Electric fuel pump on v8 - Chevy Nova Forum
Old 2nd-December-2008, 12:25 AM   #1
DesertDeuce
(OP)
DesertDeuce's Avatar
Nova(s): I hate Novas.
Im thinking about switching to an electric fuel pump this winter on my 283 '63 wagon. I see alot of fuel pumps like this style one;
http://store.summitracing.com/partde...5&autoview=sku
I was wondering if one these with the bracket will bolt to the stock location of a mechanical fuel pump with a block off plate. Like this one;
http://store.summitracing.com/partde...0&autoview=sku
My wagon has new fuel lines, and this seems like an easily accessible area for repairs. Also with this style pump I can pick up a replacement from just about any auto parts store anywhere and make it work.
Will the engines heat be a problem? I can weld up a bracket to the block off plate to make it work if I need to. Any suggestions?
I think my only other choice would be to mount it under the battery box, where the fuel line goes through the inner fender, but I would still need to block off the old mechanical pump and bend up some new hard lines, so this seems like the best route for me. Im trying to stay away from rubber hoses.
Old 2nd-December-2008, 12:27 AM   #2
Mike Goble
Mike Goble's Avatar
Nova(s): 67 wagon project
Why would you want to get rid of the mechanical pump? No wires, no noise, runs when the engine runs, etc...
I'm Mike Goble and I approve this message.
Old 2nd-December-2008, 12:32 AM   #3
dougy68nova
dougy68nova's Avatar
Nova(s): 68 4 door
electric fuel pump will need to be mounted neer fuel tank as an electric pump pushes real good but dosent suck real good like a mech. fuel pump
sorry push and suck is how they get all the guys attention in trade school
Old 2nd-December-2008, 01:06 AM   #4
DesertDeuce
(OP)
It just seemed like a good idea...
Seriously though, I was hoping for easier starts after leaving the car sit for long periods of time. Another kill switch would be cool too.
From what i could gather, as long as it stays around level(or below) with the tank it should have no problems because of the siphon effect. If it was above, and "sucking" than it would well "suck". Which is not what they are intended to do.
Old 2nd-December-2008, 01:24 AM   #5
64PRONOVA
64PRONOVA's Avatar
Nova(s): 64SS & 65SS
A waste IMO. Zero bang for the buck.
For one thing it won't make it perform any better and not as reliable as the mechanical pump.
No show, no go.
Old 2nd-December-2008, 01:33 AM   #6
DesertDeuce
(OP)
No show, no go.
I know a couple of people who made the switch and were overall happy, I guess thats why I was wanting to do it. The cost is not an issue because I can get the pump for virtually free. However that may not be the case forever.
I do know that you know your stuff though.
Old 2nd-December-2008, 03:08 AM   #7
JRouche
JRouche's Avatar
I replaced the mechanical pump for electric in three of my cars I drive now. One is an old motor home, the other is a Fiat spider and the third is my Nova.
All three have the pump back by the fuel tank. And I havent had any problems at all. If you are interested email me and I will give more specifics about wiring, including using relays, and block off plates. Oh, the Nova needs the electric, its fuel injected, but the others are carbed. JR
Old 2nd-December-2008, 04:50 AM   #8
DesertDeuce
(OP)
Lesson of the day... don't knock it untill you've tried it!
I got some very sound advice from some smart people, i'm 90% sure i'm going to do it, its the execution that I want to be 100% on, with relays and fuses etc.
Old 2nd-December-2008, 05:03 AM   #9
danthegeek
danthegeek's Avatar
Nova(s): Red 71
My only issue is, I drive my car way to much. If the pump fails, 10 minutes and $15 from the nearest auto parts store will get me a mechanical pump that will work well enough to get me home.
Another "Lesson of the Day", dont fix it if it aint broke..
71 Nova
"Freakin Hybrids man. They just dont do the trick anymore..."
Old 2nd-December-2008, 05:40 AM   #10
DesertDeuce
(OP)
Another "Lesson of the Day", don't fix it if it aint broke..
I have one of those really expensive mechanical ones. I didnt say it was a great pump, but it has a big price tag. I didn't pick it out, it came with the car.
With my mounting plans for the electric worse case scenario In about 10 minutes I could have a mechanical pump swapped in. It also helps that I have a car trailer.
At this point I want to try it just to make my own judgement, we'll see.
Old 2nd-December-2008, 12:24 PM   #11
veno
veno's Avatar
Nova(s): 72 385, t350, 3.73 4w-dsk
Garage
best bang for the buck in pumps..... Carter.....mechanical.... chaep. been doing it londer than any other brand on the market.. I have the carter street pump... it has been on the car for over 5 years..... and when I was in the 70's I used one on my 340 dart 4sp as a daily driver for 6 years...
a nation of free men, shall live forever, or die by suicide
Old 3rd-December-2008, 01:09 AM   #12
levisnteeshirt
Nova(s): shopping for the 6th one
electric pump
the electric pump is great for when your messing with the carb , taking a bowl off ,, what not . Turn the pump on and fill it back up. Great for when if you run out of gas too. I had a friend that lost a motor that filled up with gas when his mechanical pump leaked fuel inside the engine. So i've kinda stayed away from them after I saw that. For a street car , a person could carry one of the those " buzz box " generic electric fuel pumps to get ya home. I'd say Advance or Napa has them. I used a high performance elec fuel pump from Napa , that turned out to be a Carter elec pump that worked great after 5 years.
Mechanical Fuel Pump Advice tnblkc230wz Drivetrain & Performance 64 6th-September-2007 11:15 PM
Electric fuel pump hardcore Drivetrain & Performance 12 28th-January-2007 10:54 AM
EFI fuel delivery plans tpinovaII Drivetrain & Performance 18 11th-September-2006 01:11 PM
Electric Fuel Pump MNYPIT Drivetrain & Performance 14 25th-April-2006 12:45 AM
surge tank shaggy Drivetrain & Performance 6 1st-April-2006 02:14 PM
