Steves 70 rebuild - Chevy Nova Forum
Old 5th-June-2011, 08:31 AM   #1
Steves 70SS
(OP)
Steves 70SS's Avatar
Nova(s): 1970 SS Crate ZZ430 Munci
Steves 70 rebuild
I finally found the motivation to start on my car. I just moved 8 months ago and have been very busy painting and getting things done around the new house. My plan four years ago was to just get it on the road for a while and then do a re-build on it but..... I am stripping it all down and will be re-placing all the sheet metal ect. I will post pics as I move along. shouldn't be that bad as I already re-built everything except the body. I did find a huge mice nest Tear down was two days. Should have the motor out this week.Can't wait to start on the body.
Steves70SS
Old 5th-June-2011, 08:46 AM   #2
ovrdrive
ovrdrive's Avatar
Nova(s): 1971 V-8 A/C car
Sorry to hear about the mouse nest.. But, it looks like a pretty straight forward approach to the body work...
Please keep us posted
1971 2-dr Nova A/C car 355 200-4R
Old 5th-June-2011, 09:11 AM   #3
snolan
snolan's Avatar
Nova(s): 1967 Sedan LS1/T56
Floor
Is that a hardwood floor ..in the garage.
Steve
1967 Sedan LS1/T56
Old 5th-June-2011, 09:30 AM   #4
chris63
chris63's Avatar
Nova(s): 1963 400 350/350 12 bolt
Nice looking project bud.
I can only imagine what your laminate floor is going to look like once you get busy on your ride. You might be back to more house work lol
Old 5th-June-2011, 09:38 AM   #5
Steves 70SS
(OP)
floor
The floor is Pergo. The room was used as a exercise room by the pre owner.
I will leave it down for now or until it gets beat up and then use a epoxy on the cement. Nice on the creeper
Steves 70SS
Old 5th-June-2011, 10:21 AM   #6
craigs73
craigs73's Avatar
Nova(s): soon to be pro-touring 73
watch when you welding it don't go up in flames anyways looks like a good start
Old 5th-June-2011, 11:54 AM   #7
Steves 70SS
(OP)
inside roof pics
After looking at the inside roof good, I was thinking about taking off the brown card board looking stuff and replacing it with Dynamat. It only has one small spot that I think got wet and came apart. Is this something I should change or leave it alone Summers can get hot and I don't want any thing falling down when I'm finished.
Steve
Old 5th-June-2011, 12:44 PM   #8
1quik69
1quik69's Avatar
Title: Moderator
Nova(s): 1972w/408,
The headliner material is a bear to get off. If you scrape it off be sure to wear a mask. From the looks of it I would just repair the one area and leave the rest. A friend of mine had the same thing in his camaro and we just used some spray insulation and spread it flat. That was 6 years ago and no problems yet. I installed reflectix on the roof of my 69, but the cardboard stuff was much worse than yours.
Old 16th-June-2011, 08:39 PM   #9
Steves 70SS
(OP)
Motors out
Spent a few hours this week taking out the motor and trans. I will be taking out the sub-frame next and tearing it down for sand blasting and paint. I'm thinking maybe Globel West on the upper and lower arms.
steve
Old 16th-June-2011, 09:54 PM   #10
Novaman Oscar
Novaman Oscar's Avatar
Nova(s): 72
good luck with everything
Finishing the nova for you dad
Old 19th-June-2011, 09:24 PM   #11
Steves 70SS
(OP)
More teardown
Spent some time today taking out the front and rear glass. My son helped me with a picture frame wire going back and fourth all the way around. Worked really well. I'm glad I pulled the glass as there are some spots that will need some work. I hope to have the rest of the dash out by the weekend. I'm thinking of renting a big compressor from taylor rental and buying a sand blaster and blasting it out in the back yard.Anyway here are some pics from today.
Steve
Old 19th-June-2011, 09:47 PM   #12
novanation69
Title: Nova Newbie
Nova(s): 69 SS Project
Are you going to replace or repair the dash? I ask because my car has similar dash rust and I was thinking of repairing it to avoid messing with the vin.
Old 19th-June-2011, 10:00 PM   #13
sbc1320
sbc1320's Avatar
Nova(s): 1972 Nova
If you are going to sandblast the car, be careful as the heat buildup and friction can warp your panels.
Old 20th-June-2011, 04:42 PM   #14
Steves 70SS
(OP)
Dash panel
Yes, I will be replacing the top panel with a new one. I think the rust is just on the top part. I will see more when I get it off. I checked with taylor rental today and they only have a commercial blaster. I think it will be too strong as he said I would have to stand back far.So I may just bring it some where to get it done.
steve
Old 20th-June-2011, 10:05 PM   #15
Steves 70SS
(OP)
Dash out
Spent a couple of hours tonight taking out the dash and heater box.
Talk about a rats nest. Can't wait till it's all taken apart. Should be done by the weekend I hope
Steve
