Old 7th-November-2009, 02:10 PM   #1
walkerjay
walkerjay's Avatar
Wheel cylinder prep
Just received my 2 Wagner rear cylinders in the mail. They are standard cast finish. They look good but think I should spray them? I guess without any coating they are prone to rust eventually. Am I right?
Jay Walker
71 Nova SS
Deleware Valley Nova member
http://s79.photobucket.com/albums/j151/walkerjay/
Old 7th-November-2009, 03:34 PM   #2
supr78nova
Nova(s): '78 & '79
they will get some surface rust on them after they sit a while...nothing that would affect performance of the braking system. It has never crossed my mind to coat a wheel cylinder in anything, but I don't think it would hurt either if you feel inclined. Are you planning on taking off your drums every now and again to show off your wheel cylinders?
Dan
350/TH350,8.5" Eaton posi w/3.42's,Vortecs,RPM intake,Holley 650,XE268,Elite headers,X-pipe,Ultraflows
Old 7th-November-2009, 03:48 PM   #3
walkerjay
walkerjay's Avatar
Not planning on showing them off. Think I will spray them with some cast paint I have, just for peace of mind. Do they get hot? Any need for high heat paint?
Jay Walker
71 Nova SS
Old 7th-November-2009, 06:47 PM   #4
the mechanic
Nova(s): 1970 Nova
LOL...Are you bored or somthing
Any paint should be fine-theres some heat there but not enough to hurt the paint i dont think...
Old 7th-November-2009, 11:16 PM   #5
bowtie0069
bowtie0069's Avatar
Nova(s): 69
I guess you don't drive the way some of us do......I've had to wait over an hour to be able to touch the wheels on some cars I've driven--header paint wouldn't have lasted!
69 Nova 410" pump gas small block-6.63/101
http://bowtie0069.fotki.com/
http://www.thefunnycarfarm.com
Old 8th-November-2009, 12:24 AM   #6
the mechanic
Nova(s): 1970 Nova
The wheels and the drum will be hot-but touch the backing plate-not so much!
Old 8th-November-2009, 12:54 AM   #7
walkerjay
walkerjay's Avatar
Not bored at all. Just trying to do the best job I am capable of. Plus, I'm an expert at masking off and spraying with a rattle can
Never installed wheel cylinders before. In general, brake line fittings get tightened up dry, right? No teflon or sealant right?
Jay Walker
71 Nova SS
Old 8th-November-2009, 11:51 AM   #8
the mechanic
Nova(s): 1970 Nova
Correct-never any sealer on flared type fittings...
Old 9th-November-2009, 10:35 AM   #9
Rotorbolt
Nova(s): 1964 Chevy II 400 4dr sed
Go ahead and paint them. I always paint anything that has a bare cast finish on them before I put it on the car. It looks good and is easier to work with later if you end up having to. I hate working on rusty brake parts. So i'll paint everything I can. I've even painted the back insides of rotors, drums and the various little springs and hardware in drum brakes. Just make sure you mask off the machined surfaces. So you're not alone in wanting to do a nice job. I'm the same way. I'm a professional and I like professional results.
Rear wheel cylinder size orange70 Steering, Suspension, and Chassis 0 7th-August-2009 12:35 PM
4 wheel disc master cylinder SSCAPRICEWAGOM Steering, Suspension, and Chassis 1 24th-May-2008 11:36 PM
Dumb wheel cylinder question. Jeff O Steering, Suspension, and Chassis 3 17th-May-2008 02:18 AM
Rear wheel cylinder rebuild hobnose Steering, Suspension, and Chassis 11 5th-July-2007 12:30 PM
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
