Went to the track did testing Exhaust/open headers - Page 2 - Chevy Nova Forum
Go Back   Chevy Nova Forum > General > Drag Racing Forum
Old 13th-June-2017, 09:45 AM   #16
wht73
wht73's Avatar
Nova(s): 73 nova custom
I'd take a 61lb reduction in a heart beat if I was going to change them anyway!
Problem is he already has the springs.
3515#,all steel,406ci N/A,10.6/122.38, short shifting, N/A
Old 14th-June-2017, 01:05 PM   #17
Gregs72
Gregs72's Avatar
Nova(s): 1972 Chev Nova
I am not expecting to gain anything from what i read going from slapper bars to caltracs.
But my brother needs traction bars for his car and i found the Caltracs crazy cheap so i bought them so he can have the slapper bars. will be nice to get rid of the bounce on the street with the worn out leaf springs......then the QA1 shocks wont have to work as hard
1972 Chevy Nova
12.08@111.85mph 1.67 60' with 7.67@89mph 1/8th mile
Old 14th-June-2017, 01:26 PM   #18
wht73
wht73's Avatar
You think the bounce is bad?
Try leaving the Caltracs in the track setting with Aluminum bushings in the front with the split's and urethane body bushings!
It does help stiffen the car up tho.
just paranoid about changing the setup on the Caltracts.
Old 16th-June-2017, 09:40 AM   #19
Gregs72
Gregs72's Avatar
I got it all installed last night.......man the arch on the new springs is different but there is no sag......we will see how it looks when i put it on the ground
1972 Chevy Nova
Old 16th-June-2017, 07:25 PM   #20
Nova(s): 1972 Nova
I backed mine all the way off for the street even though I put a piece of hose in and pushed the pin thru to quieten them for the street. I'll adjust them here at the house and drive it to the track if I ever bother to get any drag radials for it(lol).
72 Nova 383
72 Nova 383(11.70s)
71 Nova 406(11.60s)
71 Nova 350
70 Nova 350
Old 16th-June-2017, 08:13 PM   #21
cdahl383
cdahl383's Avatar
Nova(s): 1972 Nova
Cool man, congrats on the new PB! I've never tried opening the caps on my exhaust at the track, may have to try that one day. It certainly sounds a lot cooler though haha!
Carl
1972 Chevy Nova - 12.36@109.65mph w/1.72 60ft
2015 Dodge Challenger - 11.62@117.26mph w/1.61 60ft
Old 17th-June-2017, 10:10 PM   #22
wht73
wht73's Avatar
Hope your going to provide pictures!
John, your as bad as me! I didn't go to the track till 2yrs after I installed the 406.
Old 18th-June-2017, 01:43 PM   #23
bowtie0069
bowtie0069's Avatar
Nova(s): 69
I never change mine, it's not too horrible, but it rides like a Cadillac with the pre-load backed off!
69 Nova 410" small block-Driven to track
6.39 E.T./105 MPH--6.11/112.89 w/N2O
Old 19th-June-2017, 03:26 PM   #24
Gregs72
Gregs72's Avatar
I will get some tonight. THANKFULLY it sits the EXACT same height as my worn out multi leafs did......so i guess they had 2" of Sag in them. I am really happy about that. i wanted the same if not higher.
Tonight is welding in the exhaust dumps so its easier to open at the track....and will be able to load and unload into the trailer without having to hook them back up if needed.
1972 Chevy Nova
Old 19th-June-2017, 09:16 PM   #25
epfatboy
epfatboy's Avatar
Nova(s): 1964 Chevy Nova SS
Place the dumps wisely, they have a tendency to hang up on the lip of trailers
Sent while texting and drag racing
'64 Nova
2015 Transformation
Old 20th-June-2017, 09:38 AM   #26
Gregs72
Gregs72's Avatar
Ran in to bigger issue tonight......i run my shocks in OEM location......i did the swap with my 17" wheels on..........decided last night i should just check the pro stars.......and yep shock bolt hits the wheel.........so here are the choices
1.) get a 3/8 spacer and run at the track
2.) drill a new shock bolt hole in the lower caltrac mount to raise up shock 3/4" to provide clearance
3.) ---most likely NOT happening but move shocks inboard
1972 Chevy Nova
Old 20th-June-2017, 09:58 AM   #27
bracketchev70
Nova(s): 70 Nova (sold)
If you have long studs, I would go with the spacer.
Used to be bracketchev1221
70 Chevelle 540, t-400. 9.03 at 148 1.24 60' and still 3200 lbs.
Ray
Old 20th-June-2017, 10:14 AM   #28
epfatboy
epfatboy's Avatar
1 or 2 works.
I'd actually go with 2 since it would accommodate both wheels and I wouldn't need to remember spacers. I also would have had a drill handy last night versus the spacers!
Relocating .75 is not likely to bind on compress unless your doing a little dukes of hazard driving.
'64 Nova
2015 Transformation
Old 20th-June-2017, 11:23 AM   #29
Gregs72
Gregs72's Avatar
For those that wanted pictures
1972 Chevy Nova
Old 21st-June-2017, 02:28 PM   #30
Gregs72
Gregs72's Avatar
I ordered the 3/8 Billet Spacers, i have 4" studs so there is still enough engagement through the race wheels.
So hopefully this solves the issue........
1972 Chevy Nova
track testing the carbed 6.0 bkhotrod LSx Forum 3 25th-November-2012 05:56 PM
open track suspension on another forum 04ctd 4th Generation Nova's 3 11th-March-2010 09:35 AM
Full exhaust with headers at the track? slickman Drag Racing Forum 8 22nd-December-2009 01:32 PM
CPP Track Testing our new 1970 nova very impressive stuff!! LIVIN42MARROW Steering, Suspension, and Chassis 18 18th-February-2008 12:09 PM
