manual to electric fuel pump - Chevy Nova Forum
Old 10th-January-2017, 10:03 PM   #1
vics63
Nova(s): 63 SS convertible
On a carbureted engine if I switch from a mechanical fuel pump to an electric fuel pump will I need to add a return line to the fuel tank if I don't currently have one. Or, do some electric pumps have a built in pressure regulator that starts and stops the flow as needed?
Victor
Old 10th-January-2017, 10:51 PM   #2
Roddychop
Yes there are a variety of in line electric fuel pumps that unload on their own when the float bowl is full. Usually you only need a return line to the tank if you are running EFI.
Why do you want electric ? I've never liked them because they sit there and groan if you have the key on without the engine running. You don't notice the noise when the engine is running.
Old 10th-January-2017, 10:58 PM   #3
Roddychop
It can be simple as this. You may need to modify your fuel lines depending on where you want to mount it.
http://www.jegs.com/i/Holley/510/12-427/10002/-1
Old 11th-January-2017, 12:03 AM   #4
Mike Goble
Mike Goble's Avatar
Nova(s): 67 wagon project
Put a normally open oil pressure switch in the control for the FPR and it won't start the pump until your engine has oil pressure.
I'm Mike Goble and I approve this message.
Old 11th-January-2017, 12:48 AM   #5
Mike Ward MB
Mike Ward MB's Avatar
Nova(s): 72 Nova SS 66 Beaumont S
I had an electric fuel pump on my 72 with no return line and it seemed to work alright. It was there when I bought the car. No matter what I did to the mount it made a noticable racket back there.
The electric pump is in the scrap bin and a nice equally functional, quiet mechanical pump will replace it.
72 Nova SS
66 Beaumont Sport Deluxe
Old 11th-January-2017, 01:07 AM   #6
hawkeyejim
hawkeyejim's Avatar
Nova(s): 1966 canso sd 66Canso 4dr
Had a Stewart Warner elec fuel pump on my car for years. Could barely hear it running standing beside the hood with engine off. Have had others that would shake the car and thump more than a lumpy cam!
Old 11th-January-2017, 02:37 AM   #7
vics63
I'm not committed to putting in an electric. Just considering the possibility. Wanted to understand how they regulated the pressure and couldn't find the answer I was looking for just searching electric fuel pumps. So if a pump is rated at 4 to 7 psi as the one from Jegs is, then it stops pumping when it reaches 7 psi? Why would you still hear it with the key on and engine not running. Seems like it would be just a quick blast to pressurize the line since the bowl's should already be full.
Old 11th-January-2017, 08:11 AM   #8
Stroker
Stroker's Avatar
Nova(s): '66/'67
I put mine on a switch after keyed power so I can listen to tunes or the pump itself without engine noise.
Old 10th-January-2017, 11:03 PM   #9
2K ONE
2K ONE's Avatar
Nova(s): 1967 2dr HT Pro Mod 3
electric fuel pump
You dont have to run a return line. It depends on the system you choose. I use an Aeromotive Street Strip "SS" series with their Dead head regulator.
You can contact Aeromotive through their website...
RD
Lets See Your Fuel Filter/Electric Fuel Pump Mounting Locations 62civa Drivetrain & Performance 11 4th-October-2015 09:16 PM
Electric fuel pump? novaray64 Drag Racing Forum 10 5th-August-2009 10:00 AM
electric fuel pump halfton 3rd Generation Chevy II/Nova's 27 9th-December-2008 10:23 PM
Electric fuel pump on v8 DesertDeuce Drivetrain & Performance 11 3rd-December-2008 12:09 AM
Electric Fuel Pump SlickVic107 Drivetrain & Performance 2 7th-November-2008 08:21 PM
