Drivetrain & Performance 17 5th-August-2007 11:06 PM
