Go Back   Chevy Nova Forum > General > Drag Racing Forum
Old 3rd-November-2009, 12:19 AM   #1
burntnova
Gearing Help
Ok,
I've got my 84 Camaro tube chassis car. I know it's not a nova but my street car is...lol. Anyways, I took the car down to the track for the last test & tune of the year and I had changed my blower pulley and I got almost a half second off my ET in the quarter so now the car is running 9.57
My problem is I was going through the traps at about 8600 RPM and that is a little high. So I want to lower that over the winter What are my options?
I have a 31 tall tire
rearend gears: 4:86
trans:BTE 2 spd powerglide, 1.86 straight cut gear
I'm thinking I either have to change the rearend gears or possibly a taller tire?
What does everyone recommend?
Old 5th-November-2009, 04:20 PM   #2
TechGuy
what mph did it run ?
Mike Weddle
Senior Sales Technician
Chris Alston's Chassisworks
Old 6th-November-2009, 01:58 PM   #3
burntnova
the MPH was 157. I can't find the slip but I'm pretty sure that's what it was.
Old 6th-November-2009, 08:05 PM   #4
Boxhead
Nova(s): '63 hardtop
Going to either a 4.56 gear or a 33" tire will drop you 450 rpm or so at the same mph. Visit the TCI trans website. Under the "technical" section you will find thier "racing calculators". They are very easy to use and quite handy.
Old 7th-November-2009, 12:08 PM   #5
Seattle_Mike
Seattle_Mike's Avatar
We run a tube chassis 68 Camaro with 34.5 tall slicks, Glide, and 4:11 gears. Through the lights 7900-8300 200+mph
33 Ford 3 Window 468ci Street Rod
68 Camaro ProMod/ProStreet Race Car
67 Nova Race Car
Old 7th-November-2009, 03:43 PM   #6
Cool II
Cool II's Avatar
You changed the blower pulley? You did not say how this changes your boost. Sounds like you upset your converter.
'64 sedan 327 PG, disturbed.
Upon 10 jack stands it waits
Odd Rooster
Old 7th-November-2009, 04:10 PM   #7
Cool II
Cool II's Avatar
I have said this before, your meal ticket is held by the hands bending the fins. The converter can be your best friend or your worst enemy. Get cozy with your converter man, send him birthday cards and shake his hand in public.
No seriously you can tune your converter. A good converter man can tune-up your ride better than you may think.
Odd Rooster
Old 7th-November-2009, 06:00 PM   #8
Seattle_Mike
That's why I recently purchased a bolt-together converter, so I can service it myself instead of having to send it in all the time.
67 Nova Race Car
Old 8th-November-2009, 03:13 PM   #9
burntnova
Yeah I changed my pulleys two weeks ago and it bumped my boost up to 8 from 5.
Old 8th-November-2009, 03:17 PM   #10
burntnova
what I'm running:
355 small block chevy with 177 weind blower
TCI 8" 5500 stall convertor
BTE straight cut gear powerglide
4.86 gears in the rearend
31" tall tire
my times last week were:
9.55 @ 158
my three passes didn't change much from that number. but like I said I don't want to be going through the traps at 8600 RPM. I would like that to be a little lower and that also got bumped up with the new pulley's.
Old 14th-November-2009, 12:45 PM   #11
Cool II
Cool II's Avatar
How much would your tune up suffer from a rear axle ratio change? You may have your 60 foot dialed in with the 4.86 gear, but I think this ratio may be a little deep. Your trap RPM is a bit much with a mini blower, it just heats the air at that point.(especially with your pulley change) I think a smaller gear (4.56~4.30) might upset your 60ft, but you will gain top end because the blower will be more efficient at the lower RPM.
Odd Rooster
Old 14th-November-2009, 01:03 PM   #12
Cool II
Cool II's Avatar
At some point in your tune up, the roots blower will fight you, become a back stabber. When it heats the air. And it will if you let it. With the roots, regardless what displacement, you need to know at what RPM and load the supercharger begins to heat the air.
Odd Rooster
Old 14th-November-2009, 01:09 PM   #13
Nova_Guy
Nova_Guy's Avatar
Nova(s): 68 Chevy II SS
Originally Posted by burntnova View Post
Ok,
rearend gears: 4:86
What RPM do you want to go through the traps at? Each .1 of gear change will lower RPM 100 RPM at any speed.
My web site
Webshots photo albums
1968 Chevy II National Nostalgic Nova Member
gearing ochaole Drivetrain & Performance 4 8th-October-2009 08:00 PM
gearing 74350 Drivetrain & Performance 2 10th-October-2008 09:08 PM
TH-350 gearing 1977stroked Drivetrain & Performance 3 9th-September-2007 04:46 PM
Gearing issues tgiroux Drivetrain & Performance 5 4th-June-2007 06:49 AM
Need Gearing and other advice sargas3 Drivetrain & Performance 6 29th-June-2006 04:30 PM
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
