3.42 or 3.73 with th350? - Chevy Nova Forum
Old 17th-May-2017, 10:04 PM   #1
copperbrown74
(OP)
Title: Nova Newbie
Nova(s): 1974 sedan
3,300 pound 74.
Sbc 350 with mild cam, vortec heads.
Th350 trans with 2400 stall converter
26" tires
Best posi rear end?
Most important thing to me is power off the line and when cruising at under 50.
Want good pairing with engine/trans/converter
Limited highway driving but don't want to blow up engine on highway.
Might change cam to slightly more aggressive one but not much and no other engine mods
Old 18th-May-2017, 06:34 AM   #2
kimrobertson
kimrobertson's Avatar
Nova(s): 79 Phoenix
DON'T KNOW ABOUT THE CONVERTER BUT WITH 3.42 AND 26" TIRES YOU SHOULD TURN ABOUT 3200 rpm ON THE HIGHWAY AT 70 MPH.
350/Tremec 3650 5 Speed/3.42
Old 18th-May-2017, 06:42 AM   #3
epfatboy
epfatboy's Avatar
Nova(s): 1964 Chevy Nova SS
3.73 for sure. I run the same combo and would not change in either direction.
If you change the cam change the converter to 3600. You might want to change the converter before the cam since you'll get a noticeable seat of the pants power increase.
Sent while texting and drag racing
'64 Nova
2015 Transformation
Old 18th-May-2017, 09:19 PM   #4
Nova_Guy
Nova_Guy's Avatar
Nova(s): 68 Chevy II SS
It will be 310 RPM at any given RPM with the 3.73 over 3.42 gears.
James
1968 Chevy II National Nostalgic Nova Member
Old 19th-May-2017, 10:03 AM   #5
novaboy009
novaboy009's Avatar
After 10 years of 3.73's, I went down to a 3.42 as I do a lot of highway/55 mph back road cruising. I don't think you can go wrong either way. The 3.73 is better from take off, the 3.42 is better on the open roads.
Based on your description, I'd lean towards the 3.73's.
Kev
78 Nova - autocross/drag/street car with nitrous
Old 19th-May-2017, 11:10 AM   #6
nova64000
nova64000's Avatar
Nova(s): 64 2 door Sedan
If you plan to drive it mostly under 50 mph, go with the 3.73! The 3.42 would be more beneficial on the highway...
Do you know your cam specs? Some cams would be more preferential to the 3.73.
Old 19th-May-2017, 03:05 PM   #7
cdahl383
cdahl383's Avatar
Nova(s): 1972 Nova
Garage
I'd go with 3.73 based on the info you provided on what you want from the car.
Carl
1972 Chevy Nova owned since I was 15 yrs old
12.36 @ 109.65mph w/ 1.72 60ft
Old 20th-May-2017, 12:30 PM   #8
bowtie0069
bowtie0069's Avatar
Nova(s): 69
3300 seems a bit low for a 74. Is it a no power steering, no power brake strippo model?
My 69 weighed 3140 with a 6 cylinder/3 spd. manual trans, no options, no carpet, nothing! That was on a certified truck scale.
69 Nova 410" small block-Driven to track
6.39 E.T./105 MPH--6.11/112.89 w/N2O
PG to TH350 kirk69nova Drivetrain & Performance 9 26th-October-2010 12:31 AM
th350 going in my '62... need some help Nikwho Drivetrain & Performance 1 1st-March-2009 06:48 PM
Converting th350 to powerglide? Blew up my th350 gr8ride_71 Drag Racing Forum 9 14th-October-2008 09:39 PM
