Driveshaft offset - Chevy Nova Forum
Old 11th-January-2017, 10:28 AM   #1
Burnett03
Nova(s): 65'
Driveshaft offset
I've read a lot of threads and have seen that the engine is offset about 1 inch to the passenger side. I am currently building a 65 and working on the rear end right now. Just installed a cross member and frame rails. Now i would like to start building the 4 link setup. However the car has no engine, no trans, and no front clip. I know i will be using the Alston front clip and they told me it offsets the engine 1/2 to the passenger side. My question is can i even build the 4link without the front clip, engine and trans? How will i know where to position the ford 9 so it aligns with the transmission? I'd like to get the rear end somewhat done so i can roll the car around the garage. Can i just position the ford 9 to be 1" offset on the passenger side?
Here is my build thread to show you what I'm doing.
Thanks guys.
Old 11th-January-2017, 10:49 AM   #2
Pragmatist
Pragmatist's Avatar
Just as a driveshaft can articulate up and down it is also able to work with a rear end offset to one side or the other.
67 hard top,
My 1980 avatar pic.
Old 11th-January-2017, 01:09 PM   #3
Burnett03
Nova(s): 65'
Thank you for taking the time to reply. What I get out of your reply is get the pinion close in the tunnel and let the u joint do the rest.
Old 11th-January-2017, 02:00 PM   #4
MTNNOVA
Nova(s): 1967 2Dr HT
You might get lucky, but if I were you, I would research driveline angles a little more before proceeding. Get them wrong and you can have some very irritating problems later. If memory serves me right, you need to know the centerline angle of the engine/transmission(usually about 3 degrees down at the tailshaft). The centerline of the pinion shaft is usually set 1 degree lower at the front. This will allow the joint to exercise as it runs and avoid premature joint failure and also compensate for some axle wrap as the pinion shaft will try to rise under power, although not as much with a four link. I believe the optimum lateral offset is 0-1 degree for each 10-12 inches of driveline length. with 3 degrees per 10-12 inches being maximum. Greater angles are often run, particularly on 4X4s, but often lead to early joint failure and irritating vibrations.
Old 11th-January-2017, 03:05 PM   #5
Seattle_Mike
Seattle_Mike's Avatar
You are correct, the Chassisworks clip does keep the stock offset location. No question it's desirable to keep the drivetrain perfectly aligned, why wouldn't you do it? A zig-zag alignment may get you by, but if you are going to all the expense & effort to do a quality build, you might as well do it right.
68 Camaro Nitrous ProMod 848ci Buck Racing Engines
Old 11th-January-2017, 03:12 PM   #6
Pragmatist
Pragmatist's Avatar
I would agree but it's more esthetics than mechanically necessary. The driveshaft doesn't know or care which end is up, north or sideways. What matters is if the plane is parallel.
67 hard top,
My 1980 avatar pic.
Old 11th-January-2017, 03:34 PM   #7
Burnett03
Nova(s): 65'
Thank you for your input. I agree it is better to do it once i have everything. I was just trying to do things little by little to keep the cost spread out. I will have to buy the chris alston clip, engine and the rear end setup all at once which i was trying to avoid.
Old 11th-January-2017, 05:07 PM   #8
Roddychop
If you take the time to read this it will explain everything you need to know
http://www2.dana.com/pdf/J3311-1-DSSP.pdf
If the engine and trans are square in the frame and the rear end is also square , the driveshaft won't care about the angle as long as they cancel out, providing your not past the maximum working angle of the u joint. If the tailshaft of the trans is pointing down 3 degrees you will need to point the diff pinion up 3 degrees so they also cancel out. This angle is assuming the car is at ride height and the car is weighted as if it was driving down the road.
Old 11th-January-2017, 06:04 PM   #9
Pragmatist
Pragmatist's Avatar
And in the same vein if the engine is square with the chassis the rear end doesn't have to be directly in line. It can easily be an inch to either side.
67 hard top,
My 1980 avatar pic.
Old 11th-January-2017, 06:13 PM   #10
Burnett03
Nova(s): 65'
I will give it a read, thank you very much.
Old 11th-January-2017, 06:21 PM   #11
Roddychop
I meant the link for the original poster, you obviously know the theory. Most pinions are not centered as u joints wear longer if they have at least a 1 degree working angle.
Offset? laser-red-nova Wheels and Tires 2 17th-March-2016 02:58 AM
Offset? blownnova Steering, Suspension, and Chassis 1 28th-January-2011 01:41 PM
