I cleaned up my faded blue plastic seat backs so I could dye them black. The plastic is faded bad and it also has deteriorated so when you rub it with your hand fine plastic like flour dust comes off in your hand. I'm thinking I'm going to use a scotch bite pad or maybe some 320 grit sand paper and scuff it up then blow some dye on them. Anyone else see this and know of some other way to fix it? RM
Are these for 69 72 nova cevelle? If so ,I have seen them for about 60 bucks.If you sand them you will lose the grain texer ,maybe get some vinyl top glue and cover them with vinyl.
My seats are hi back. I checked a vender that I have used in the past and you can get just the backs , or they post a 6 pcs set. I have covered some plastic backs with vinyl or fabric before . Don"t have any pics thou. If you cover them, ruff them a littel so the glue will stick better.
I hope this helps. jm
I have similiar problems with white plastic for my 74 Nova and have also heard that other years and makes have the same problem (the plastic powdering). The only way to fix it is replace them or you could find a thin material and wrap them using a landau top glue spray adhesive. If you decide to cover them then I would sand them with a pretty rough paper to dig through to solid plastic material and then prep it with reducer or plastic adhesion promoter.
OK so tonight while listening to our HS football game I used a scotch bite pad and scrubbed the back panels. I scrubbed the hound out of them and the loose film scrubbed off but it left the texture pretty much in tack. The texture was like underneath the film. I wiped them with general purpose 3M vinyl cleaner and sprayed them with Fuson plastic paint. They look good. I bought gloss black and don't like the gloss so I plan to try semi gloss or something but the texture seems OK. Not perfect for a show car but fine for my purposes. I bought new chrome trim for the seats and it looks too small to fit. It looks like door edge and the old trim is bigger. I'll see how that fits later. RM
I went and got some satin Fuson paint today. I repainted the backs to get rid of the gloss look and painted the four side trim parts that go around the bottom of the seats. They all look pretty darn good. I'll be installing the chrome edge trim in the next day or so when I know the Fuson is good and dry. That should be a good test of how durable the Fuson is and if it is stuck on real good. RM
I installed the chrome edge trim and the plastic parts on one seat tonight. The paint didn't chip or peel and the palstic parts look good. I can recommend Fuson from the results I got. I got mine at Walmart. RM
Related Threads
Chevy Nova Forum
2.4M posts
56.8K members
Since 2004
