Spring Compressor? - Chevy Nova Forum
Old 13th-June-2010, 11:13 PM   #1
floaterboy
floaterboy's Avatar
Nova(s): 64 2DR Sedan
Spring Compressor?
I need to remove the front coil springs on my '64. My question is which type of spring compressor works the best? The 2 piece type that clamps on the outside of the spring or the one piece style that goes through the inside center of the spring. Where is the best place to find a quality tool to do the job?
Thanks,
Len
Old 13th-June-2010, 11:55 PM   #2
jer66nova
jer66nova's Avatar
Nova(s): '75 nova best1/4 mile 13.
Thanks,
Len
you can remove the springs with out compressor putting them back is abit of a challenge. raise car and support on stands after removing wheels and tie rods from spindles and remove shocks. take lower balljoint nut and loosen it do not remove at this time loosen up lower comtrol arm bushing mount bolt. support lower contrlo arm with floor jack and remove and seperate balljoint lower jack until all pressure is off the spring. use a large pry bar and you can pop them out, of course be careful but you can get them out
66 chevy IIsedan
PROSTREET FRATERNITY MEMBER
http://s156.photobucket.com/home/jer66nova/index
Old 14th-June-2010, 12:05 AM   #3
Nova SS 67
Nova SS 67's Avatar
Nova(s): 67 Nova SS Mod Hot Rod
autozone is free.
Old 14th-June-2010, 11:25 AM   #4
nova66mussl
nova66mussl's Avatar
Nova(s): 66 H/T 66 Wagon 1933 Fo
You have to remove the shock & use an inside type coil spring compressor. The above mentioned works on 68 & later cars. I changed the springs on my 66 wagon yesterday, took 1.5 hrs. The key is having the right tool for the job.
Old 14th-June-2010, 11:37 AM   #5
tony
tony's Avatar
Nova(s): '63SS'64SS'654D'76HD'89HD
Originally Posted by Nova SS 67 View Post
autozone is free.
^^^ Good suggestion.......
Just look the tool over good before you take it home. Sometimes people return tools damaged or missing components & they don't get checked before being put back on the loaner shelf......
Here's the best I've seen for the job.......
http://www.parts123.com/parts123/yb....Z5Z5Z50000132A
Old 14th-June-2010, 01:14 PM   #6
Stuntman Mike
Stuntman Mike's Avatar
Nova(s): '69 Nova
Autozone is worthless for this application. They gave me those MacPherson strut spring compressors. They said that was all they had. They were completely useless. Getting my springs in required me doing things the dangerous way: A pry bar and a couple of heavy duty ratchet straps. I wouldn't recommend that way to anyone though. I should've just got the right tool rather than risk injuring myself or worse yet, damaging my car.
Old 14th-June-2010, 01:43 PM   #7
Nova(s): 1972 Nova -383
Most springs can be done without any problems and without a spring compressor. I installed Moroso trick springs and had to use an internal compressor as the spring was so long. Doesn't hurt to hook the spring to a scrap piece of chain and strap it or bolt it to the frame. Those springs coming out can kill or injure a person very easily.
Old 14th-June-2010, 02:04 PM   #8
NovatoriusRex
NovatoriusRex's Avatar
Nova(s): 67 Chevy II Nova Hardtop
I picked up an internal spring compressor on Ebay for about $30. It'll come in handy multiple times, so it's something I recommend having in your Chevy II's garage.
-Brent
I want a new duck. One that won't steal my beer... - Weird Al
Old 15th-June-2010, 09:37 PM   #9
nukledragger
Nova(s): '68 L78, and others
I've changed several sets of front coils recently and have rented internal spring compressors from O'reilly as well as AutoZone. After having several of these release tension and "pop" as I was walking across the shop with the compressed spring in my hand, I called the MAC Tool man. He brought one by my office for $100. I asked, what's the diff between the $30 compressor and the $100 compressor. He replied, "the $100 one won't kill you". He was right, worked first time, no issues. Best $100 I ever spent.
JMHO
ND
Old 15th-June-2010, 10:46 PM   #10
Bipolar4U
Title: Readers Club
Nova(s): '64 2dr. SEDAN
Harbor Freight has an excellent spring compressor that's reasonably priced.
Old 15th-June-2010, 11:15 PM   #11
Rroxon7
Rroxon7's Avatar
Nova(s): 1964 Wagon 400. 1966 1/2
autozone is free.
I'm using one from Autozone right now... It cost $54 to walk out of the store with it.. You'll get your money back when you take the compressor back.. I used the hook style using it on both sides.. Springs came out without issues
Old 15th-June-2010, 11:32 PM   #12
Greg_R_63
Greg_R_63's Avatar
Nova(s): 1963 2-dr hardtop
Thanks,
Len
I have one of these, and I recommend it highly:
Early Nova Spring Compressor
Old 16th-June-2010, 12:02 AM   #13
surfdog
surfdog's Avatar
Nova(s): 64wagon, 67wagon
Do not attempt this job without a spring compressor. The Chevy2Only tool is the way to go!
John
Which Valve Spring Compressor? tnblkc230wz Drivetrain & Performance 16 4th-June-2009 03:59 PM
Spring compressor required? Vnova Steering, Suspension, and Chassis 4 10th-February-2009 03:02 AM
coil spring compressor Steves 70SS Steering, Suspension, and Chassis 4 10th-July-2007 05:56 PM
Front Spring Compressor Bluesman 3rd Generation Chevy II/Nova's 8 7th-October-2006 10:59 PM
