Help me build a 400+ sbc. What would you build?? - Chevy Nova Forum
Old 2nd-March-2008, 09:35 PM   #1
NovaRich
(OP)
NovaRich's Avatar
Here is what I am looking to do. I want to see what some ideas are for a build with only a few stipulations.
The stipulations:
Must use a stock 400 block (can be bored and stroked)
No spray in the build
Must run on 93 octane
Must use aluminum heads (preferrably GM fast burn)
The more torque/hp...the better
Let me know what you guys would do. Please be as specific as possible. I am considering going this route to get my car on the road faster.
Thanks for any help at all!
MINE:
66 2 dr. Sedan Chevy II Soon to be Mossport Green - Father, Son, and Grandson's Project
Radio, Heater, and Lighter Delete, Rubber floor, steel wheel, dogdish car
Soon to have: ZL-1 BBC w/ M-22
DADS:
66 2 dr. Sedan L79 Chevy II Red on Red
Old 2nd-March-2008, 10:02 PM   #2
Ironman
Ironman's Avatar
Just like any small block chevy the sky is the limit to the number of combinations you can have. It all depends on your intended usage and amount of money you have to spend.
For a street car with a SBC I think a 406 is hard to beat. You can make it into a stump puller, drive all day or head to the track if you want. If you are not going to be turning any high RPM you should not have any problem with the stock crank and rods, just add some good rod bolts and get some pistons to give you the compression ratio you want.
I'm in the middle of a 421 which takes a 4.125+.030" bore and 3.875 stroke.
10.87 at 119 on the brakes 400 SBC pump gas, flat tappet cam, small tire.
Old 2nd-March-2008, 10:56 PM   #3
NovaRich
(OP)
NovaRich's Avatar
Are you building this from a stock 400 block? Can you give me some info on what components you are gonna be using?
MINE:
DADS:
Old 2nd-March-2008, 11:17 PM   #4
NovaRich
(OP)
NovaRich's Avatar
Sorry, I see your build in the other thread. Nice Build!
MINE:
DADS:
Old 2nd-March-2008, 11:30 PM   #5
Ironman
Ironman's Avatar
I walked into a deal someone needed out of that included a GM 400 block with splayed caps installed, Ross flat top pistons, Perfect Circle rings, 6" Eagle H beam rods, and a Scat lighweight forged crank with a 3.875 stroke. I still need to get the block bored and the heads and cam on order. I'm going with a solid flat tappet cam, 254/254, 540/540, 106 and an aluminum head with around a 215 runner, 64cc, probably 2.05/1.6 valves.
The rest I have from the previous engine or have recently acquired, a Quickfuel 750DP carb, Professional Products hurricane intake, MSD ignition, Hedman headers, 1-3/4 primary, 3" collector, Milodon oil pan with the windage tray and kick out, and Paul Wrights pump on the way.
Old 2nd-March-2008, 11:33 PM   #6
NovaRich
(OP)
NovaRich's Avatar
So to get the 421, you only had to bore 30 over? What would 60 over be? Can you get 427 ci from a 400 block?
MINE:
DADS:
Old 2nd-March-2008, 11:43 PM   #7
Ironman
Ironman's Avatar
426 CI or so with 4.185 bore if I entered the data right.
Old 2nd-March-2008, 11:59 PM   #8
66IISS
66IISS's Avatar
Well, here's the build that we did, aluminum headed 406 that runs on 93 octane and goes like stink (estimate of about 500 hp or so)
lunati voodoo 60105, hydraulic flat tappet cam
Canfield aluminum heads (cnc ported)
Victor Jr. intake
1.6/1.5 int/exh roller rockers (summit brand)
mahle forged pistons, flat top
11:1 compression ratio
Summit brand distributor
electric water pump
electric fan
etc. etc. etc.
Runs on 93 octane with no knocking, goes like stink. It's matted to a 4 speed with 3.73's, breaks the tires loose on the freeway.
1966 Chevy II SS, 406 C.I.
1990 Chevy Corvette
2000 F*rd f150 Harley Edition
2003 Chevy Corvette Z06
Old 3rd-March-2008, 09:04 AM   #9
NovaRich
(OP)
NovaRich's Avatar
Victor Jr. intake
electric water pump
electric fan
etc. etc. etc.
This is exactly what I am looking for. What 4 speed do you have in the car? Do you know the specson the heads?
MINE:
DADS:
Old 3rd-March-2008, 10:03 PM   #10
tnblkc230wz
tnblkc230wz's Avatar
Nova(s): 1971 Nova
You can make make a 427. Need a 4 inch stroke crank and 4.125 bore. If you go 30 over it is a 434. Curious as to why you are insisting on Fastburn aluminum heads? Do you already have them most 200 cc aftermarket heads are better. The Edelbrock ETec 200s are cheaper as well. I think even the Dart Pro 1s are cheaper and much better.
71 Nova, Pro-Touring/Autocross
LS3 eRod, 6 speed.
Old 3rd-March-2008, 10:15 PM   #11
Bat 21
Bat 21's Avatar
Nova(s): 72 Nova SS
Nova rich, bore and stroke, for the most part = cubic inch, heres a good site that shows all of the stock bore and stroke specs...
http://users.erols.com/srweiss/tablersn.htm#Chevy
-Dave
'72 Nova
Old 3rd-March-2008, 11:20 PM   #12
66IISS
66IISS's Avatar
http://www.canfieldheads.com/sbc_2600.html
I'm pretty sure those are the heads. The engine was built by my father and I about 3 years ago, I don't have the information in front of me, this is all off of memory. I'm almost positive we went with the 220's, we got them because AFR's were darn near impossible to get around the time (at least 6 week lead time ).
4 speed is a Muncie M21, tires are old. It cruises down the freeway at 75 at about 3000 rpm (been a while since I've driven it, this winter stuf has got to go). This is right about where the cam starts to pick up power, if I floor it you get shoved back in the seat and away you go. 75 - 95 is pretty quick, car is very unstable after that.
Either way, it's a blast of a car. All this was done with the stock 400 bored 30 over, scat crank and eagle cap screw rods
1990 Chevy Corvette
Old 5th-March-2008, 05:35 PM   #13
NovaRich
(OP)
NovaRich's Avatar
Didn't insist on the fast burn heads, just preferred it. I'll settle for any ALUMINUM head
MINE:
DADS:
Old 6th-March-2008, 02:18 PM   #14
ezzze
Title: Nova Newbie
Nova(s): 1964 2 dr chevy II
TTT.....keep them coming. There are a lot of stock block 400 owners who want to know winning combinations.
Old 6th-March-2008, 02:47 PM   #15
69LT1Nova
69LT1Nova's Avatar
Nova(s): 1969 Nova, grandma fresh.
Does anybody de-stroke 400 small blocks these days? I seem to remember this was the hot ticket... 400 block, 350 crank with spacer bearings to get 377ci. You could rev the crap out of this engine and it'd just sing all day long.
Nowadays it seems like everyone is going for big cubes... which is great for torque... but considering that a Nova is a light car, a high RPM motor would be fun - and help get you out of the hole with less tire spin.
Thoughts?
400 sbc fast1stgen Drivetrain & Performance 29 2nd-March-2008 04:47 PM
Please help - 400 sbc build up Dawg Drivetrain & Performance 82 31st-August-2007 05:04 PM
Budget 400 sbc build...good idea? Dawg Drivetrain & Performance 14 16th-October-2006 02:56 PM
