Retrofuel 2010 Camaro fuel pump kits and complete tanks for EFI and LS applications - Page 3 - Chevy Nova Forum
Go Back   Chevy Nova Forum > Classified Ads > For Sale Ads > 1962-67 Chevy II parts
Old 2nd-November-2012, 11:41 AM   #31
Power
Nova(s): 67 Nova
I received on of theses complete tanks last week. all I can say is "WOW".. very nice piece and the customer service and price were right on point.
1967 LS3 T56
Old 2nd-November-2012, 01:38 PM   #32
66 BADBOY
66 BADBOY's Avatar
Nova(s): 5 all in 1
Thanks for the good words man!! Nice dealing with you
SHE'S ALIVE!!!
Old 2nd-November-2012, 02:14 PM   #33
Power
Nova(s): 67 Nova
Mine will be running in two wks!!!
1967 LS3 T56
Old 2nd-November-2012, 02:40 PM   #34
66 BADBOY
66 BADBOY's Avatar
Nova(s): 5 all in 1
Originally Posted by power View Post
mine will be running in two wks!!!
sweet!!!!!!!!
SHE'S ALIVE!!!
Old 9th-November-2012, 01:28 PM   #35
Pragmatist
Pragmatist's Avatar
Originally Posted by Nova 404 View Post
Hey Barry, Where can I get some of these fittings to connect the factory quick lock to an AN fitting? Thanks
66 & 67 hard top, Work in progress
http://s116.photobucket.com/albums/o30/argrandawg/
Old 12th-November-2012, 07:38 AM   #36
66 BADBOY
66 BADBOY's Avatar
Nova(s): 5 all in 1
They are Russel parts. Summit or Jeg's carry them. I can dig out the PN when I get my paperwork back in front of me, but they list them on the Russel site under Specialty EFI fittings. I've heard a lot of bad stories about the push on type, and followed those stories through until Russel came out with the two piece screw-together type, which is the one I use/sell.
SHE'S ALIVE!!!
Old 12th-November-2012, 11:10 AM   #37
Nova 404
Nova 404's Avatar
Title: Supporting Vendor
Nova(s): 1967 Nova SS
They are available in blue or black in -6 and -8 AN size.Be sure to get the screw together type NOT the plastic clip type.
-6 blue
http://www.summitracing.com/parts/rus-644120
-6 black
-8 black
http://www.summitracing.com/parts/rus-644133/overview/
Member of the NorCal Brotherhood!
Old 14th-November-2012, 09:27 PM   #38
66 BADBOY
66 BADBOY's Avatar
Nova(s): 5 all in 1
Looks like we will also be offering a ZL1 pump option as well in the near future. Gotta get one here to be 100% sure it will work fine with the pickup setup.
SHE'S ALIVE!!!
Old 20th-November-2012, 01:23 AM   #39
theomms
What is a ZL1 pump?
Old 20th-November-2012, 08:55 AM   #40
Nova 404
Nova 404's Avatar
Higher flow rated pump out of the new super charged Camaro.It will support more HP than the standard Camaro pump.
Old 7th-December-2012, 04:01 PM   #41
66 BADBOY
66 BADBOY's Avatar
Nova(s): 5 all in 1
ZL1 pump was delivered today. Only exterior difference is that there is an extra siphon jet on the bottom that is directly across from the location of the original siphon jet that is the same on the LS3 pump. This will do a nice job of keeping the bucket full longer due to the pump's higher fuel capacity.
It is a higher output pump that is recommended to be used with a PWM, however I have read about people that have been successfully running them with an internal regulator system. I do not have any firm data on the effects on pump longevity.
Also adding a different setup for the wiring harness to the product line. Connections for the sending unit as Delphi will be wired to a 4 pin flat male Weather Pack connection with a 4 pin flat female Weather Pack connection plugged into that with 12 gauge pump power leads and 16 gauge sending unit leads coming out to connect to the customers wires. This will allow easier installation/removal of the tank without putting stress on wires or connections.
Pics to follow real soon.
SHE'S ALIVE!!!
Old 12th-December-2012, 05:31 PM   #42
66 BADBOY
66 BADBOY's Avatar
Nova(s): 5 all in 1
ORIGINAL POST UPDATED AS WELL
New harness setup (P/N PHARN): $75 Sending unit ends are crimped and then heated. The insulation is a shrink tube type with a small bead of solder inside. The shrink tube shrinks up when heated, and the solder then melts and offers a more reliable connection than just the crimp. Sending unit wires are 16 gauge, and the pump power/ground are 12ga. Overall length is approximately 24 inches long.
P/N ZL1: $85 additional to DIY kit price or complete tank price. ZL1 PUMP NOT YET READY FOR SALE WITH DIY KIT OR COMPLETE TANK
Here is the bottom of the ZL1 pump (pump on the right). You can see the black connection tube that links the extra bottom siphon suction to the jet pump. This pump is the exact same size as the LS3 2010 Camaro pump (pump on the left). I have NOT designed the pickup tube connections for this one yet. It may not be necessary to modify this pump like I do for the LS3 pumps due to the extra bottom siphon that will naturally be located at the front/lowest portion of the tank. I will follow up with the details of that soon.
P/N VENT: $15 Stainless 3/8 female NPT vent bung can be added along with the DIY kits as a separate piece.
P/N VENTWELD: $30 Vent bung welded into a complete tank. P/N VENTWELD. Includes the vent bung as well as the weld-in installation.
SHE'S ALIVE!!!
Old 13th-December-2012, 01:45 PM   #43
GerryLP
GerryLP's Avatar
Nova(s): 71 427 Acadian, 63 Wagon
Badboy (Bryan??),
Have you though of working on an increased capacity fuel tank for 3rd Gen's???
12 Gallons is not enough, as you may imagine, and adding another 4 or 6 gallons should not be a huge addition in volume size. What do you think? Plus, it would give you an "in" to leverage your electric fuel pump kit into one of them.
Even when the 307 was installed, 12 gallons was not enough because on a long trip, I had to fuel when hitting my last quarter tank of fuel. Now with the 427, that will come sooner.
GerryLP
Old 13th-December-2012, 05:44 PM   #44
jimr38
jimr38's Avatar
Nova(s): 1972 nova
Originally Posted by GerryLP View Post
Badboy (Bryan??),
12 Gallons is not enough, and you may imagine, and adding another 4 or 6 gallons should not be a huge addition volume size. What do you think? Plus, it would give you an "in" to leverage your electric fuel pump kit into one of them.
Even when the 307 was installed, 12 gallons is not enough because on a long trip, I had to fuel when on my last quarter tank of fuel. Now with the 427, that will come sooner.
GerryLP
i would be interested in one of these bad boys for my 3rg gen too...please make one...
Old 7th-January-2013, 08:59 AM   #45
66 BADBOY
66 BADBOY's Avatar
Nova(s): 5 all in 1
Sale pending on the last tray kit in stock. Currently waiting on the supplier to return a quote for the 68-72 A body setups along with the next order of Nova setups. Probably looking at a 4 week lead time before the next round will be delivered to me and then the time for me to put the kits together.
SHE'S ALIVE!!!
Fuel On Demand pump controller and a 2010 Camaro pump 66 BADBOY LSx Forum 19 30th-July-2012 11:32 PM
Anatomy of a 2010 Camaro fuel pump (PICS) 66 BADBOY LSx Forum 30 14th-February-2012 01:29 PM
Fuel Tanks & Pumps for Fuel Injected Novas? SteveM Drivetrain & Performance 7 4th-September-2009 11:00 PM
Fuel tanks for fuel injection conversions? SteveM Drivetrain & Performance 4 18th-December-2006 10:47 PM
