Question my 69 nova does not have a wiper motor, I want order one. So my question is I look at my wiring harness and has 2 plugs with 2 wires on them and also I have 1 single wire so do I order a 3 wire or 4 wire motor with pump
The wiper motor you need should have 3 terminals and a rectangular (not round) motor housing. The pump should have 2 terminals.
One of the 2-wire plugs goes to the washer pump. The other 2-wire plug along with the single-wire plug go to the motor.
On the 3 motor terminals, one is spaced farther away from the rest ... that one takes the single-wire plug. And the 2-wire plugs have at least one "index notch" that lines up with an "index tab" on the corresponding motor/pump terminal. If you get them mixed up, the index tab will keep an un-notched plug from going all the way on.
Here is a photo of the wires I have, and this should be the motor I need.
Thanks for your help.
Related Threads
Chevy Nova Forum
2.4M posts
56.8K members
Since 2004
