Missing E brake parts? - Chevy Nova Forum
Old 21st-September-2016, 10:23 AM   #1
busmania
(OP)
Nova(s): 65 nova post
This might be in the wrong section...if so, I apologize.
My 65 came to me in parts and pieces and the e brake cables are just hanging on the ground. I am working on getting the ebrake fixed so I can finally take it for a test drive.
Right now I have a cable that comes from under the floor up front. Inside the car, the end of the cable has a round end/ball on it. Where does this connect to the handle?
http://s924.photobucket.com/user/riv...tml?sort=3&o=0
Second, that single cable runs out the floor and then has a half moon on the end where I assume the two e brake cables attach. But the rear wheel cables are not long enough for it all to meet in the middle. What pieces are missing? Does the single cable connect the two cables in the middle or towards one side of the car?
end of cable from under dash
http://s924.photobucket.com/user/riv...tml?sort=3&o=4
right side
http://s924.photobucket.com/user/riv...tml?sort=3&o=2
left side
http://s924.photobucket.com/user/riv...tml?sort=3&o=1
Lastly, do my pictures show up in the thread for you? They do not for me (Ive tried imgur and now photobucket) which is why I also include the links to them.
As always, thanks for helping this newbie get his nova on the road.
65 2 door sedan
Old 21st-September-2016, 10:30 AM   #2
sbc1320
sbc1320's Avatar
Nova(s): 1972 Nova
Don't know that body style, but pretty much the same as mine probably.
Anyways you need the metal link(2) on each side of rear cables. This will allow you to join to the main cable which is missing. This main cable hooks into your half moon piece where you have your adjustment. The half moon piece hooks to the drivers side area of the main cable and the opposite passenger side should have a metal rod/hook that supports the other side of the main cable. So essentially the main cable comes around like a U as it goes from one rear cable and around to the other rear cable.
72 Nova 383
72 Nova 383(11.70s)
71 Nova 406(11.60s)
71 Nova 350
70 Nova 350
Old 21st-September-2016, 10:58 AM   #3
sbc1320
sbc1320's Avatar
Nova(s): 1972 Nova
Looks like you are copying the first one that says "Email & Im".
You need to click on the bottom or 4th box -"IMG" and your pictures will show up.
72 Nova 383
72 Nova 383(11.70s)
71 Nova 406(11.60s)
71 Nova 350
70 Nova 350
Old 22nd-September-2016, 02:26 PM   #4
busmania
(OP)
Thanks to both of you. I am starting to get a visual...
I went to the junk yard and the oldest car they had was a 70 impala. I took the U shaped cable (probably too long), the equalizer bar and some hooks.
Can anyone just snap a quick picture to me of the stock e brake cable set ups underneat your car? I am happy to give you my phone number if texting a pic to me is easier. I just need a visual of the set up and google is of no help.
65 2 door sedan
Old 22nd-September-2016, 03:48 PM   #5
jd128
jd128's Avatar
Nova(s): Counterfeit 67 SS
Here's a link to the 67 Assembly manual...UPC 5 sheets C1, C2, and C3 show the parking brake installation.
http://www.novareference.com/manuals...ly/Part5&6.pdf
JD
64 2dr Post 194 3spd->283 4spd - Sold
77 4dr 305 at - Sold
67 Coupe 350/400hp 4spd 3.36Posi
Old 22nd-September-2016, 04:45 PM   #6
busmania
(OP)
JD, thank you! That helps a lot.
It would appear I am missing this bracket (Circled in red on my pic below).
Does this bracket mount to the floor or does it hang via the tension in the lines? anyone got a picture?
http://imgur.com/a/QvE5a
65 2 door sedan
Old 22nd-September-2016, 04:54 PM   #7
SCHWABIE
SCHWABIE's Avatar
Nova(s): 2-'63ss verts '64 rt wgn
that bracket is welded to the floor , I have one here I may be able to cut it off this weekend
NOROOF & LONGROOF SOCIETY
SAWZALL SYNDICATE
Old 22nd-September-2016, 05:07 PM   #8
busmania
(OP)
Thanks. Yeah, my floors were mostly replaced by the PO so id bet a nickel he "forgot" to reattach the bracket...and that is partly why I am so confused. I think I got it now though as far as how it is set up.
65 2 door sedan
Old 22nd-September-2016, 05:28 PM   #9
jd128
jd128's Avatar
I drove my car to work today so a took a couple pictures...it looks like I forgot to put the retaining clips back on...need to do that when I get home. Apparently they have been off for a year!
JD
Old 23rd-September-2016, 09:45 AM   #10
busmania
(OP)
Alright alright. Now I'm getting somewhere.
From my last picture, you can see I DO still have the bracket at the rear. It is ont he left side, just forward of the rear wheel.
LAST question on this (maybe). Rears were converted to disc brakes. The line coming out of the passenger side is not nearly long enough to reach that bracket on the left side. How do I extend it? Or, should I make a new bracket in the middle of the car?
this picture shows I do in fact still have the bracket.
65 2 door sedan
Old 6th-October-2016, 09:36 AM   #11
busmania
(OP)
Update for anyone that stumbles upon this in the future (I hate searching threads and reading the entire thing only to find the op never came back to tell what fixed the problem).
You all probably knew this already but the cable that comes from the rear wheels is ONE cable, not one cable each wheel like in my original pictures. I ordered the cable and after a few mods to the ebrake cable coming from inside the cab (it wasn't long enough, or the rear cable was too short), I have an e brake.
Almost time for a drive.
65 2 door sedan
Old 20th-March-2017, 07:10 PM   #12
tlharris1
Title: Nova Newbie
Nova(s): 1963 SS
I have a 63 SS HT that too is missing E-Brake parts. I need the E-Brake cable guide (3991966)and clamp (3791967) that is located under the drivers side floorboard. In addition I need the clip (3791130)that clamps the rear passenger E-Brake cable to the rear end/pinion bumper bracket. If anyone could point me in the right direction, I would thankful.
Old 21st-March-2017, 07:30 AM   #13
acd65post
acd65post's Avatar
Nova(s): 65 Two Door Post
First off welcome to the site. You should be able to get most of the parts through Chevy II Only, Walts Classic Novas or you can post an add in the wanted section here but I think there is a minimum post count ( or perhaps that is just if you are selling.)
Old 21st-March-2017, 10:44 AM   #14
tlharris1
Title: Nova Newbie
Nova(s): 1963 SS
E-Brake Parts
Thank you, Nova Guru.
Parking brake missing..... josh1076 Steering, Suspension, and Chassis 4 17th-October-2014 01:18 AM
Missing brake fluid burns Drivetrain & Performance 6 2nd-June-2009 11:56 PM
Is it just me or do I have some parts missing.......? 3-Pedal Post 1st & 2nd Generation Chevy II/Nova's 8 18th-March-2009 09:45 PM
missing parts I think kceb10 Steering, Suspension, and Chassis 9 13th-April-2006 05:21 PM
The missing parts! chevynuts88 Body and Interior 2 24th-March-2006 08:36 AM
