Crossmember for a T56 in 66 hardtop - Chevy Nova Forum
Old 16th-April-2017, 09:37 PM   #1
ruggerdrisc
(OP)
ruggerdrisc's Avatar
Title: Nova Newbie
Nova(s): 1966 1974 (sold)
I just finished installing an LS3 and T56 in my 66 hardtop this weekend. Can you recommend a crossmember that works with the least amount of fabrication? What did you use? Thank you! Brian
Brian
1966 Chevy II Coupe
Speedway Motors G-Comp Clip w/ 6 piston
Moser 9in w/ 4 piston
Old 17th-April-2017, 06:02 PM   #2
ruggerdrisc
(OP)
Title: Nova Newbie
I made a few calls... American Powertrain has a brand new modular crossmember designed for early Novas. It should be available to order middle of next week.
Brian
1966 Chevy II Coupe
Old 17th-April-2017, 06:26 PM   #3
Highroller54
Nova(s): 1964 2dr seeeedan
Are you happy with the speedway clip? Anything you don't like? I need to order a clip asap.
Old 19th-April-2017, 06:51 AM   #4
ruggerdrisc
(OP)
Title: Nova Newbie
So far so good. I haven't tried to re-install the down tubes that connect to the firewall and clip now that the engine is in. I'm concerned there is not enough room once the accessory drive is installed.
Brian
1966 Chevy II Coupe
Old 19th-April-2017, 03:06 PM   #5
Highroller54
What do the upper spring pockets look like? Is it just a flat plate with a hole for the shock? Or is there a piece of tubing welded in that goes inside the spring or maybe outside?
I've seen some people bitch that they are noisy. What I was wondering is if a guy could put a polyurethane upper mount/spacer on top of the spring.
Old 19th-April-2017, 11:55 PM   #6
ruggerdrisc
(OP)
Title: Nova Newbie
I'm almost certain it's just a flat plate as you describe but I can look again and confirm. I haven't been able to drive it yet so I can't comment on noise.
Brian
1966 Chevy II Coupe
Old 20th-April-2017, 12:36 AM   #7
Highroller54
I appreciate that! I'm not sure a little noise would bother me anyways lol. What size are your front tires?
Old 21st-April-2017, 01:14 AM   #8
ruggerdrisc
(OP)
Title: Nova Newbie
255/35 on 18x9 wheels
Brian
1966 Chevy II Coupe
Old 21st-April-2017, 09:04 PM   #9
Highroller54
Do you think I will have troubles with 17x9? I'm worried the smaller wheel will rub the control arms on tight turns. I have no clue how much room is in that area though.
T56 tranny crossmember Bmac Steering, Suspension, and Chassis 1 20th-July-2015 08:22 PM
T56 tranny crossmember question romancommander LSx Forum 71 26th-January-2015 10:02 PM
T56 Crossmember Perple76 4th Generation Nova's 12 25th-March-2008 09:44 AM
'66 T56 crossmember Novadream Drivetrain & Performance 4 28th-November-2007 04:11 PM
