Whats the best way to install valve cover gaskets? - Chevy Nova Forum
Old 9th-December-2008, 12:19 AM   #1
batman09
batman09's Avatar
Nova(s): 1967 LS3 & 1962 LSX wagon
Whats the best way to install valve cover gaskets?Anyone got any good tricks to keep them from leaking?Also which are the best...Cork?thanks bm
1962 Nova wagon-----Lsx/4L60e
1967 Nova---LS3/4L70e
Old 9th-December-2008, 12:26 AM   #2
The Big Al
The Big Al's Avatar
Nova(s): 68ss, 70ss (SOLD)
I have a set of the blue Moroso gaskets i know are at least 5 years old. Never leak, and don't have to use any goop!
They have been off & on many many times.
Also your new AFR heads have raised gasket surface and a good machined area.
I say no gasket sealer needed. And get a quality gasket.
AL
“The bitterness of poor quality & Service remains long after the sweetness of low price is forgotten”
Old 9th-December-2008, 01:55 AM   #3
Seattle_Mike
Seattle_Mike's Avatar
If using cork one's I usually use some 3M weatherstrip adhistive and glue themto the valve cover and then put a little grease on the gasket before putting them on the engine...has worked for me for years. On the race car we use the blue Moroso's since they are going on and off all the time.
33 Ford 3 Window 468ci BBC
68 Camaro ProMod 848ci Buck Racing Engines Nitrous
Old 9th-December-2008, 01:59 AM   #4
ALLT4
ALLT4's Avatar
Nova(s): 1977 Concours ZZ383
If you have stamped valve covers usually I'll tack the gasket here and there to the cover's lips. Not too much though because it's a PIA to get off the cover then. Also some spreaders to spread the load helps.
If they're machined covers, don't sweat it, just get 'em on and tighten them down a little. I agree with AL also here, rubber type valve cover gaskets do a much better job and are reusable.
Old 9th-December-2008, 02:04 AM   #5
JRouche
JRouche's Avatar
I dont remove my valve covers so once they are set Im fine. I use a very thin skim coat or gaskacinch (sp?) on both sides. Let it dry up completely then assemble. No leaks, but I have stiff valve covers too. JR
Old 9th-December-2008, 08:55 AM   #6
veno
veno's Avatar
Nova(s): 72 385, t350, 3.73 4w-dsk
I have tried many a gasket, cork, Neoprene, MLS rubber steel, the felpro preformed rubber steel, many.... and always come back to the thick cork.... I use a skim coat of silicone on the cover, apply the gasket and lay flat with my motors manual on top over night...
a nation of free men, shall live forever, or die by suicide
Old 9th-December-2008, 10:32 AM   #7
bowtie0069
bowtie0069's Avatar
Nova(s): 69
The Fel-Pro rubber/steel have been on my last few engines (same set) no sealant needed. Stiff cast covers make a difference; my old Moroso lightweight stamped aluminum ones flexed so much they were hard to seal.
But in my slimeball engine compartment it's hard to tell where it comes from!!
69 Nova 410" small block-Driven to track
6.39 E.T./105 MPH--6.11/112.89 w/N2O
Old 9th-December-2008, 12:15 PM   #8
67 church
67 church's Avatar
Title: Supporting Vendor
Nova(s): 67 2dr hrd top, 2-63 wags
I have done everything listed above also. What I found is that a good cast valve cover is the best start. They don't warp or bend when they are tightned down. The only sealant I use now is between the valve cover and gasket, but I also have aluminum heads with a nice flat rail. Don't over tighten the cork gaskets or they will split.
Chuck Church
330-442-7162
Made in the USA
Old 9th-December-2008, 12:15 PM   #9
Ironman
Ironman's Avatar
Never could get a cork gasket to seal...until I stopped over tightening them...problem solved.
10.87 at 119 on the brakes 400 SBC pump gas, flat tappet cam, small tire.
Old 9th-December-2008, 07:05 PM   #10
64PRONOVA
64PRONOVA's Avatar
Nova(s): 64SS & 65SS
I also like the extra thick Felpro (1/4") cork valve cover gaskets. I apply a thin bead of Permatex red to the valve covers and glue them on. Gaskecinch will work too. Only apply the stuff to the valve covers though or your gaskets will be a one-shot deal. You want them to come-off with the valve covers and not stick to the heads.
The thick gaskets are necessary with certain intake manifolds that interfere with the flange on the valve cover. They raise the cover up higher so the flange doesn't touch the intake when you tighten them down.
I remove the valve covers on my engines periodically to adjust valve lash and they come right off nice with the gasket in place on the valve cover. The gaskets last for years and can be removed many times. Best of all, the don't leak no matter what type of valve covers you're using.
Old 9th-December-2008, 09:47 PM   #11
Boosted74
i jsut use the steel core this rubber ones. i reuse them all the time, a couple years old. if you use cork, make sure to use it dry. a lot of people add silicone, but silicone doesnt grip cork so it wont be long until it poops out.
Old 9th-December-2008, 11:42 PM   #12
Duane
Duane's Avatar
Nova(s): 66 2DR POST LS1
all the above work.
But one thing I haven't seen mentioned is the use of studs over bolts.
I have always used studs, place gasket on so the gasket is centered, palce cover on, tighten cover with nuts and washers evenly.
Or you can go with an LS motor which has a nice preformed press-in o-ring style.
66 100 series,LS1/4L60e,TCI,9" Currie,Tru-trac,4wh disc, Caltrac bars, VAir Gen IV, DDigital VHX dash.
Old 9th-December-2008, 11:54 PM   #13
283nova
283nova's Avatar
Nova(s): 64 hardtop
i take a wire wheel or some fine grit sand paper or emery paper to the valve cover where the gasket is suppose to go wipe it off, and i apply a gneours amount of HI-TAK let it sit for a minue or 2 and put the gasket on and turnt he valve cover over and put a couple of weight thigns on top of it and let it sit for 10-15 minutes to cure and it seales the valve cover to the gasket then i use a thin film of axle grease or black rtv on the gasket to head side. never had one leak on me. also i do not tighten the snot out of them
Old 11th-December-2008, 06:48 PM   #14
68chevyll
68chevyll's Avatar
Originally Posted by Duane View Post
all the above work.
I use studs with the Blue Morosos. No sealer at all. no leaks here.
valve cover breather 40buickcoupe Drag Racing Forum 5 5th-January-2012 05:18 PM
Breather or no breather 40buickcoupe Drivetrain & Performance 66 13th-October-2008 05:23 AM
pcv, valve cover question fosheezie Drivetrain & Performance 9 18th-June-2008 04:27 AM
How important are valve cover breathers? Scooter Drivetrain & Performance 22 18th-April-2006 11:54 PM
Valve cover spacers 9second yenko Drivetrain & Performance 4 6th-April-2006 11:02 PM
