if i were you i'd try and get a muncie,even if it takes you a while to save up,i've had a couple saginaws and was very disatisfied with them,sloppy,long throw,and geared for a station wagon,even if you just get a good housing with salvagable gears,you can rebuild it yourself,they'r not that hard the come right apart like cake,and yes you will need a Z bar and ball stud,this is a ball with threads on the end like a bolt,that threads into the block oposite the Z bar wich bolts to the outside of the frame,opisite the bolt holes for the auto shift bracket,you will also have to tap the holes as they are not right now,you will also need the adjustable rod for the Z bar and the spring that holds it in place, once the Z bar is in run the main pedal rod threw the fire wall(uninstall the plate over the hole 2- 1/4" screws)and hook it to clutch pedal with cotter pin,also you might want to get the boot that goes over the rod and sicures to the fire wall so rain doesn't get in the car, and pedals i would buy used off of ebay or somewere,i have 2 sets on my wall in my shop if your enterested,and they are also easy to put in,you just unhook the clip and push out the pin for the rod assymbly from the master cylinder,un bolt the master cylinder and pull it away from the fire wall a couple of inches so its out of the way,then just uninstall the clip on the main shaft rod holding the pedals in,push out the rod,the pedals will drop and push the 4 speed ones into place,they will lign up the same in the bracket,push the pin threw and reinstall the clip,o and you also have to unbolt the plastic button for the brake lites and reinstall when done--Dan:turn:
