mono to multi leaf spring - Chevy Nova Forum
Old 13th-May-2010, 02:57 PM   #1
Novaman71
Novaman71's Avatar
Nova(s): 1971 Nova
I want to upgrade top multi leaf, can i just cut the old perches out and weld new ones on and install multi leaf leaf springs?
Old 13th-May-2010, 03:14 PM   #2
mrdreex
mrdreex's Avatar
Nova(s): 72' Nova 383 AFR/solid
You will need different spring perches than the mono leafs, but yes, as far as cutting is concerned, you can do that. You will need to get it just right though as not to mess up your pinion angle. I am not 100% sure how you go about measuring pinion angle that way, but that's the only thing you will need to worry about perch-wise.
Old 13th-May-2010, 03:25 PM   #3
Dutch
Dutch's Avatar
Nova(s): 71 SS/74 Custom/74 Hatch
Assuming that you have monos on right now, I would keep them and if your monos still hold your car up, you can install a full floater rear hanger and run a ladder bar. You can keep your original mono and strap on helper leaves making your own multi-leaf spring by adding the Calvert half spring (an old trick as only the front half of the spring controls engine torque) and using the their torque tube (traction bar).
If you are going to go multi-leafs you have to decide between three leaf, five leaf, six leaf and half leaf add ons. The spring eye material makes a difference as well. You can use aluminum in the front eye but not in the rear hangers as they have to have some deflection to keep from binding. Polyurethane and Delrin plastic bushings both work as well as a hard rubber bushing.
Alot depends on what your overall goals with the car are. Most dealers sell set-ups that are a direct bolt on requiring no fabrication, if you think you have to move your perches then you should look at a different dealer. Just make sure you get the right arch, they are different between set-ups, traction bar or no bar.
"Street Legal, who's really looking?"
Old 13th-May-2010, 04:23 PM   #4
Novaman71
Novaman71's Avatar
Nova(s): 1971 Nova
I was thinking about keeping it mono, however i am upgrading up a v8 and was concerned with them buckling on me with the extra torque and hp.
Old 13th-May-2010, 05:12 PM   #5
Dutch
Dutch's Avatar
Monos are used by a ton of racers, some swear by them. There are pros and cons to each, you have to decide what you want for handling and ride comfort.
Old 13th-May-2010, 06:03 PM   #6
Dan_Lebherz
Dan_Lebherz's Avatar
Nova(s): 1964 Chevy II Wagon
Contact ESPO Springs & Things. they can sell you springs and pads and everything else you need to to replace your springs.
I changed out my monleaf leaf springs for multi leaf springs nearly 8 years ago and I'm still using the monleaf axle mounts. No problem that I have detected. Mine is a first gen.
64 Wagon
383, TH200-4R, 3.73s
11.683 @ 114.70 MPH 1.580 60'
Old 13th-May-2010, 06:49 PM   #7
1320quick
Nova(s): 1971 Nova 1968 Chevy II
I run mono leafs on my 71 Nova and we have 1500hp on the bottle and have been deep in the 8 second zone at almost 170mph. It depends on what you want to do with it. Calvert split leaf mono's work great but there are other options out there as well. If you decide to switch to multi-leaf springs, there are companies that see a setup that allows you to keep the mono spring perch on the axles and not have to swap them out. That being said, it's not all that hard to replace the spring perches.
Old 14th-May-2010, 01:06 AM   #8
Novaman71
Novaman71's Avatar
Nova(s): 1971 Nova
I see, ill do some shopping around to see what i want to actually want to do. All the cars being built for is to have fun joy riding every now and again, but knowing you can run a lot of hp with monos i might keep them or find multi springs that can fit with my perches that are on there now. Thanks to all, Richard.
Old 14th-May-2010, 10:19 AM   #9
71'Nova 383
71'Nova 383's Avatar
Nova(s): 71 Nova
Hotchkis Multi Leafs
Just changed my mono leafs out for a set of Hotchkis multi leaf springs, part #2407C. I have the mono leaf perches on my rearend. They give you a thick urethane spring pad for the top that allows the multi leaf bolt to work in the mono perch. So far I like them. Under normal driving they're smooth and semi-soft. Under cornering when you get into the over loads they stiffen up. Nice combo....
Old 15th-July-2010, 11:41 AM   #10
Novaman71
Novaman71's Avatar
Nova(s): 1971 Nova
I am going to go with the Hotchkis multi leaf springs, part #2407C, it has a 1.5 in. drop to it. Do i need to have any modifications to my suspension or could i still use the original shocks that are required?
Old 15th-July-2010, 05:12 PM   #11
Fast Eddie
Fast Eddie's Avatar
Nova(s): 1966 Nova
Calvert split-mono and Calvert Traction bars.
Fast Eddie
1966 Nova
408 cu in SBC
Aqua
Old 15th-July-2010, 09:55 PM   #12
71'Nova 383
Nova(s): 71 Nova
You should be able to use your original shocks however, the right way to do it is to measure it once you have the springs installed and the car sitting on the ground. Ideally you want the shock to be in the middle of it's stroke at ride height.
In ride height position it is suppose to be about 16.5" on our cars.
Mine was 17.5". When I talked with hotchkis they said that was still ok.
Their shock compressed is 12.94" and 20.09" full extended.
Old 15th-July-2010, 10:17 PM   #13
Nova(s): 1972 Nova
You don't need to change perches on a 71 going from mono to multi leaf springs. I did it on mine without any issues. The only thing I had to do was to drill the locator hole bigger. I ordered the multi leafs from Classic Nova I believe many years back on the 71 in my avatar( I sold it about a few years back). The Mopar style and universal style spring perches don't even use any sides on them at all. I am pretty positive that I ordered the 5 leafs, and I think they offer a 4 leaf also. I did order new pads for the multileafs, ran stock rear shocks, and 90-10's in the front, subframe connectors, and traction bars also. Now I couldn't tell you a thing about any of the competition style springs, but mine worked good for me on the street and the strip. I wished I would have taken the car to the strip before with the monos though to see how it reacted. I only changed because of the old age and sagging springs.
Old 16th-July-2010, 10:30 AM   #14
JBimmolate
JBimmolate's Avatar
Nova(s): To be determined...
To avoid the perch swap you can make buy some solid spacers to make up the difference to keep the plate from bending too much. or just stack some washers .
Miles
" The Resident Differential Guy, Have A Question? Just Ask! "
11/2016 FastEddie, he will be missed
Old 16th-July-2010, 11:18 AM   #15
Nova(s): 1972 Nova
My traction bars took the place of the plate, so maybe my traction bar plate was a little beefier. I did away with the t bolts and used two u bolts instead and went to the bigger size up u bolts.
Mono/Multi Leaf spring perch/saddle question Cory Steering, Suspension, and Chassis 4 24th-June-2010 12:49 PM
Mono to Multi Leaf Spring. HELP!! 69BBNova Steering, Suspension, and Chassis 6 15th-June-2010 02:27 PM
63 leaf spring mono or multi? jb8100 Steering, Suspension, and Chassis 2 28th-February-2010 08:08 AM
Difference bewteen mono leaf srping and multi leaf spring?? 73NovaMan Steering, Suspension, and Chassis 7 30th-October-2009 12:47 AM
