Originally Posted by the mechanic
Both ways will work, as will putting the sealer on and bolting manifold down right away...I prefer the slight skin method-ive worked with hundreds of people who did this hundreds of ways-
two things always remain the same, Very clean surfaces and using enough rtv.
Yeah, yer right, get her clean first. Thats prolly the most important part...
Now.... The letting it skin up first??? I REALLY dont get the logic behind that. I understand the concept. If you lay an intake down on wet silicon it will squish it all out, been there, done it, there isnt any support there and no skin to keep the wet silicon from seeping into the working part of the engine.
So is that the only reason to let it skin up?? Cause its not a valid reason IMO. Everyone knows the silicon is gonna be really tight on the lower half cause it was laid down on a super dry surface and the silicon was wet, it grabs like gang busters. So then why wouldnt you want the same contact for the upper piece??? Maybe cause guys dont want to spend the time to shim it up with a few sticks of wood to keep it from completely squishing the sealant out till the sides skinned up??
Dunno, I just know from my uses of silicon that a wet silicon to dry metal surface is almost perfect.
My only advise, and its not good for much LOL Is get the silicon bead when its wet.. Wet is good
JR
