Hi fellas,
First off, a kudos to motoboy for selling me a factory sway bar. Thank you!!!:yes:
And the questions are:
1. What lube would you recommend for the U-bracket bushings? I don't think my Astroglide would be good for this.
2. Can you recommend a bolt/nut/washer set for the U-bracket installation into the crossmember?
I've got all of the parts, except for the lube and U-bracket bolts/nuts/washers. I'm not sure if they need to be hardened or not...
Thanks folks, NPHNP.
Cheers, Tim
Cheers, Tim
