Rear springs - Chevy Nova Forum
Old 7th-December-2012, 04:10 PM   #1
utterson
utterson's Avatar
Nova(s): 1966 Nova SS
Rear springs
A little info. If I change from a mono leaf to a mult. leaf on my 66 do I have to change the bracket on the rear end housing?
Old 7th-December-2012, 04:17 PM   #2
Nova(s): 1972 Nova -383
Different car(71 Nova) same concept though. Only thing I had to do was enlarge the locating hole in the spring perch for the leaf spring centering pin. I had a 1/4" shank drill bit by 1/2" drill size.
I guess a person could clamp the springs together and unscrew that pin and grind it smaller if need be, but I just enlarged the locating hole which could be done with a small die grinder and carbide bit.
I am sure someone with a 2nd gen will chime in for you, but I say it should work like mine did.
72 Nova -383, AFR 195s, Lunati #60113, 11.70s, next pass will be an 11.50
Old 7th-December-2012, 06:41 PM   #3
nova656567
Nova(s): D/D: 65 Hardtop 65 SS, V
Not normally, but might vary depending on the manufacturer. Some you need to trim the sides off of the pad.
Walt
Old 7th-December-2012, 06:46 PM   #4
the FLYER
the FLYER's Avatar
Nova(s): B Pillar of Society
on the 3 leaf multi's the plate will fit perfect to the housing without the use of the pads. if a traction control device is to be used (such as CalTracs) remove the pads anywho... Calvert Racing recommends their removal...
'64 411 377-Tko600-3:73's
'64 469, '63 435 (projects), & '63 469 (my driver)
Videos~Albums
Old 2nd-January-2013, 01:25 PM   #5
bestpart
bestpart's Avatar
Nova(s): 1964 Nova SS
Rear Springs
Go with Eaton Detroit, you will have to change nothing...
Rear Springs davemfl Steering, Suspension, and Chassis 5 12th-January-2012 12:39 PM
rear springs halfton Steering, Suspension, and Chassis 1 7th-August-2008 02:02 AM
rear springs chevbombs Steering, Suspension, and Chassis 3 15th-July-2008 01:57 AM
New rear springs bleedchevyorange Drivetrain & Performance 3 4th-May-2008 08:59 AM
A REAR END DEBATE: floating (pinless) springs and the dangers of the rear moving FunkyNova66 Steering, Suspension, and Chassis 16 6th-October-2006 10:29 AM
