Ridetech Coilovers in a TCI front Clip - Need Assistance - Chevy Nova Forum
Old 20th-March-2017, 06:31 PM   #1
patrickjlanahan
(OP)
patrickjlanahan's Avatar
Nova(s): 1967
Garage
I recently purchased a 67Nova that has an older version (2010 era) TCI front Clip with RideTech Adjustable coilovers. I need some help!!!
The mounting bracket for the coilover is on the front clip is 1 inch wide, top and bottom. The Coilover has a spherical bearing rod end with a one inch wide mounting bracket. Its held in place by a 5/8 inch mounting bolt.
However, the coilover rotates, due to the spherical bearing, and as such the rod end hits the mounting bracket. The noise is pretty awful particularly on bumpy roads, changing from forward to reverse etc.
I spoke with TCI and they told me the bearings were worn. I ordered new spherical bearings, but that is not the issue. The bearings are operating just as they should be.
I also spoke to RideTech, and they are shipping me a metal spacer.
In the mean time I've been trying to find threads on this site with additional info. From everything I read, the spherical bearing needs to move to prevent binding.
From some of the pictures I've been able to see on this site it appears there should be some type of a bushing to prevent the rod end from itting the bracket, but still allows the bearing to move??
I've attached a couple of pics. One that shows my coilover mounted, and as can be seen the contact it makes with the mounting bracket.
The other with it unmounted so to show there is no type of bushing, just a spherical bearing allowing metal on metal contact between the rod end and the mounting bracket.
Would enjoy some feedback.
ID:	284689   Click image for larger version
Name:	upper coilover.jpg
383 Stroker
Old 20th-March-2017, 07:43 PM   #2
rebob
rebob's Avatar
Nova(s): 63 no post
Garage
Mines the same as yours but with TCI's single adjust shocks, I just cut some thin rubber washers to go around the sheaves and cushion the shock body from the mount. I think The rubber is soft enough that it doesn't bind.
Rick
63 coupe LS2, T56, TCI
Old 20th-March-2017, 08:25 PM   #3
patrickjlanahan
(OP)
Nova(s): 1967
Garage
Very cool, Rick. Thanks for the photo. Yes, appears I have the same single adjustable shock you have. Perhaps I'll make some spacers same as you have made if I'm not satisfied with the spacers that Ridetech sends.
Assuming your spacers provide enough absorption that your coilovers dot rattle around?
383 Stroker
Old 20th-March-2017, 09:49 PM   #4
rebob
rebob's Avatar
Nova(s): 63 no post
Garage
No rattle, it's just what I came up with at the time, they've been in there a few years.
Rick
TCI front clip coilover issue Need Assistance patrickjlanahan Total Cost Involved Engineering Inc. 2 16th-March-2017 01:42 PM
Front mounted battery with a TCI (or other) front clip. NIGHTSHADE 1st & 2nd Generation Chevy II/Nova's 3 17th-May-2016 07:37 AM
Front mounted battery with a TCI front clip. NIGHTSHADE Total Cost Involved Engineering Inc. 0 7th-May-2016 06:44 PM
tci front clip help yeah baby Steering, Suspension, and Chassis 1 18th-May-2010 06:16 PM
