Second Gen PCM mount ideas - Page 2 - Chevy Nova Forum
Go Back   Chevy Nova Forum > Body, Chassis and Mechanical > Drivetrain & Performance > LSx Forum
Old 13th-November-2012, 03:57 PM   #16
Nova 404
Nova 404's Avatar
Title: Supporting Vendor
Nova(s): 1967 Nova SS
Originally Posted by novanutcase View Post
Not sure what motor your using the ECM for but I would imagine it's for an LS. I have a stock LS1 ECM mount cradle if you're interested. Once you mount it it makes it easy to slide it in and out if you have to.
John
Thanks John,post a picture so I can see which type you have.
Member of the NorCal Brotherhood!
Old 13th-November-2012, 05:30 PM   #17
charley7
charley7's Avatar
Nova(s): 1966 2dr hardtop Ls 6.0L
I got one from psi harness. It nice but not gonna work for me. I think it was under 30 bucks.
Charley
Old 13th-November-2012, 05:46 PM   #18
Nova 404
Nova 404's Avatar
Is that the one with the cip to hold in hte ECM? If so I saw that and cant see any way to use it where I need the ECM
Old 13th-November-2012, 06:09 PM   #19
charley7
charley7's Avatar
Yes that's the one. Chuck was telling me about a S-10 one but don't know if its a different design or what year it's from.
Charley
Sent from my iPhone using AutoGuide.com App
Old 13th-November-2012, 07:26 PM   #20
novanutcase
novanutcase's Avatar
John
Build Pics(No Comments)
http://www.stevesnovasite.com/forums...ad.php?t=78088
Old 13th-November-2012, 08:22 PM   #21
charley7
charley7's Avatar
Hey John. Is that a factory PCM holder and from what vehicle
Charley
Old 13th-November-2012, 08:35 PM   #22
snolan
snolan's Avatar
Nova(s): 1967 Sedan LS2/T56
Pcm
This may not be the same computer, I welded two tabs to the bottom of the dash i can still get my glove box in but never installed it ...Mine is a Fbody computer, guessing you have something else.
MY fuse block for the PCM (Ingnore the wiring mess it was a mockup)
Steve
1967 Sedan LS1/T56
http://s252.photobucket.com/albums/hh17/snolan1/67ebay/
Old 13th-November-2012, 09:24 PM   #23
Toxic
Toxic's Avatar
Nova(s): 67 Nova, 69 Camaro Conv
funny, I've had the same conversation with my buddy that builds a lot of pro-touring cars. he said " I don't understand why everyone wants to put the computer in the cab, your never going to touch it, everything it programed thru the obd port." Even GM leaves it in the engine compartment.
I was like Oh Yeah Huh ? He mounts the computer in the pass fender well in all his LS builds. In the novas, I would build a sheet metal box in the fender well.
Just a Idea.
Will aka Thread Killer
Old 13th-November-2012, 10:14 PM   #24
Nova 404
Nova 404's Avatar
Steve same computer,factory heater box is an issue in that location as best i can tell and I would like to keep my glove box..Toxic,I just do not want to ever see it especially under the hood.I know they are under the hood in factory applications.I tried to get some pictures but I do not have enough hands to get it in place and snap a picture.
Click image for larger version
ID:	23941   Click image for larger version
ID:	23942   Click image for larger version
Old 13th-November-2012, 10:24 PM   #25
the FLYER
the FLYER's Avatar
Nova(s): B Pillar of Society
Mount it under the fender on the firewall... make a cover for it.
David went into the Heidt's inner fender, driver side... just in front of the hinge, installed a cover. You'd possibly have the same type of room with a stock inner fender... maybe...
Speaks the guy with the ancient, dinosaur... unwanted stepchild, 1st generation Chevy V8 engine...
'64 411 377-Tko600-3:73's
'64 469, '63 435 (projects), & '63 469 (my driver)
Videos~Albums
Old 13th-November-2012, 10:38 PM   #26
novanutcase
Charley
Yes! I think it's from an '02 'Vette.
John
Old 14th-November-2012, 07:37 AM   #27
TomM
TomM's Avatar
Nova(s): 66, 67 Coupe
Brian, I used the mount John showed, typical for 98-02 F-bodies. I turned the computer facing forward. I trimmed the large tab off the front so it wouldn't be hanging down. Then I made some "L" brackets off the PCM holder and secured them to whatever I could find above it. The mount was very sturdy, and also let you swivel the PCM down to remove it if needed. It tilted up enough that you couldsn't see the wires from outside the car. With the computer out of the mount, I had full access to the fuse box.
T,
Old 14th-November-2012, 08:43 AM   #28
Nova 404
Nova 404's Avatar
Interesting Tom would you have any detailed pictures?I was plalooking at it last night and it does fit the area a little better with the wires facing forward.
Old 14th-November-2012, 09:08 AM   #29
TomM
TomM's Avatar
Didn't shoot any pictures, sorry, it was in the blue car, so I don't have access anymore.
If I remember, I screwed one side of the bracket to the sheet metal, just above the kick panel, and the other was screwed to the brake pedal support. I used fairly thick aluminum, and just bent it accordingly. It was real sturdy, and didn't vibrate at all....
I used self locking nuts on the bracket so I could tweak it just tight enough to swing it down, yet it wouldn't move under it's own weight....
T,
Old 18th-November-2012, 10:49 PM   #30
Nova 404
Nova 404's Avatar
I have been playing around with this,so far this is the idea not sure yet if its going to work out or not.PCM fits the bracket very nicely,anchoring the bracket securely in the car is looking like much more of a problemSo few areas to bolt anything in in that area.
Pull out the quick pins,slide slightly forward and it drops out of the bracket.I have things just tacked into place in case i need to make adjustements
First Gen Mini Tub Upper Shock mount options, opinions, Ideas???? DevilDeuce Steering, Suspension, and Chassis 0 18th-August-2012 03:38 PM
top post teminal mount vs side mount round betty Electrical 3 22nd-September-2010 01:50 AM
I need to see low mount alternator, and low mount power steering setups slownova73 3rd Generation Chevy II/Nova's 12 15th-February-2010 10:05 AM
283 SBC motor mount and frame mount papasnova Drivetrain & Performance 4 25th-April-2006 12:36 AM
