I have a 57 ford 9 inch rear with 11 inch brakes.I have the drums but no shoes or hardware.I'm having trouble finding shoes,local parts store did not have a number in there wagner book.The drums measure a little over 2 inchs wide so I put some 2 inch by 11 shoes off an old full size chevy car and they fit fine on the ford backing plates but the drums rubbed the shoes it liked about an 1/8 inch or less to seat on the axle.Does anyone have any ford brake info or sources and/or part #s for a 57/59 9 inch rear. Thanks
I had the same problem with an early Ford rear on the Durango Deuce so I went to the boneyard and got some 11x2.5's off a 70's Merc Marauder. I was told I had to send in the early shoes to have them re-built since there aren't any readily available at the store. I may still have the original drums and shoes.
super_davecars said:
My parts guy at Orielly's found some brake shoes for me.They are Brake Best brand part # 55. He had them in stock for $14 and no core charge they are 1 3/4 x 11 inch shoes.
Would I have to run a sixteen inch wheel to clear discs or is a 15 o.k. ?
I have seen various threads on ford nine inch , 8.8, s 10 , Versellas (spell check),etc.
Perhaps there should be something under "best of tech" or something for "rear ends for first gens " or something similar.
A = Mounting plate (center to center)
B = Backing Plate to Backing Plate
C = Wheel mounting surface (drum to drum)
I have a 62 , according to these specs its 57 3/4" Wheel mounting surface-Wheel mounting surface
Im wanting to do the lincoln 9" rear but wanted to get some input from you guys.
The specs say that its 58" Wheel mounting surface-Wheel mounting surface
Would it be a safe assumption to say that I can bolt it up with no issue ? since its only 1/4" difference total, yielding a 1/8" difference on each side.
The big difference I did see was 1/4" on the mounting plates so Im guessin this will be the only thing I will need to modify . Has anyone else used this rear end? Im just asking even though its a rare rear end. thanks
The Lincoln rear has a centered pinion where the Chevy II has 1/2" pinion offset. The Lincoln brake parts are getting hard to find and are pretty expensive. Wheel spacers would fix the width problem but you'd need longer studs. If you were changing studs you could have the bolt pattern redrilled to 5x4 3/4" Chevy pattern. The yoke would be easy to change but you need to remember that the 9" is 1" shorter from the axle CL to the u-joint CL. means the driveshaft slides out of the trans 1" more.
arent those rearends getting expensive ? like 6-800 bucks . SEEMS you can get any rearend and have axles made(forged) and housing shortened for the same cost ? I have used this rearend also ,but it was 15 years ago and it was expensive back then .
where to get pininon yoke with 4.5" depth as shown
How widely availible are the deeper pinion yokes? I checked ebay and saw about 1/2 dozen shorter ones will check locally and hit the junkyards but just wondering how availible they are.
i put the versailles rear in my 63 and it was pretty much a bolt in. there is a u-joint available that allows the chevy shaft to bolt to the ford rear. i thought it would be an easy way to get 4 wheel disc. then i bought a currie posi and super strong axles so i ended up with alot in it, but i don't regret it. strong rear that i should never have to worry about. the calipers and vented rotors are heavier than they need be tho.
The Mustang Boys will want that rear end big time.
It's a good unit.
I got a Detroit Locker for sale that will fit perfect!!!
The disc brake stuff is easy.
Any parts store will have it or can have it in day.
the parts are "W" class but not discontinued. They are the same on a lot of FORD vehicles.
It is just a plan in the near future. What do you suggest in using? What I really want to do is swap out the original rear end with something better.
thanks
There are certain ones that will bolt right in, like those from the late 50's sedans, the Versailles/Monarch setups from the late 70's, the early Mustangs, some Broncos, etc.
I swapped my stock one with a 9" out of a late 60's mustang. I have a 3rd gen though. I found an article in hotrod magazine listing the total lengths of the stock chevrolet rear end, also the ford 9" rears were listed. You probably could find it in their archives. The swap was very very easy. Used the factory chevrolet driveshaft. Had to have a brake hose made, the ford brake lines were bigger. I did this swap about 13 years ago. Installed a powertrax locker in it. I have been very pleased with it. That 9" takes whatever I throw at it.
Does anybody know what the axle offset is on a 9 inch ford with the 11 inch Torino brakes? It also has the housing ends with the 1/2 T bolts, I think they are Torino also.The reason I am asking is I found this brake kit on CL and want to know it it will fit my rear end/axles
You can buy that kit directly from Ford Motorsport for less money. I bought one to put on a narrowed 9" for my Nova. From what I remember, you have to have the big bearing ends. I used some from Mark Williams. The kit pretty much bolts on...uses Explorer calipers and E-brake setup that's kind of slick. I used Lokar E-brake cables to rig it up. If you have any questions, let me know.
Now, for around another $700 (or more depending on the options you want) you can have a nodular (BIG bearing) center section (I get mine straight through Canfield---same as the Moser since John sells 90% of them to Greg Mosier ), spool, 35 or 40 spline axles, a modified Daytona pinion support (for oil return), 4340 billet yoke and whatever gears you want.
Then, if it's all set-up right, you won't be able to hurt it on your BEST day.:yes::devil:
The down-side....Then the rear-end will weigh as much as the rear of your car!! I'm thinking seriously about sending my axles back and having them gun drilled and the flanges lightened. There's several pounds to be removed there!!
