3rd Generation (68-74) Wheel and Tire Fitment - Page 27 - Chevy Nova Forum
Go Back   Chevy Nova Forum > Body, Chassis and Mechanical > Wheels and Tires
Old 27th-July-2016, 04:00 PM   #391
xMLMx
xMLMx's Avatar
Nova(s): 1969 Nova
15x8" wheels with 5" backspacing (Wheel Vintiques Style 30 from Summit Racing), using a 275/60R15 BF.G rear tire. Monoleaf rear springs with the shocks relocated inboard, at the highest "eye" on the shackles for the time being; I plan on lowering the back a good 1-2". So far this is a perfect fit, save for being a little tight on the outside at full compression. There's a little wiggle room to re-center the axle if I run into scrubbing problems on launch.
Will be updating this once I have time to fabricate a new cross brace for the rear shocks to tip them inward up top and lower the car down.
Old 3rd-August-2016, 10:11 AM   #392
maj75
Nova(s): 1972 SS
I have gone through this whole thread and didn't see my question addressed. I have a '72 Nova stock suspension, factory disc brakes.
What is the largest SQUARE 15" tire/wheel package that will fit. I want to be able to rotate tires and have 1 spare tire😉
Most posts are how big you can go on the back and others have different backspace front to rear. I'm OK with using small spacers if necessary.
Old 3rd-August-2016, 10:36 AM   #393
68bbnova
68bbnova's Avatar
Nova(s): 68 nova 70 nova
The largest front tire will dictate this, I have a 15x7 4" backspace on the front with a P215/65/15 tire. That will surely fit on the back.
Old 25th-August-2016, 12:50 AM   #394
bella's dad
bella's dad's Avatar
Nova(s): 1973 Hatchback
I thought this reply should be posted here as well
Eventually i was going to have to take the plunge and buy some larger diameter wheels in order to fit disc brakes.
Wheels are U.S. Mags "Rambler" series, 17X7 front and 17x8 rear. Both have +1mm offset. Tires, Continental Extreme Contact DW, 225/45-17 front and 235/45-17 rear. I test fit 245's in the the rear but it looked like it would rub on the fender if I hit a big bump/pot hole.
Click image for larger version
Name:	New wheels 013.jpg
ID:	250537   Click image for larger version
Name:	New wheels 016.jpg
ID:	250545   Click image for larger version
Name:	New wheels 018.jpg
Old 1st-September-2016, 11:52 AM   #395
Ironswede
Ironswede's Avatar
Nova(s): 1972 Nova w/305
1972 looking for 17s
Im looking for 17" wheels that will fit my 1972 Nova that is lowered 2" in the front and 1.5" in the back.
Im not trying to stuff the most I can under the car. Just looking for good fitment.
1. Will these 17X7s work for the front? If so, what is a 'safe' tire size to go with? Meaning, not stuffing a tire under there. Just something that is sure to fit.
Wheel size: 17" x 7"
Bolt pattern: 5 x 4-3/4"
Backspacing: 4-1/4"
Offset: +6mm
http://www.classicindustries.com/pro.../sw177542.html
2. Will these 17X8s work for the rear? Just a smidge wider for a cooler stance. If so, what is a 'safe' tire size to go with that is sure to fit?
Wheel size: 17" x 8"
Backspacing: 4-1/2"
Offset: 0mm
http://www.classicindustries.com/pro.../sw178542.html
*note* Id be willing to do the 17x7s all around if that made it easier
Old 8th-September-2016, 09:49 AM   #396
JLMartin7J
JLMartin7J's Avatar
Nova(s): 1972 Nova SS, 1965 Nova S
Has anyone ever used the Z06 wheels from Replica, if so how did they look under your nova?
1972 Nova SS 396 small block, 1965 Nova SS factory 327 2 speed powerglide
Old 10th-January-2017, 05:45 AM   #397
32blownhemi
32blownhemi's Avatar
Nova(s): 1970 Nova SS clone
By any chance is anyone running Centerline Convo Pros? Thanks! Bill
Old 16th-January-2017, 01:13 PM   #398
meridian208
Nova(s): 1970
Wheel Fitment Video
I made this video when trying to fit some pretty wide 17 inch wheels on my car. I went ahead and showed a bunch of measurements and some of the problem areas you may have for fitting any size wheel on the rear though. Hopefully this helps someone figure out the specs for a wheel and tire combo they are looking at.
Old 18th-January-2017, 10:19 AM   #399
70chevybb
Nova(s): 72 ss
Wheels
I installed new wheels last night. here is the problem 15x8 4.5 back spacing with 255/60/15's. The drivers side is perfect but the passenger side is going to rub. I have read where some guys 3rd gen nova's have the rear end that sits 1/2 inch to the passenger side and mine is the same, I really do not want to cut or woll the lip on the quarter. I am thinking about buying 1 15x8 with 5 inch back spacing for the right side. I then would have the exact same clearence. Anyone see a problem doing it like this?
1st Generation('62 - '65) Wheel and Tire Fitment novanutcase Wheels and Tires 201 12th-January-2017 01:22 AM
4th Generation('75 - '79) Wheel and Tire Fitment novanutcase Wheels and Tires 28 2nd-January-2016 06:16 AM
3.5 Generation (73-74) Wheel and Tire Fitment rcb Wheels and Tires 2 18th-December-2014 02:37 PM
3rd Generation (68-72) Wheel and Tire Fitment rcb Wheels and Tires 0 10th-April-2014 08:37 AM
