my 1977 nova - Chevy Nova Forum
Old 28th-November-2012, 05:09 PM   #1
darricks77nova
darricks77nova's Avatar
Nova(s): 1977 nova base
my 1977 nova
here is the nova i know it looks like crap right now but its a work in progress let me know what you think
Old 28th-November-2012, 05:18 PM   #2
jimys72
jimys72's Avatar
Nova(s): 72 Nova, 78 Elcamino
Its a starting point. my has some rust like yours. just hafta cut it out and replace it. important sure u can do it.
Old 28th-November-2012, 07:23 PM   #3
carbon_x
Nova(s): 1976 Nova Base Model
Looks good! A few spots needing more attention than the rest, but a great starting point, it looks like!
Keep us posted
1976 Nova - I6 250 motor with 71k original miles. Currently being restored.
Old 29th-November-2012, 09:23 AM   #4
77-427-5sp
77-427-5sp's Avatar
Nova(s): 1977 nova bb 427 5sp tko
looks like a good starting point , good luck whats first up on the list ?
77 fake ss 5 sp tko 427 big block hyd roller cam 3.73 9 inch 4 wheel disc brakes
Old 29th-November-2012, 10:27 AM   #5
dlezama
dlezama's Avatar
Nova(s): 76Concours 77MalibuRally
Not sure about those quarters. Can be very expensive to replace, and doing yourself would probably require extensive work and at least some prior experience. I see the problem goes all the way to the rocker panel. I would check the door jambs too... If rusted through the structural integrity of the body might be compromised.
I mean, every car can be saved, but at what cost and effort? Is it worth it to you? Those are the hard questions.
I see it has buckets and possibly other rare stuff, maybe you could transfer some of these goodies to a cheap body with less rust?
Old 29th-November-2012, 11:50 AM   #6
darricks77nova
I have the new rear quarters came with the car when I bought it I do have to replace the rockers figure go full rockers if I can find em the outer wheel wells are shot if I did the summit tubs could I cut em to work as stock wells cause I gotta keep the rear seat for the kids
Old 29th-November-2012, 11:16 PM   #7
dlezama
dlezama's Avatar
In that case youre ready to go... Rockers might come from a donor car, they are rarely rusted through...
Old 30th-November-2012, 09:37 PM   #8
darricks77nova
well first is gonna have to be the rear quarters and the rockers no my inner rockers are not bad but figured why not may just replace outer rocker panels plus i wanna do the rear outer wheel wells so it wont rust anymore lol but i am thinking that i should take the frame out and do the floor pan and rhino line the heck out of the bottom of the car not sure how much rhinoliner cost but its worth it to protect the car from rusting even thinking of doing the inner pannels to so in case the heater core goes out again then the floors are double protected has any one done this before
Old 30th-November-2012, 10:39 PM   #9
ss75nova
ss75nova's Avatar
Yes the hardcore 4x4 crowd does this on their rigs. My 4x4's aren't hardcore enough, but my next one will be.
75 nova custom hatchback 355/t350/8.5.
Old 30th-November-2012, 10:53 PM   #10
darricks77nova
also the engine will be popped out for a much heftier 406 with vortech heads and cast crank i got this score from my brother in law i gotta get it aline bored and honed for the aftermarket main caps that where installed not sure what type of cam to use in it yet but i will ponder on this a while since it is machined for a factory roller cam so thinking roller and yes it is a 2 peice rear main seal block also thinking of what intake to get for it but yes im going bigger for sure lol
Old 1st-December-2012, 07:29 AM   #11
77-427-5sp
77-427-5sp's Avatar
that sounds kinda odd to me a 400 bloc is not set up for the factory rollar cam
you would need to weld the top of the lifter bosses to get more height then mill them flat plus the front of the block does not have room to correctly install the camthrust plate needed for a factory cam
why would they do that when they could simply use retro fit cam rollar cam and lifter no machining need
could it be a bowetie block or aftermarket block ?
any casting number on the back of the block where the bellhousing bolts up ?
Old 1st-December-2012, 11:30 AM   #12
darricks77nova
the way were gonna do it is to use 2.2 roller lifters and they fit just fine i will get a cam button have to since it doesnt have the cam plate provision its a 509 casting its a fairly easy mod got it off of nasty z28 all the info and every thing i will post the link here so you guys can read it its pretty kool and also it is a long post so i warn you it is long but let me find it and il get the link up here
Old 1st-December-2012, 11:38 AM   #13
darricks77nova
here it is and happy reading lol http://www.nastyz28.com/forum/showthread.php?t=190146
Old 1st-December-2012, 12:20 PM   #14
77-427-5sp
77-427-5sp's Avatar
thanks for that you have to go about 10 pages in before you see anything
kinda neat in my small block i ran a 274hr comp , i know the retro lifters are pricey , but when i weigh out time spent / parts and the lift being limited i think i would save and use the reto lifters
cam button works great , i would suggest the timing set that comes with the built in bearing on the back
Old 1st-December-2012, 12:54 PM   #15
darricks77nova
the reason i was gonna do it is its cheap easy and reliable and since im not going wild i should be ok i want to try to get away from flat tappet but im not against flat tappet just wish the new oils where stable enough for them to work properly but now its just to easy to wipe a lobe with the flat tappet cams and i think it sucks gotta go to something that is more expensive.... sory for the ranting just makes me sick to think just because there clunker program didnt work well that they made the oil companies take out the zink and phosphorus beacause the new cats wouldnt handle the zink is this our problem no i dont think so they should of researched the deal lol
In 1977 I got my 67 Nova SS at age 15 SixtySevenNovaSS Car Profiles 5 29th-June-2012 10:00 AM
1977 Nova, No Power cptnzod Drivetrain & Performance 11 1st-December-2011 01:49 PM
1977 Nova ENCS Body and Interior 5 13th-March-2011 08:51 AM
my 1977 nova right now drag-u-la 4th Generation Nova's 14 16th-December-2008 10:06 AM
1977 ss Nova 79ChevyNova Ebay, etc. Discussion 2 31st-July-2007 11:50 PM
