Trans mount for 4L60E in a 63 - Chevy Nova Forum
Go Back   Chevy Nova Forum > Body, Chassis and Mechanical > Drivetrain & Performance > LSx Forum
Old 15th-December-2011, 04:10 PM   #1
MLM454
MLM454's Avatar
Nova(s): 1963 Wagon,LS1 AOD build
Question Trans mount for 4L60E in a 63
Any of you guys with 63 -65 model cars used a trans mount from Year One or Classic Industries? I have a TCI clip and I'd like to buy one that will take care of the correct alignment to the rearend and clearance at the tunnel. I wouldn't mind drilling holes, but I don't have access to machine shop equipment anymore.
Also, have yall used any universal adapters that allow the stock column shifter to be used. I have the steering on the TCI clip hooked up and I'm ready to stick in the engine and tranny. I kept the stock column and steering wheel trying to keep the stock look inside. I don't mind if the shift indicator don't have 1,2,3,OD, I just want it to work.
Thanks for yalls help,
It's coming along nicely
Mike
Old 16th-December-2011, 07:48 PM   #2
Rantnrave1969
Nova(s): 67 hardtop in need of TLC
Mike
Chevy 2 Only has a crossmember for a 4l60E, you can use an autoparts store mount or urethane one. "Should" be no hole drilling. as for the driveline angles if you read enough of these threads about these clips out there, some guys have no problems some do. some fixes have been as easy as swapping motor mounts, others have been cutting the motor mount pedastals off the crossmember and relocating them. seems to be less of an isssue with a manual rack and smallblock, as opposed to power rack and LS engines. as for the shifter i think lokar has a cable hook up for that but headers have always an issue with column shifter
Old 17th-December-2011, 12:12 AM   #3
Burke
Nova(s): 1963 nova wagon
Mike
Does your TCI clip center the engine? I think you will find that most of the trans crossmembers are offset like stock and will need modification to work with a centered clip. I reshaped the stock power glide crossmember for mine, but it's a lot of cutting and welding. I was able to use my stock column shifter and linkage after some modifications, and Shiftworks makes a indicator lens that's properly marked for the 4L60. CBR makes the nicest crossmember for the 4L60E that I've seen. It's designed so youre exhaust doesn't have to hang to low, and bolts into the stock location.
63 wagon L33 4L60E 12 Bolt 3.73 VA gen IV Willwood Brakes CBR front w/power rack & Watts link rear
Old 17th-December-2011, 02:13 AM   #4
MLM454
MLM454's Avatar
I appreciate your help yall,
I didn't know whether to get a flat bar type like this:
http://www.classicperform.com/Store/...va/CP16002.htm
the g force looks good like good clearance for exhaust:
http://www.transmissioncenter.net/gf...FQNZhwodqUlInw
These are just a few I have seen:
http://www.yearone.com/serverfiles/f...archid=6605617
I thought the flat would be better for clearance but the tube would be stronger.
I don't know about the TCI centering the engine, I can sure see the offset in the tunnel.
Old 17th-December-2011, 09:26 AM   #5
63LSWagon
63LSWagon's Avatar
If youre considering the Chevy2Only crossmember for a 4L60, their description says it doesn't fit a later model 4L60 and they are right. This is mine (with an $8 summit mount)...
Old 17th-December-2011, 03:21 PM   #6
MLM454
MLM454's Avatar
That's what I was afraid of Nova Guru,
You did a good job on yours, but I need a bolt in. I am using a 98 LS-1 engine and tranny from a Camaro. I haven't found out about whether the street TCI clip centers the engine yet but I believe it does. I looked at the TCI website and didn't see a cross member offered.
Thanks,
Mike
Old 17th-December-2011, 11:43 PM   #7
pismonut
pismonut's Avatar
Nova(s): 63 400
Just mod your stock mount as i did with my power glide one it works great and you can get a stock 02 camaro rubber mount from autozone for 13 bucks
Sent from my SAMSUNG-SGH-I897 using AutoGuide.Com Free
Old 18th-December-2011, 12:36 AM   #8
MLM454
MLM454's Avatar
Thanks Pismonut,
I'll try that first and see how much modifying it needs.
Mike
Old 18th-December-2011, 10:23 AM   #9
67 church
67 church's Avatar
Title: Supporting Vendor
Nova(s): 67 2dr hrd top, 2-63 wags
keep in mind that the type of adapter plates that you use for engine placement will determine if it all lines up as well. Some mounts move the engine forward some move them back....
Chuck Church
330-442-7162
Made in the USA
Old 18th-December-2011, 11:18 PM   #10
MLM454
MLM454's Avatar
Thanks Chuck,
I bought the TCI clip from Ibuildm on here and he also sold me the LS motor mounts. I didn't realize they varied from front to back.
I haven't set the motor in yet, but that is next.
Mike
Tags
shifter linkage
4l60e trans query elephantrider70 Drivetrain & Performance 5 30th-May-2011 01:01 PM
4l60e trans linkage NovaBear Drivetrain & Performance 1 17th-March-2011 12:12 AM
Trans Mount lcwilson95 Drivetrain & Performance 1 17th-September-2010 10:42 AM
trans mount Slick75 Drivetrain & Performance 1 17th-March-2009 09:07 PM
