Looking for input on posi, gear, and axles - Chevy Nova Forum
Old 19th-March-2017, 09:40 PM   #1
Mwilson904
Nova(s): 1972 project
About to pull the rear end out of my project, the axles have "value line" cast on the end, so I'm guessing they're not the best, the posi unit was posted earlier and determined it needed to be changed. I plan on dropping it off somewhere to just have it done. Plan to have it as a street/weekend car. Has a 502 in it with approx 520 hp (allegedly) has a th400 trans.
Please give me recommendations on good but reasonable:
Posi unit
Gear ratio
Axles
I'm guessing it's a 8.5 but don't think that matters if I'm having them change everything, here are some pics.
Any input will be appreciated
Thank you
Click image for larger version
ID:	284609   Click image for larger version
Old 19th-March-2017, 09:58 PM   #2
Nova(s): 1972 Nova
Eaton 30 spline posi
Moser 30 spline axles
3.73 gears if it's a weekend warrior
72 Nova 383
72 Nova 383(11.70s)
71 Nova 406(11.60s)
71 Nova 350
70 Nova 350
Old 20th-March-2017, 07:54 AM   #3
xMLMx
xMLMx's Avatar
Nova(s): 1969 Nova
Eaton limited slip rear differential. Great bang for the buck.
Richmond gears. Do not cheap out on gears- pay a little extra for the good stuff.
Moser axles. With the kind of power and torque that 502 will be turning out, good axles are good insurance.
Old 20th-March-2017, 06:24 PM   #4
JBimmolate
JBimmolate's Avatar
Nova(s): To be determined...
The Value Line axles are a little better than original factory axles or so they claim. I have installed a few over the years and have not had any issues but they are on the cheap end of the spectrum. I would run either Moser, Dutchman, Toms or Sierra axles. Eaton posi units are very good and as for gears I prefer US Gear (not USA STD), Motive, Sierra, or something along those lines, not a huge richmond fan except for drag applications.
Miles
" The Resident Differential Guy, Have A Question? Just Ask! "
11/2016 FastEddie, he will be missed
Old 21st-March-2017, 08:07 PM   #5
Mwilson904
Eaton 30 spline, moser axels, and a decent 373 gear is the route I'll go.
I believe the housing has been powder coated, or painted very well, I found a local shop online and called them, they seemed to really want me to upgrade to a 12 bolt, but I think the 8.5 is fine for what I need.
I would have them purchase the parts, when I told the guy I wanted the eaton posi, moser axles, and a some decent 373 gears, he said the gears come with the Eaton posi unit? I've never heard of this before, maybe with the moser axles, or he misunderstood so I'll wait until he calls me back with pricing and info.
I would be bringing the shop the unit.
I'm guessing in the $1500.00-1600.00 range?
Posi 500, axles 250, gears 250, bearing etc 50, 450 labor?
Does that sound about right? +/- $100 or so.
Old 22nd-March-2017, 10:02 PM   #6
70chevybb
Nova(s): 72 ss
rear end
I j u st installed this exact set up I n my 72 the 396 4 speed. Great combo
Old 22nd-March-2017, 10:43 PM   #7
Nova(s): 1972 Nova
I did the 4.11's, but that 3.73 gear is hard to beat. My buddy did a 3.90 gear. You can get a good deal on the posi on Ebay at times. I want to say I paid $420 for my Eaton posi.
72 Nova 383
72 Nova 383(11.70s)
71 Nova 406(11.60s)
71 Nova 350
70 Nova 350
Old 25th-March-2017, 12:26 AM   #8
Mwilson904
Ugh.
I pulled the rear and took it to a local shop, the guy pulled the case off and said that he'd just run it, no need to change.
I went by a classic restoration shop and they didn't pull the case and just said that I will shatter it, so I should just sell it and buy a Ford 9"
He Said I could find a new one, moser or Currie for about 2k.
I called moser, they're about $2,700.00
Soooo, I'm putting it back in for now, measure for a drive shaft and get that ordered (don't have one) and I'm going to stick with the plan for the Eaton, Moser and gears, utilize the casing and order the parts when I find someone local that comes recommended, I need to make some local connections and find a shop.
Oh well, I wanted to pull the leafs to put on the (Camaro) new spring eye brackets anyway.
Old 25th-March-2017, 12:33 AM   #9
pk64f100
pk64f100's Avatar
Nova(s): 1964 nova II 400 350 hp &
I purchased new Ford 9 from Quick Performance nice set up.
Old 25th-March-2017, 12:52 AM   #10
skylarkjohn
skylarkjohn's Avatar
Nova(s): 75 Nova
Being an old Ford mechanic I go with the 9in. No laying on your back to work on it, easy to set up and it's stronger than any 10 bolt
Las weak I cudn't evon spel machenik...now I r 1
posi gear lube for 8.2 rjy Steering, Suspension, and Chassis 3 14th-April-2014 01:47 PM
Posi rearend gear check PetraNova Drivetrain & Performance 10 18th-December-2011 09:32 PM
Gear Oil in Eaton posi? childo74 Drivetrain & Performance 7 20th-May-2010 02:06 PM
Should I change gear ratio with posi? 62bandwagon Drivetrain & Performance 4 4th-September-2006 01:59 AM
