1st Gen Pull the motor with or without tranny? - Chevy Nova Forum
Old 4th-December-2012, 01:23 AM   #1
PldBryan
PldBryan's Avatar
Nova(s): 1963 Nova SS 383
I am getting ready to pull the motor and will eventually pull the trans probably as well.
I wanted to find out what everyones experience has been in pulling the motor and trans together or should I just pull the motor by itself as planned and do the trans later.
I will not be taking the front end sheetmetal apart at all so clearance could definitely be an issue.
PLDbryan
1963 SS
383 Forged Bottom/AFR top/Solid Bullet Cam in the middle
Muncie 4spd
F@&^ 9" Rearend
Old 4th-December-2012, 01:44 AM   #2
dk63nogo
dk63nogo's Avatar
Nova(s): 1963 SS
If its the stock setup you can get by with them together. I know you dont want to take apart the front end but at least the grille and possibly the hood for insurance. Just my .2
Sent from my DROID RAZR using AutoGuide.Com Free App
Old 4th-December-2012, 08:20 AM   #3
Kid63
Kid63's Avatar
Nova(s): 1963 Nova SS 2drHt
I was able to get my 327 and trans out of my first gen no prob, oil pan and all.
Every day above ground is a good day...
http://www.stevesnovasite.com/forums...d.php?t=210662
Old 4th-December-2012, 08:34 AM   #4
67nova73
67nova73's Avatar
Nova(s): 73 and a 67 Nova
I havent had any problems with past exp. in pulling them together
Old 5th-December-2012, 08:28 AM   #5
Carl Stevenson
Carl Stevenson's Avatar
Hood off of course, pull them together works fine.
Unbolting 2 of the upper bellhousing bolts is hard unless you remove the trans mount and crossmember, then lower the back of the trans first. Then you can get those bolts with one of those 2 or 3 foot extensions and a 9/16" swivel socket.
Carl (in the prairies...)
65 Canso Sport Deluxe
67 SS 327
Old 5th-December-2012, 02:42 PM   #6
Wadd2
Wadd2's Avatar
Nova(s): 1964 Coupe 1966 Coupe
I've always removed the hood and grille and pulled them together. This time I pulled just the engine and left the tranny in the car. However, now I have a lift so I could get around underneath to get to bellhousing bolts etc. Motor is done and just broke in on the test stand this past weekend so when I get time in the near future I'm going back in. Hope it goes in as easy as it came out. I thought doing engine separate was easier but again, I have the luxury of a lift.
Old 5th-December-2012, 05:04 PM   #7
Jeffs63NovaSS
Jeffs63NovaSS's Avatar
Nova(s): 1963 Chevy II 400 Series
I pulled motor and trans ( 4-speed ) together ---- took off hood - grill ANYTHING that would catch on something.. Made the mistake of not putting it back in the same way....tranny was a pian in d *****.
Old 5th-December-2012, 06:09 PM   #8
VooDooII
VooDooII's Avatar
Nova(s): 62 pro street 62 wagon
I always drop the trans first then yank the engine, trans and engine need to be separated anyway
Pro Street Fraternity
5000 mile club
Old 5th-December-2012, 10:05 PM   #9
EdwardsSS
Nova(s): Two '63s and a '55.
With some Novas, you can loosen the rear transmission mount bolts and jack up the transmission just enough, in the tunnel, to get at the top transmission housing bolts.
Old 5th-December-2012, 11:44 PM   #10
TMack63nova
TMack63nova's Avatar
I dropped the trans and then pulled the engine. If you have an engine leveler then it's not a problem to pull it as a unit.
Just my
Old 6th-December-2012, 12:02 AM   #11
PldBryan
PldBryan's Avatar
Thanks for all the replies.
I will likely pull them seperate as I will probably do it alone and I would imagine just the motor would be a little easier to manage around than all at once.
Motor has been in for close to 18 years but I do seem to remember those upper bellhousing bolts being a bear to get at.
I have not been in any huge hurry to pull the motor and have had the new one sitting next to the car all fall waiting to get around to it. Now I am looking at it being Dec already and i realize I need to get to work. Pull motor and throw new one in is not biggie but I am going to do some tiddying up and making it more sanitary. Now I just bought a new 9" rear setup and want to strip the underside of the rear and get it looking new as well.
I got to get busy!!!!
PLDbryan
1963 SS
Muncie 4spd
F@&^ 9" Rearend
Old 6th-December-2012, 01:59 PM   #12
Pandora's Box
Pandora's Box's Avatar
Nova(s): 67 Nova Wagon 408"/700R4
I did mine by myself (with help from my alter ego) as an assembly. I found that it was much easier to do and was able to use proper torque on the transmission to block bolts. This is an important step to prevent cracking the belhousing due to torque from racing.
I also noticed that the factory service manual mentions to pull the whole assembly as well.
On the first day God created Hot Rods and Harleys-then came the Demo Derby to get rid of all the rest!
Old 6th-December-2012, 09:58 PM   #13
Motoboy
Nova(s): 63 Nova
I have always pulled/assembled as a whole. What a PIA to get to the bolts on the transmission, just so close to the firewall. By the time you move the engine forward and mess with getting the bolts out you could have both out together. I'd say 15-20 minutes to get both out taking your time. An engine leveler is a must though. PLus I think it's easier to assemble the engine/trans out of the car.
Old 7th-December-2012, 01:42 AM   #14
PldBryan
PldBryan's Avatar
Finished unhooking most everything tonight and thought I would take a look at the two upper bellhousing bolts. These are the 2 that are supposed to be most difficult correct? I had plenty of room to get a box end wrench on each bolt and simply undo them. Each of these cars are different right
Still not sure if I will pull together or apart, probably decide once I get there.
PLDbryan
1963 SS
Muncie 4spd
F@&^ 9" Rearend
Old 7th-December-2012, 06:24 PM   #15
nova656567
Nova(s): D/D: 65 Hardtop 65 SS, V
If you don't have a engine leveler to adjust angles pulling them together is a PIA and likely to mess up paint etc. unless you pull the core support & grille. I've always separated them and then pulled them. Still use a engine leveler, but don't have to mess with the core support or grille.
Walt
Best way to pull a 194 engine with tranny? tmoore79 Drivetrain & Performance 10 15th-February-2010 08:19 PM
I have to pull my motor out.. johnh Drivetrain & Performance 20 17th-September-2008 05:06 PM
How to pull a motor... Funkmaster Zachy Best of Drivetrain & Performance 103 5th-March-2008 01:10 AM
Engine/tranny pull burkej62 Drivetrain & Performance 8 7th-March-2007 11:35 AM
