Air Struts or bags?? - Chevy Nova Forum
Old 18th-June-2017, 01:13 PM   #1
Cuban65ChevyII
Nova(s): 1965 Chevy II 4dr. 1st ca
I am a Rookie on air ride but I have plenty of experience in coil overs, trailing, arms, 4 links, control arms, ect... in the off road world of Jeeps and 4x4 conversions. Vehicle is a stock 65 Chevy II four door hardtop. 194 c.i. powerglide. I want to keep it completely stock as far as drivetrain, braking, and body as well because it was my grandfathers car, However I want to bag it and slam it on the ground while parked.
My question is what will give me the lowest stance while driving and then slammed while parked. Will bags or struts with a drop spindle be enough?
What would be my best combo to incorporate the rear as well. I can fab what I need so just basic parts will suffice.
So struts with spindles or bags alone or with spindles too? I would like it as low as possible it will be a cruiser not a road drifting, track cornering beast, just a grocery getter! THANKS for any info in advance all comments will be greatly appreciated!
Old 18th-June-2017, 04:01 PM   #2
Twinshadows
Twinshadows's Avatar
Nova(s): 1969 White 2-door
1st off....... Welcome to Steve's ........
then ...... for your ?'s....... I'm not sure..
but I really like 65's (all styles).... and I really like th' guys staying SIX......
So, I'd vote for "bags", to drop your car (when parked at th' shows or cruise nights)....... I think that would be 'killer'. I've had my '69 for 20 years as a DD, and just now starting to change things around (up dating items).
good luck , and , keep us posted
later, .jim
ps----- look at the bottom of this page----- "similar threads"..... more info
Old 19th-June-2017, 08:37 AM   #3
Roddychop
I have a 63 on air, bags/ drop spindles in front, triangulated 4 link in the back with sleeve bag/ shocks.
You will not be able to actually slam the car , it will be low but don't pretend you will lay frame.
You can search for my build thread " project Beaumont " for pictures of my set up.
Old 19th-June-2017, 10:36 PM   #4
Cuban65ChevyII
Thanks Rody and Twist. I figured I would not lay rail with just bags but as I said want to keep it stocker with a locker! I do want it on the ground as much as possible. I figure the spindles and bags up front and I am going to possibly make a 3 link in rear to keep it simple. I will make lower trailing arms with lengthened perches to add axle torque control and the top link will be for aiding the torque control but more so pinion angle if it does not work I'll just make to uppers and go 4 link! There is not a whole lot of power and torque in the 6 banger so I think it will work but I will over built it cause I usually do! Ha!
Any Ideas on drop spindles makers or bag houses. I seen Air Bag It has a kit for 1k which looks descent, Comments? Any one on struts have height and drop travel measurements?
Old 20th-June-2017, 07:49 AM   #5
Roddychop
Someone put this kit on the back of my car ( minus the front struts )
http://www.ridetech.com/products/sus.../product-3249/
And this one on the front
https://www.performanceonline.com/19...spension-kit1/
I like air ride but I probably would not have bothered on a 63. Your limiting factor may be your oil pan. My V8 oil pan sits on the ground. Also it's already tough to get wheels under a nova without mini tubs and a front clip , so if you bag it don't expect to get much over stock sized wheels.
Pictures you see of huge deep wheels slammed under a nova sitting on the ground are usually tens of thousands spent and countless modifications.
Old 20th-June-2017, 09:49 AM   #6
Shane65
Shane65's Avatar
Nova(s): 63 & 65 wagon 64 hardtop
Both my 65s had V8 front sump pans and they had lots of clearance to the ground when aired out. For safety reasons nothing should contact the ground when aired out in case of air bag failure while driving. The wagon picture is at ride height and the transmission and exhaust at that area only had 2 1/4" clearance yet I put thousands of miles on it. Wheels were pretty inexpensive(Jaguar E-type 15" X 6). Shockwaves on the front and custom made lowering blocks with de-arched springs. The sedan was air bags all around. I made my 4 link since there were no companies making them 18 years ago.
Click image for larger version
64 hardtop, 63 wagon
Old 20th-June-2017, 10:14 PM   #7
Roddychop
You're telling me you got those rear wheels under the orange car without mini tubs ?
Old 21st-June-2017, 09:11 AM   #8
Shane65
Shane65's Avatar
Don't think I implied the sedan was mini tubbed. I did mini tub the car. It is a stock width rear end and since I added 2" with the tub, I added 2" in back spacing to the wheel I had previously ran and around 2" in tire width.
Old 21st-June-2017, 10:19 AM   #9
Roddychop
Thanks for clarifying. The picture of the wagon doesn't expand so its hard to see but if you were running 6 inch wide rims then it probably didn't rub.
My car has 7" wide rims with 4 1/4" backspace and with 205 tires on the back I was having rubbing issues until I had .125 " machined off the mounting flange. There is definitely not a lot of room under those cars unless you start modifying them.
I love the orange car but I bet it wasn't cheap to get that stance.
Old 21st-June-2017, 10:28 PM   #10
Shane65
Shane65's Avatar
Cost wasn't too bad. I made my 4 link and the Air Ride controls were new unused from ebay. ut they may have been 225(I sold it last year)I think the rear tires were 235 60 15 b Here's a picture that you can enlarge with the car at ride height. My 64 that I'm building is my most expensive. Shockwaves all around and TCI front and rear clip. Just have to find the time to get back building it.
Old 22nd-June-2017, 07:34 PM   #11
Roddychop
I love the wheels and stance on that blue car.
Suspension air bags slick nova Steering, Suspension, and Chassis 3 17th-October-2016 07:31 PM
air bags.... blonby Steering, Suspension, and Chassis 9 23rd-April-2013 04:58 PM
Finally got my new Air Bags 66 WICKED WGN South Western US 1 12th-March-2007 03:26 PM
Air bags or Coilovers on 74? marks LT 3rd Generation Chevy II/Nova's 0 23rd-December-2006 10:26 AM
