'64 from idiot to gauge - Chevy Nova Forum
Go Back   Chevy Nova Forum > Body, Chassis and Mechanical > Electrical
Old 19th-March-2017, 04:56 PM   #1
Chevy264
Chevy264's Avatar
Nova(s): 64 Chevy II 2dr hrdtp 400
So I am finally getting around to installing my SS gauge cluster.
Going from the warning lamps or idiot lights to gauges.
I have installed the correct temp sender and I am now looking at what to do at the gauge.
My question is: Can I remove the warning lamp, and use the two wires (dark green and pink) to work the now temp gauge?
Thanks.
Old 20th-March-2017, 12:19 AM   #2
64PRONOVA
64PRONOVA's Avatar
Nova(s): 64SS & 65SS
The temp gauge requires a different sending unit than the idiot light uses. The factory SS Amp gauge requires the external shunt. The color of the wires shouldn't matter.
Both can be purchased at Chevy2Only and other Nova parts vendors.
The fuel gauge will work with your existing sending unit.
The oil pressure gauge is mechanical and requires the tubing and fitting that goes in the back of your engine block.
Old 19th-April-2017, 11:20 AM   #3
Chevy264
Chevy264's Avatar
updating info
So my question was, if I could cut the warning lamp socket off and using those existing wires to work the now installed temp gauge.
The answer is yes.
I did exactly that, cut the lamp socket off and used the wires.
I work for John Deere and Co. and I was able to find these terminals and connector to make the plug in for the temp gauge.
For the terminals I used John Deere part number: U46662
For the connector I used John Deere part number: R77479
Click image for larger version
ID:	288258   Click image for larger version
Old 6th-June-2017, 04:47 PM   #4
g-shox24
g-shox24's Avatar
Nova(s): 1963 Nova 3.8L
The answer is yes.
Is that considered a manual or electric gauge?
Gas Gauge Stuck Past Full, Not Sending Unit nor Gauge Mnistor1 Electrical 25 14th-February-2015 04:28 PM
Gauge wiring question for 65 nova, idiot lights to SS gauges g-ride2 Electrical 7 10th-May-2011 01:45 PM
Look at what this idiot did?? batman09 Drivetrain & Performance 24 18th-December-2008 07:43 AM
i am an IDIOT! SuperSport623 Drivetrain & Performance 11 30th-October-2007 09:43 AM
