Saginaw bell housing - Chevy Nova Forum
Go Back   Chevy Nova Forum > Non-Technical > 1st & 2nd Generation Chevy II/Nova's
Old 20th-November-2012, 12:14 AM   #1
dave's63
dave's63's Avatar
Nova(s): 1963 chevy II sedan
I'm trying to mate a 4 speed Saginaw ( I know it's not a muncie ) to a 350 with a 168 tooth flywheel but I don't have a bell housing. Anyone know what bone yard vehicle (make & model) has a compatible bell housing? I've read i may need a 621 bell housing? Thx everyone
Alberta Newbie
Old 20th-November-2012, 12:40 AM   #2
Carl Stevenson
Carl Stevenson's Avatar
The 621 only fits 68 and up. I don't believe you'll find a bellhousing to fit a 168 tooth in the first generation Nova like you have.
Is there some reason you can't use the small starter, flywheel and bellhousing?
Carl (in the prairies...)
65 Canso Sport Deluxe
67 SS 327
Old 20th-November-2012, 12:47 AM   #3
dealer-deuce
dealer-deuce's Avatar
Nova(s): 1963 NOVA 400 1970 NOVA
bellhousing
I am pretty sure your going have to run the smaller bellhousig because of
tunnel size and clutch geometry unless are going to adapt tunnel correct
bellhousing #3849309 also the smaller flywheel 153 tooth 10.5"
Old 20th-November-2012, 11:09 AM   #4
dave's63
dave's63's Avatar
3788383 GM Housing
Carl & Dealer Deuce, nice to have support from fellow members like you guys. I'm still learning and was suprized to hear that I could use the smaller bell. I have everything from the straight 6 swap out including the 3788383 bell housing and 153 tooth flywheel. When I compareed the bolt pattern for the 168 tooth on my '81 350 crate engine it doesn't match the 153 tooth bolt pattern. I just assumed I had to go to a V8 bell housing. I just got the Saginaw 4 sp. and didn't even bother to see if it mated to the 3788383 bell housing. Sure would be nice if it did! What does it take to have my 153 tooth fit to the 350? Is this a feesible option without incurring other install problems along the way? sorry for all the questions. I'd rather not have to cut & fab up too much of the tunnel if possible. My end objective is a weekend cruzer nothing heavy duty like strip racing. Thx guys for helping me thru my build. This site is to me what a walking stick is to a blind man! Thx everyone.
Old 20th-November-2012, 06:20 PM   #5
dave's63
dave's63's Avatar
3788383 bell housing pics
This is my 1st time posting pic's so I hope i got it right? Hopefully they will shed light on what I can do to get my 4 spd saginaw hooked to my 350. BTW, i tried fitting the 4 spd tranny to my old 3788383 3 spd saginaw bell housing but no go! Hole is about 1/4" too small. Now what?
THX guys!
Old 20th-November-2012, 06:41 PM   #6
Carl Stevenson
The 153 tooth manual flywheel can be used on 194, 230, 250 6 cyl as well as 267, 283, 305, 307, 327, 350 small blocks (prior to 1986) and 396, 427 big blocks. Lots of interchange there, no problem. As you are finding though, you either need to buy the 3849309 bellhousing or have your's machined to the larger opening for your Saginaw.
Do you have all the clutch pedals, linkage etc? If not,the best thing to do is find a complete 64-67 Nova or Acadian with a manual trans (has correct 309 bellhousing) and take everything from it. The one snag is the clutch pedal needs to be 66 or older for your car.
67 SS 327
Old 20th-November-2012, 06:41 PM   #7
lyn smith
Nova(s): 1963 convert,64 wagon,63
flywheel
that looks like a 6 cylinder flywheel.
Old 20th-November-2012, 06:47 PM   #8
dealer-deuce
bell housing and flywheel
Dave, that flywheel should bolt right up to your 350 make sure you buy new
flywheel attaching bolts the are hardend, should be able to purchase them
from a good parts supplier. second you will have to hunt down a 309 bell
housing for this set up or go aftermarket with a fancy blow proof type
I am positive a member on this site has a spare 309 housing kicking around.
if you have more than 25 posts you can post in the wanted add section.
also if you are planing use that 350 you will need to change oil pan,pump
and pickup if you are going to put it in a stock front end. linkage for v-8
pretty straight forward all parts are in reproduction you will also need
cross shaft adapter for 350 block, lots parts to locate for swap.
Old 20th-November-2012, 06:52 PM   #9
dealer-deuce
flywheel
I think Lyn is correct that looks to be different from v-8 flywheel I believe
v-8 has a smooth face all the way acrossed. let me get some pics up
Old 20th-November-2012, 07:29 PM   #10
6T6NOVA
6T6NOVA's Avatar
Nova(s): 66 Nova SS
Originally Posted by dealer-deuce View Post
..........also if you are planing use that 350 you will need to change oil pan, pump and pickup if you are going to put it in a stock front end. ..............
You will need buy the Distributor oil pump drive shaft. It is shorter(for Chevy II/Nova front sump pans only) than a stock 350 one.
You will need to grind on the oil pump and the number eight(8) rod nut for clearance for the 350.
You will need to dimpel the oil pan for rod clearance for the 350.
Bryan
Old 20th-November-2012, 07:55 PM   #11
dealer-deuce
pictures of some of the parts you will need
Old 20th-November-2012, 07:58 PM   #12
dealer-deuce
Old 20th-November-2012, 08:00 PM   #13
dealer-deuce
Old 20th-November-2012, 08:36 PM   #14
Carl Stevenson
Yes, but it can still be used with the 6 cyl clutch unless it's going to take a beating!
67 SS 327
Old 20th-November-2012, 08:42 PM   #15
dealer-deuce
Beating!!
how can you not beat on 350 four speed!! maybe it is just me
T56 bell housing allanejames Drivetrain & Performance 2 11th-March-2012 01:28 AM
Which bell housing do i need? mr.murf Drivetrain & Performance 4 29th-September-2011 12:44 AM
Need help as to which Bell Housing I need. jaytone 3rd Generation Chevy II/Nova's 5 22nd-December-2007 11:17 PM
GM bell housing dadscoupe Drivetrain & Performance 1 22nd-October-2006 10:44 PM
