Bad News - Chevy Nova Forum
Go Back   Chevy Nova Forum > Non-Technical > 4th Generation Nova's
Old 7th-January-2017, 02:35 PM   #1
kimrobertson
(OP)
kimrobertson's Avatar
Nova(s): 79 Phoenix
Bad News
Going back 5 years when I built my engine I really didn't know what I was doing with setting the valve lash. Consequently at first startup the valves were way too tight.
Over the past 5 years I have been bothered by a ticking noise form the valve train. I was hoping maybe just caused by the old 1978 pushrods and rockers. Engine seemed to run fine with good power. Just that annoying tick that wasn't real loud but annoying--and no amount of adjusting would make it go away.
I have had new push rods and rockers for about 8 months and finally got them in this morning with my brother's help.
The noise is now actually worse! When taking the old ones out we had found several bent push rods... probably from the initial startups because they were all straight when I originally installed 5 yrs ago. Next step will be to do a compression test and see where everything stands. If that looks okay I will pull the intake and check the lifters...and cam ( if I can see enough of it).
350/Tremec 3650 5 Speed/3.42
Old 9th-January-2017, 10:51 AM   #2
Nova Twins
Nova Twins's Avatar
Nova(s): 1976 Base
Was the cam matched to the springs? Is there a chance you had any coil bind going?
Old 9th-January-2017, 11:27 AM   #3
kimrobertson
(OP)
Nova(s): 79 Phoenix
Not sure what coil bind is...Is that when the valve springs can't handle the lift or float because the can't handle the rpm?
Cam is Comp Cams XE 268 12-242-2 Valve springs were new .550 lift "Z28" springs. Specs in link...
http://www.compcams.com/Company/CC/c...x?csid=86&sb=2
Old 9th-January-2017, 11:33 AM   #4
Nova Twins
Nova Twins's Avatar
Nova(s): 1976 Base
Coil bind is when the spring cannot compress anymore and the pushrod is still trying. Are you using the stock length pushrods?
Old 9th-January-2017, 11:37 AM   #5
Nova Twins
Nova Twins's Avatar
Nova(s): 1976 Base
Did you see the note that stock springs cannot be used?
Old 9th-January-2017, 01:04 PM   #6
kimrobertson
(OP)
Nova(s): 79 Phoenix
Okay--The springs are good to .55 lift and the cam is .48...I remember now asking about the stock spring note when I was considering buying the cam and they said the springs in my heads would work fine.
Old 9th-January-2017, 01:11 PM   #7
1978 ls3
Nova(s): 1978 2dr coupe
I have been using the Z28 springs for a 10 years now in my 355 with the comp xe268 running her up to 6000 rpm occasionally and zero issues.
Old 9th-January-2017, 05:42 PM   #8
Nova Twins
Nova Twins's Avatar
Nova(s): 1976 Base
Good. I was worried about too much lift for the spring.
Old 9th-January-2017, 06:59 PM   #9
skylarkjohn
skylarkjohn's Avatar
Nova(s): 75 Nova
Are you useing cast iron heads? Were the valve guides checked for exsessive wear? If they are worn they will tick. It will sound like a lifter tick and at cam speed.
Las weak I cudn't evon spel machenik...now I r 1
Old 9th-January-2017, 09:58 PM   #10
kimrobertson
(OP)
Nova(s): 79 Phoenix
The heads are cast iron but were reconditioned when I put it together. New guides, seats, seals, valves...3 angle valve job... I'm thinking that my overtightening the valves originally damaged the cam before I got them loosened up and adjusted properly so I could never get rid of the noise It wasn't a terrible noise but just not right. So I was hoping the new parts would take care of the problem...
What I'm a little confused about is why new pushrods and rockers adjusted properly would result in the same noise only louder. Maybe the cam & lifters worn the wrong way somehow is affecting the new parts?
Old 9th-January-2017, 11:57 PM   #11
kansas
Title: Guest
Posts: n/a
Try thicker oil. Maybe the lifters are bleeding down too fast and behaving like rhoads lifters.
Old 10th-January-2017, 08:11 AM   #12
Pragmatist
Pragmatist's Avatar
Garage
Blown exhaust manifold gasket will cause a tick.
67 hard top,
My 1980 avatar pic.
Old 10th-January-2017, 09:15 AM   #13
sbc1320
sbc1320's Avatar
Nova(s): 1972 Nova
Could be lots of things. I've seen a broken piston skirt sound just like a loose rocker.
As far as setting your valves, if you don't know how then learn/ask and don't guess. Not bashing at all, but really serious about this. Don't only learn the how, but the why also.
72 Nova 383
72 Nova 383(11.70s)
71 Nova 406(11.60s)
71 Nova 350
70 Nova 350
Old 10th-January-2017, 10:37 AM   #14
kimrobertson
(OP)
Nova(s): 79 Phoenix
Running 20-50 since rebuilt 5 years ago...Actually am thinking of running lighter weight after I get this straightened out.
Old 10th-January-2017, 10:38 AM   #15
kimrobertson
(OP)
Nova(s): 79 Phoenix
Yes I'm aware of that but this is definitely internal...
68 Nova, good news/bad news Project Nova Ebay, etc. Discussion 11 7th-November-2012 12:55 AM
Last weekend: good news/bad news ZNova Drag Racing Forum 13 8th-November-2011 11:39 PM
Gear whine-Bad news, Good News I Suppose mikeorwan Drivetrain & Performance 12 19th-August-2008 08:28 PM
Timeslips from tonight. Good news, bad news. MuscleDreams Drag Racing Forum 6 29th-April-2007 10:48 AM
